I'm trying to send a jpg image encoded with this code snippet:
int err = mbedtls_base64_encode(NULL, 0 , &dlen, src, slen);
const char *dst = (char*) heap_caps_calloc(dlen, 1, MALLOC_CAP_INTERNAL); //MALLOC_CAP_8BIT);
size_t olen;
err = mbedtls_base64_encode((unsigned char*)dst, dlen , &olen, src, slen);
Using MALLOC INTERNAL, when espcam takes the picture it resets
In the setup function Serial.println(ESP.getFreeHeap());
returns this: FreeHeap is: 263008
That's because the only already encoded image size I'm getting is only 8Kb. I expected more, much more, at least 30 Kb.
When I try to send an image of just 15Kb to the test-API it generates this error:
[V][ssl_client.cpp:59] start_ssl_client(): Free internal heap before TLS 66764
[V][ssl_client.cpp:65] start_ssl_client(): Starting socket
[V][ssl_client.cpp:104] start_ssl_client(): Seeding the random number generator
[V][ssl_client.cpp:113] start_ssl_client(): Setting up the SSL/TLS structure...
[I][ssl_client.cpp:127] start_ssl_client(): WARNING: Skipping SSL Verification. INSECURE!
[V][ssl_client.cpp:197] start_ssl_client(): Setting hostname for TLS session...
[E][ssl_client.cpp:36] _handle_error(): [start_ssl_client():207]: (-32512) SSL - Memory allocation failed
[E][WiFiClientSecure.cpp:133] connect(): start_ssl_client: -32512
[V][ssl_client.cpp:265] stop_ssl_socket(): Cleaning SSL connection.
[D][HTTPClient.cpp:1139] connect(): failed connect to api.io:443
[W][HTTPClient.cpp:1438] returnError(): error(-1): connection refused
Error on sending POST: -1
[D][HTTPClient.cpp:400] disconnect(): tcp is closed
Using HttpClient. The api accepts both https and http
What can I try here ?
Thanks
...Luckily I managed to solve the out of memory problem by declaring the huge base64 string not as String but as const char*
For a moment I was happy but unfortunately it was a false alarm.
