megaAVR_TimerInterrupt Library to support megaAVR (UNO WiFi Rev2, Nano Every)
How To Install Using Arduino Library Manager
This library enables you to use Interrupt from Hardware Timers on an ATmega4809-based boards, such as Arduino megaAVR : UNO WiFi Rev2, AVR_NANO_EVERY, etc.
As Hardware Timers are rare, and very precious assets of any board, this library now enables you to use up to 16 different ISR-based timers, while actually consuming only 1 Hardware Timer. Timers' interval is very long (ulong millisecs). The most important feature is they're ISR-based timers. Therefore, their executions are not blocked by bad-behaving functions or tasks. This important feature is absolutely necessary for mission-critical tasks.
Why do we need this megaAVR_TimerInterrupt Library
Imagine you have a system with a mission-critical function, measuring water level and control the sump pump or doing something much more important. You normally use asoftware timer to poll, or even place the function in loop(). But what if another function is blocking the loop() or setup().
So your function might not be executed on-time or not at all, and the result would be disastrous.
You'd prefer to have your function called, no matter what happening with other functions (busy loop, bug, etc.).
The correct choice is to use a Hardware Timer with Interrupt to call your function.
These hardware timers, using interrupt, still work even if other functions are blocking. Moreover, they are much more precise (certainly depending on clock frequency accuracy) than other software timers using millis() or micros(). That's necessary if you need to measure some data requiring better accuracy.
Functions using normal software timers, relying on loop() and calling millis(), won't work if the loop() or setup() is blocked by certain operation. For example, certain function is blocking while it's connecting to WiFi or some services.
The catch is your function is now part of an ISR (Interrupt Service Routine), must be lean and mean, and follow certain rules. More to read on:
HOWTO Attach Interrupt
Important Notes:
  1. Inside the ISR function, delay() won’t work and the value returned by millis() will not increment. Serial data received while in the ISR function may be lost. You should declare as volatile any variables that you modify within the attached function.
  2. Typically global variables are used to pass data between an ISR and the main program. To make sure variables shared between an ISR and the main program are updated correctly, declare them as volatile.
Initial Release v1.0.0
  1. Intial release to support to ATmega4809-based boards, such as Arduino UNO WiFi Rev2, AVR_NANO_EVERY, etc.
  2. New examples to support Blynk using WiFiNINA_Generic and Blynk_WiFiNINA_WM libraries.
Currently Supported Boards
  • Arduino UNO WiFi Rev2, AVR_NANO_EVERY, etc.
  • ATmega4809-based boards.
Examples:
  1. Argument_Complex
  2. Argument_None
  3. Argument_Simple
  4. Change_Interval
  5. FakeAnalogWrite
  6. ISR_16_Timers_Array_Complex
  7. ISR_RPM_Measure
  8. ISR_Switch
  9. ISR_Timer_Complex
  10. ISR_Timers_Array_Simple
  11. ISR_Timer_Switch
  12. ISR_Timer_Switches
  13. RPM_Measure
  14. SwitchDebounce
  15. TimerDuration
  16. TimerInterruptTest
Release v1.3.0
  1. Fix TCB Clock bug. Don't use v1.2.0
Release v1.2.0
  1. Selectable TCB Clock 16MHz, 8MHz or 250KHz depending on necessary accuracy
  2. Add BOARD_NAME definition
Release v1.1.0
  1. Fix bug. Don't use v1.0.0
Example ISR_16_Timers_Array_Complex on Arduino megaAVR Nano Every to show timer accuracy
3.1. TCB Clock Frequency 16MHz for highest accuracy
Starting ISR_16_Timers_Array_Complex on megaAVR Nano Every
megaAVR_TimerInterrupt v1.2.0
CPU Frequency = 16 MHz
TCB Clock Frequency = 16MHz for highest accuracy
Starting  ITimer1 OK, millis() = 6
SimpleTimer : 2, ms : 10007, Dms : 10007
Timer : 0, programmed : 5000, actual : 5000
Timer : 1, programmed : 10000, actual : 10006
Timer : 2, programmed : 15000, actual : 0
Timer : 3, programmed : 20000, actual : 0
Timer : 4, programmed : 25000, actual : 0
Timer : 5, programmed : 30000, actual : 0
Timer : 6, programmed : 35000, actual : 0
Timer : 7, programmed : 40000, actual : 0
Timer : 8, programmed : 45000, actual : 0
Timer : 9, programmed : 50000, actual : 0
Timer : 10, programmed : 55000, actual : 0
Timer : 11, programmed : 60000, actual : 0
Timer : 12, programmed : 65000, actual : 0
Timer : 13, programmed : 70000, actual : 0
Timer : 14, programmed : 75000, actual : 0
Timer : 15, programmed : 80000, actual : 0
SimpleTimer : 2, ms : 20066, Dms : 10059
Timer : 1, programmed : 10000, actual : 10000
Timer : 2, programmed : 15000, actual : 15006
Timer : 3, programmed : 20000, actual : 20006
SimpleTimer : 2, ms : 211269, Dms : 10064
Timer : 0, programmed : 5000, actual : 5000     <========== Very accurate @ clock 16MHz
Timer : 2, programmed : 15000, actual : 15000
Timer : 3, programmed : 20000, actual : 20000
Timer : 4, programmed : 25000, actual : 25000
Timer : 5, programmed : 30000, actual : 30000
Timer : 6, programmed : 35000, actual : 35000
Timer : 7, programmed : 40000, actual : 40000
Timer : 8, programmed : 45000, actual : 45000
Timer : 9, programmed : 50000, actual : 50000
Timer : 10, programmed : 55000, actual : 55000
Timer : 11, programmed : 60000, actual : 60000
Timer : 12, programmed : 65000, actual : 65000
Timer : 13, programmed : 70000, actual : 70000
Timer : 14, programmed : 75000, actual : 75000
Timer : 15, programmed : 80000, actual : 80000
SimpleTimer : 2, ms : 221333, Dms : 10064