I've slimmed down the code until the basics remain that cause the problem of memory allocation failure.
This is the code, note that it does not have a photo taking function. But there's this huge String of an encoded photo.
// ESP DEV MODULE PSRAM enable e Default 4 Mb with SPIFFS (1.2 mB APP / 1.5 mB SPIFFS)
#include "Arduino.h"
#include <ArduinoJson.h> // v5.13.5
#include <HTTPClient.h>
#include <WiFi.h>
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "esp_camera.h"
//char ssid[20], password[20];
const char* ssid = "xxxxxxxxxxxxx";
const char* password = "yyyyyyyyyyyyy";
int nowifi;
char json_str[34000];
String url = "https://api.z-api.io/instances/3B9AD37835F/token/09666523C/send-image";
String foto = "/9j/4AAQSkZJRgABAQEASABIAAD/2wBDAAMCAgMCAgMDAwMEAwMEBQgFBQQEBQoHBwYIDAoMDAsKCwsNDhIQDQ4RDgsLEBYQERMUFRUVDA8XGBYUGBIUFRT/2wBDAQMEBAUEBQkFBQkUDQsNFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBT/wAARCAEtAS0DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD3b9qL/k7Kw/7EqL/0tuK5sd66L9qZ9n7WNh/2JUX/AKWz1zcZ3ttA5NfKZprXXoNK5ZtjmTFdNpw2xLxk4rHs7Ekqqrlz+ldJYWrfIMdOteNymy2NCBCsYyKp6jPiI4FaePKibjGBWJqT/uT9K0igsYc07AFsU2K6LDNLNGxTFU2jKjJzVOOg7HR2N8xj2huv8qivraSZXYMjkYATd8xycDjvXPC6e2bcGOa3bbXlSAiV/sqEFjJvAwB1IPUHnt9K1oX5rGkU0ij4i1mDTLWCK8twsifP5xcq6+wwa8e8a/FbQ/Bs8kljcefqc8bPLZvI0nlYwQpOcMM46YJxjIrk/i78atQ8S6ndado/7sW7sPtEeWLgYw/J4AA4HfJNeG3BaaZoVuwC77ZrmTOA3vgHAH4YzX0dKgpasLtnZ+PPjH4j+I10dKid7bS4D+8CSHAHflcKW55xzyfSl8Nadp/gy2N5JHDd6rP8zvMMxwx9OFxkHHOepIzXG22q6fpcQitV2QRnfjcWEjH7rg5yzk9AaqXV9da60BMjQKztIIVOBwMn0wAATya9FRjBWRm4tnc6x8Z9cOpRR6PevazwRvFJcxuciNwwKqeg+ViOOcE0jKbrwvPc3GrO8kyhVto4TM0eThQ2BgHB3fN7Vwur3MWmanJaeULSV4ElEioJCpxywB6ZOTkg49DVifxkJLeSHUPEL29uTiOJJzhAOxVfSjnUehnY9fTwX4fsbtYZo/FeoW0UIb7RBp6W0TMUyQDJ8xGcjcV4wK43UdI0WHxLfPZW+qyW6MTCLqVFkZR3bBIX6Z/OvN5vGGiw4jfV7m6Zc/P5cpQr242/WsS7+IGl2rMtraeeeocI0Tn8d2al1TWEbns0F5pkwJGjwNKfvNJK0rH0+Y8cfgPauosdQSWIX0Gl+TGrANdW8R2Bj90FgDjoeM579xXzM3xN1q5AFuTEi9I/M39e3Pf616Adc+L9xZaV4amu5LbTsf2haW8m2OLMgKl87SckLjnnnp0IlM2ep6/4p+NegQaR4d0aLTLyK7tfOBvJLldjhmJwIQm4Hd6k8YPOcms/iOa7KvI7RxgBiwCnGc8YCjng9fevIYPhx8QI7tJH1fTpyBwv2tdigegKAAD6/r12oPDHjVNxkstLmP8Adt7yLf8AQKXyf89au5i46no1r4gS+vEkeeEiAAKxJwc5+6QD6Dg9ayPFNyPENjDY7Ge2VlZlhnwXIGBkEDoAfz96871NtW0dHe88N3SunLNF8y+nRM+vb8ap2XjXRbkKkl5JaXPeOdSMfQn/AAHWndBbQ9n8GalZ6ZatpmgpbWOoy5IeS6NtO2CDjefvDr8uRnI69K2dX1BrHSba9uo5ftbSFGlnUxSAAkZZ1xu+rqTnueledaVr+prZRxx3KahpcvWOSJZ4pB657H37Z7Vorri3jR287JZpCwMcFvds0YH+yrhio91I9+1VGoloTZnTx67qa+Ybd49TiliCvbSAJOSeu3gLIvqML9PWXwwlx4ZuNQbSLuWyjvISs1sjfJKPTGfccDP4dK502sl1qEc7y3D5JIWVGkU+n3ODjt+NXf7RZPFCy3vmQRNAIhNEWiLFejHsep5HPFOo41I2sFn1PTPh98WLG6kOlahcxLfqSqbn2iQD8AQfavTob1J0DqPlI618v/ELSo305tWikmnmjVDHLbyZlOM4yDjd/P612fwE+Mdv4p01tO1CTbqUD7EZxtEqL3xnr6//AF6+XxWFt7yNGtD3WGbe20Cpd/OKpLE0eGPCtyOeacT3zXjNOOhkaUVyycZJHpU6OW56e1ZqNgBc81bifkA1L7CLo5HWoZBk1JGflIoaPmlYCt5fvTlXaOuKsJEDmnJD1xT0TAh/amG/9rbTU9fBMXP/AG+z1mW9rsYHrjFa/wC0ywb9sOwjPfwNCf8AyoT0QW4BFe1mmlZehENy3YQYUN69a6Czsz8r5wKoadCGK966KGFFiHHNeOnc1RVnjAibntXP3yFl210tygPOcZrGuYgpYZ5xmrT6DMWGASZBA465qlqMQQEYHHNakigPuBwRWDq0jDJ3cZ7da0i+bQDntXvImDx+YqYUklyQBXj3xJ8eS67FJYaRLIlpE5R7kAASdAQvt710/j/xVCRc2EEirIFIeQdEJ6c+vWvFb3VdhbT7JlGCWa4YfcHdsete7hqKS5rFpsSZJbPSLa2hxDNMfMZ1UGR+cEYz+tcxr2oR6VZ+TZEXdxyJFB/dEZxtJxyOevPf1revtTa5upIIAAgjPmTA9AOw/mfQD8/KPEt41nqHlWbvbx4yRAybW9jnLMfT8CSO3qpq2grmek1wZnaUPO8QVm2ptUOvQAZ4xxj121iP4puLeIeTIWkbBMmSVJwBxnk5xnggZzWrc2mpeK2LyborVyC24ZXt27/yHUDDZMCWCWt9Lb2ERuZgpR7mTlVJ9OKG2Vuc5dX91fSmWe4aaY9Eclv0JOP/AK9XbDR43xPe3HkQHorEgsPU4/z61v6J4Se4uZFsj512MfaLp1zHEvPT3/wrWi8LwxSiKIbpv4pOjk+pBPH0JA+vFJ6asahc5W6urCCIRW1lmTOPOlUc/hjPr1rKhW6u5vLELz54EcafMT2HA4+v9M16zafDuKRPMuCZAql3Rxx/Trz144ruNM+HKwweZbW7SeWdsgGAPu7iAxIwfyHXj1ycrmvJZHBeD/Den6X4f1E6nAEnaBwCW25bj5gT29PX8BXsfimVrmPw5EElX+x9O+wiNI8yTyb9xA6kEBV4P3QSeOaw5bNYijNpbLGQdwMileh6qOPXpjvwarTa9/acjOH8lUl3Bos4IHYkZwcZGccbj0zTg0SOi8VvO0LG2vbfIOEeIDH4E1FP4n1iG4Y26zXO/wC6G2gH6jbWMbxjdC2EgaZMiN24jlUknB6kPg//AFqjtdZNneyTFWEaEeZEw5T1OO2DWqYrampeeItVvQgudEidEz8sUmP02+tYWp6ZDqcpafQ5nHVVWMNg+2Pf/DtXpGmavbxx2tyi74JT87FiPLPoeK9C03w9pus6XG8MkCyv3aQr+XXP0479gcJO+hVkfIlt4W8V6fqRbw9pmo2zuzFo0BAkX0ZDw30/St+18dT6ddyWPijRZNOulIWZ4rUrhh1aSFgOR7EDnOOK+hBpqeH9StbyWP7clpdJI9h5uPtKqckBxgIf7uDjocHpXz78bL618QeN9RureWW4tpyWje4TZPGp52SY5DgEA44444Arb2elznOs0a/0PU7qC48O689ncMGZreGQiPG4gDY/zJ/DkDK1pXGp3sVylxqIkllZtpuGYGNye+8dD27dK+cp7OKCYMgdXU5SRXKsP+BD/wDXXd+A9d1e9SSG21rf5ag+SAu5l5+/G+N4HqDnmufUcT0nWp01q0j06V5IYCgZ4kcrub1DDn8qbo3gux0e+a9s7y9t7rO9JITkr67gT8x46nms63nfU0KqTFeRt80XbB6MvfH1rfsr5vK2N1/vE9+xrmqNtWZ0RSZ9EfC7xxD4r0mO3aaKW7hGwyK2Q+O5HZq7pUVvvda+R/AHid9B8cw6kzpBayHNwMnbu7N175PTHSvq3T7mPU7Zbi1lSWF+Q6txXgYqjytNHPUVmXgg7dKmgxvGTgVAv7vjdn8aljcLjaOfVq87S5k2XgSoGe9SBg3eqhZnwC1SxgtzTegrotJhehqUGoE+UVMjYGfWs73YrlT9o+Lzf21rDk8eAIj/AOVCetC1i+bNM/aEti/7ZtjJnj/hA4kx6/8AEwnq/aRfMPQ84r3M2f775DgXNNiw4JrWaRQRlsVnLhBxVW4u+Sc15PMMv3lyoOc8CsW91OJXYnjis++1RgG5/WuW1LUHc4Bxz601Gw0bh1lJGIRNxzjrXK+Kb77BpVzNO5+dcKM9PU/h1p0Ny0T5DfWvCPjz41vfEupQ+G9Pm3woxW4Ktux03ZYexI/GvQw1HmkVZnD6v4xGpahcxWjNJcvKxa47K3Ut/tNz0461X8prsSlSIljTdNczDAX0JPc/ewOPoTitc+HbXw3pMsj7EjKnzLhkBySep5we2O+cZrIu/EVkrGR3aKK2k/dqpy+7GCTk5LHG32wT/Ea+jUeVJGkUzjfEOq32pWrR2YubCw45J2S3DepzyAe6/TnqBT0XwRl4LjUYlj8sARWqr8sQH971I64Ptmunsbc3E/8AaV5brGcn7Lbr1XJ6n1b369Kle8kurryLeHzZ1O1lV9ip/sH09x+vFEnY0UTMuoII3mmWRYLYY2oeAOvI9PftmsiLSzqDtDHE8NlnDTFcGTHXHtz1ruJfDyxL9q1CWN0UZLuAQP8ArmpH6/Tk037JJqQPlRyQWTnCb1O5/fJPH8vSsnKxooXOeIeCBNK0tB50ZwxU5EY/vP6t1z+FdJ4R8LJAFXaJJpVIkkYcjgnj09vrW7ong9rW2aKOIYcgt/eAHJOfbr+Fd5o/hsG1LCNjICqxhBjgCp57msadmcJdaM9izIFLIrkEevBx26/NUCW1zLAkEl6zRRu3CqCrnjJ5PJ4HvXqN14Tur1iEKoowdiR5we+TmqK/DW6uZJC8soXrtzsRvZuf881nc05Tz+2iS0iuHd5bjjCgzFAq9jxx69a89vrXytQkH2qSMyuWDH7wP149fbPvXuc/wxlLh1ZIs9A0TyAjsOTj1rP1j4SJLYs8gM7DnJwPwAA4FONTlJ9kpHjj+YsRhnBaFzyw6n+6w7gg9s0+7szc2quzlrpOrg7d4Hr33Kf5Ve1Xw7daXMYZEIRMlCT29KzYLhLaXP8Aqps/Mc8N6ZrdVOcbpco7QdYFhKbG6B+yXR2A9lY/d/HrXV+E4b6w1WKweSSVCcwvkkHPQgeo9K5HV41u0Z1Ty3P3tvHzeo9TW54J8c29rd2dnryvIq42TR8ucHt/tDj5RyRnFaw1ZhKNkfQsfwm13VNhnhcIsXmbpmCAZ7jJHsOOfauc+MH7PZu9PkuIUlTxJaQCZ0lTKSgDOM/xYA6ccKScgGvsDwL4phs/COmXljcrrGiXVuDbXcQB28d+SCV6evH5cl8RbpfFFk8vyRXSMJFO3aSR2NfSrB81DnR4f1i1blPyL1ZlN/MPL8mVCVdQc4wccnrng9TW14WncyIYmZZIzlXUnIP+FdN8cfDj6D8Tb9YYx9nu2KkBsD5gckfmCD2IrlLLw9PbI0gjFwVIJQcNjn+WP1r56Vo6M9NK7ueuRXTSxQyoDDcKAyyEAYY9T7g4GfbNb4vYrwGfaI5OFkQdA1ea+HdcQSCAsY8jAin+XP0PrXYS3G1lYgLIDwT3Hcdf8jNcczdaGhrES/2exRdnI5BwR9K9Y/Z08ZSOt54cmmM4WMzwu/DgDqp9cE/rXjt2rGH91tlV0BbY3yn1GCeB6e2a1fhhqhtPFVjNBJHBfWlzh2aQh7iFyFwVPBAU5OOpHtXJVScGZzWlz7FiOQMHGKuRsOBWcquUjY9GUNU6cYwa+bkrM4r6l5ZcTbsZq9FKrD0PpWUHXI5qeFsisGxmmnPep422LjNVIRkVKBkdcULcnqbHx/h3/taWjd/+EIjH/k/LUsCYK+1P+PC5/avtOP8AmSo//S6WlRNufevezb+N8i47D5WCxk5rJvD+6JzmtO7GYqx744grxX8QzAvpN4Y5rnZM5OScGt27+42axHYA/Q10FI4r4meM7fwh4Tvb0SP9qI8uBVXPzHuTkdPT3z2r53sSzmOSZVMl0GkyPvH5sg/Q5IA/HvXqP7QbNdvo9gF4ld5GJ6ALt/xrzjVr2PQPOYuqMhKkA7hgDgY6cZ/WvawuiTN4ow/iv4qOiWkAgVWZp1aSNh1K4ZQR35I49utch4fu5by6E+oMD829B2zjv/eHT68c1l+K9Yk1trlpGH3iyn+EHnnPSoYtQ26fthbLFgvXr716cpMuKOo1rxFNFaEoxDs/lQ5PfHJPpjjA9xzXZ+G9Ki8MaeGmb9+w3y/3mJzxnv8A/XPrXlNi8t7r8B8vzbe0A2qTgNKeuT25Br23wf4cm1xmu7tlupCBlI2OyJRntyD+I/TNc8p6HVCNyfR9Dl8Q3qzXykxKQyWo4x1wx556cCu6bw3PcNGhVTHbqEXPAcg/+gj19Sa6bw1oLoxhhBWNvv3DZGR32Yzzg4zzwT6g16p4X8I2trbxFgjBzvMaoSy9sbQOOAP85rLnudEY3PNI/CM1zpjuqKZkQ478njj/AD613HhXRUn0q2nCuXKrvXaPlKkDBz3ypr0fTvDCpKQsZWJz9xzkitiy8LLZMZNiruO9gvdu5/Gk2zohCx54miwDaHidPYEj+dWf7Ptxcn92vyDIJ4Of89q7660WGQlzErj0YdKyJfCgLFo53hB7ADFRzNF+zRxt54fS5fzFQByMnC4/Cs288NrLbshjK7uOBnH4V2l7od7bluFnQdNpOT+FZ8sM3KPFJHLj7rDrWfMx8h4zrvw8hvBvYq2/JwV5H+FeU+KvhW0cckkcYZByQByf/r19VzaMsoKFSrn061j3/gZr1Dkjc3Ho36gj86tTaE4aHwVeWtxot4yF2ktx1BB3D8P89ar3kSTEnop+YEZwSOfzr638Zfs5jW0nktFa3usDDRybgTg9iB/OvEPFXwP8T6B50aaeb9Rgq0TFTj6N/jXRCq7HNOk7Enwa/aY8Q/AidYDBH4h8MyvuutEvJCsbt2licAmOQEDkAjjkHt9KQeJPCfx5itPFfw91i50+5DbbzS9Sx51jJ1ZGIJGOuGHBBHOa+FNf8O67alvO8Nakqx8kiJm/kpH61T0ux8XyRX1lY2d1otheALdQxh7aKYY6v1MhHPBOBnoM17tDMquHi1GWj6HkVMHGbUnE9E+MV3a674/lFhdR6vZ6c7x/bYz+6lmZsvtP8SrgKD3wTjmuKvEkEwuYDiRGB2N91h3H4/0rv/DXg+3u/BcUNhIBe2qsbhP4t3HUemAMHofwrj9XhvdM+YJKBj5h96P8B2+nfjFeZKsqj1Oz2VkV9Mt4Nbk8qOPbdN8r2ky8g+zDv6Yrbt4XOy0njfziN0e9skjoy5/EfnXNWPnTyQTWbCGZW3COSQmNz6ByflP14/Ouyur2fXIYpZ0+z3UQCCV+pcf3/c57dceuagzasXrAQXAOXMbspAkdiw+UE4PoPv8A5im6RpE1n460+dwG3+WjkH3GM++adbzNdW+YJEw/BBbA9cEDnpuyB3zx0rSeVrGaxuZSsnlFNzoMA4AOT79M/SsaivF2MpJtH1Ppd1KsEIkcyHaOTWos4I5rndDuo7/TLW4hbfG8YKtn/P8Ak1swk7Tn0r5qaaepwNF1DWlaRlsH1qhZLygrYhyrKMd6wcbkl2Jdo+lJuCnnvQJQCaie7jB5OKhLUaOp+Oyk/tW2h/6kuMf+T0tAzjk+1S/HFc/tWWX/AGJsf/pbNVOVcYwevP6V72a/xl6FxRJcj90eax78fua0nT90Tk/jWfepmEmvDW6K6HK37kRtg4rFI3d+prX1AfK1ZHTPvXWtRqx4X8cNSEvia0hMwiFtbHIxk5c5z+QH514D411jffG1hADKQNrHJVfqOPX869U+ON3t+I18sbcCOPJ64O0cV4+YJLu7mkkYYJwpABc+oJNe7h1aKOhbHI6jHtR13ZxznnmksfNe2j8oZZWDYx1xnit66sLeGUgInuJHGfyFRWGj3Fxc4BMyj7yrGDj8T/n8cGumcrG0E2zoPCmkyPc2EMXPmZmZ8dRg7f1NfW/wd8JF/mlYvDGdyxkADP4fWvGfBnhIW11p0bqzyCMXE/qSSAqfzP4fjX1p4MsmtLSJAuwE54NcU5Ho04Hf+HdHSNUWZAMdBjIFdZbRRxDavT2AA/QVzml/uSM5HHQ1qR6ii8E5/GkmkdHLY3Y4kPIUe9WCFAHGB6VjR35xy2Kk/tHA+/VORoi5eKqruC81nSgFSAOKSS+3jBbIqBpSe/FQ2iwfjjr7VWmijmUo6BkP8LDipi4qIfXNZsCv/Z9uP+Wa8egqGS3RTjaMVdkYKvWqkrjPpSE0RC3Rz9wGq97pEMikFQxP94A1cWUDqaJJFI5NaJ2IsclqHhHT5syPAhI/2f8ACsLUfh5pGoRBGtY1bqGKD/EcV6BcKAD0NZzJuPSm5eY7Hjuq/Cy0W53GCzfZ/HJFvZR7DAAB/wBrA964fxT4KtGhuY4ULHGXkfDPIeeuOMnpgADJHSvpa4t1mgKOu5euM5rgfF2nR3UEisOeg4qOZ30MHFHwB4209/CuoM8G5bfcdwzkBj0HT/6/HWqdj4nurpY0ZmZSw2rvyyken8vx616x8btCijjuT5e/II9PSvB9BuFh1FYm6yE7TnoR0rtoy5tzz62kz1nwed5YwyZWWFpN2P4t3X6kc1a1HV2iW6t2wGdSsZ9CO3vnpis7wvH5UwVHDoXyoB6cf5/KpZ0825vImHzeblD706u9jOKuj6c+COqLrXw8sJOfNhzCwbtjkY9RyefavRYIG4GPevm/9l3xK8F5e6FLMNpHnQhmxkA4Yf8Ajwr6VsRJn94oGMYArw60dbnnVFZmtZ2wCjjk8mtGNQgHy5qK2iwowcZqwq4GM9q42ZMrSOAT8uM1VdgTVi6XHfNU1XrSW6KSOz+PszL+1hZqrY/4oqMkZ/6fpaNxZRkc1B+0GhP7Wlkf+pJj/wDS2apLGORM7xj0r182/jL0HElZSFJxgVh6ncEBhnArcupsQn1rkdUmyzdq8ZdzTcx9SnUEjuaownzXC8fXFQ3TtK53HmktJvKliPXa2SPUVvF3dh2Pkr4+3cjfGDXo95REaNPplASa4GPTLqSR3tgfs27EbOvJA6n6Vt+J9UXxP8Rdbu5J4Vae9lZmVuCQxUH8lFWbWSOR0hR9yj5uBnqeoHfPHH07ZI+hh7sUdMYmJb6E1zuLBdw6s5xkdyPYV6H4F8HxXN/l923goqAkyEegHUe9c+6x2U+ZGErDKuyDILDk7fUqMDPoePm4Hp3w/sHu3Eg2hjjcyrgE4yD646ckZPJxzgRVlodtKN2egfD7w2tzf/a/LCqdqx8Yyq9D+te2aYixqDgYA4/Ouf8AC2nx2djGoQLtAAH/ANb6g11NugK9CBXJc9KEeVF8ahtAGe3rQt62c5C+5qowGcelReb6ZFTdl2NddRIxmXP4VINTP979Kx2kBH3uacshApq5SRuR3u4feqRb4hvm6Vz6T89cVYFxgfeq/UDbecEAqc017ggVlLcnHrTvtBPanoItyTsw5NV2mUHBPNN84FTwarSMM9KV10GOlnK5wTUP2wnqTSSOD3quR6Gouymi6l1u4bkUxhzx0qCDIHep9oPUUrmfkNdgq/0rndbhSWAv0JODxW5IdzlRwBzWHqwzuPoMimiGj5u+MmgrdRyoE2kqSG65r5M1bT207WAhGCWwBivtz4kWzXsJKjBxg57e9fNvirQIjdr5ke5Ubcrjua6aLakedUXMyroNwLOzSdm2tnZ17mtInzdUnc8Rh0Zx1xnp+pH44rmI5C1lHblSTvVyO+Bk/wBK3NNsrix0/VZ5JS3mqrjJySoYEcfh+tbydzBpo7P4c+fofxe0lZFEf2mdlGW6q6HP5HI+oNfZVvDlgD1r4s8E3Q1b4leH5WlCCYsfLIwEA7D23g/rX2hDMfWvKxGjPMq/EbMD/vFFWJCDwDisuOTGDmpmuBjOc157VxWEuJxGWDdAKpC+iyfmxVPVZypPvxWVgtULcD1349KD+1fZn/qS4/8A0ulp6xhV/wDrU/44Reb+1faD/qS4/wD0ulp83yAKBn3r2M1/jL0LprmMy8UqjVyWpAlmrodQuXy/fBxisO7AcE9j2rxYo2tY5e5A8wgfSqE37hJJGOFCk/kDWpdRYmYCo57YmwucReY+35V9eDXRDSSY1oz4H8Pwre31ypdo4zLI4AOdxLEgY967a00u2tNKkuA4PyFInU53E8ce+O/bnjmuGtgunXs0Sna6zOjf7JL4/rmulsr9hBGzsfsyEbR09myfrmvd5ro6oI1Lm0aO5BI2rwSF+YyHrgDuM5+hwMcCvbPhFok/lmVoztBxx09ePbn9O/NePWFvJr/iSytrcEyEhtw5XPTj8MV9X/Dvwqmn2EQCjDADp/n0rCcrnfThY63TLYwRBWPLc49PatyKE7AAM1PBpsalTjtmtW2tVwCaysdqZjrZuc8ZHpUL2QU9dpPtmuikMVu2MYqCWSEtu3gUJGbbMX7KwHGGFMaMjg8VpTSRhsq2apzzx8knmraKRSMONxzgVAz4OKluL6OPlTWVc3is27dzVlGit0yjA4FPF4WGATn1rn1vWJODU8V4UbLHj3oA3Irlgm3gn1pWndRyKyY78FuCPwqwt2GAyaQGgBmlEWTSWs8crhC23jrVxIAxOetZ6sVyFV20DLHirkdr071ZS1jHOOfelyibMWSDBJI5rE1CMlmA4rtJLZX6D8aw9Xs1j5I5zRaxD1PDPH6m2LPtzGpyxz0r588eQy2LEMqlCSyyKPvDHf6V9XeMNIWe1dAAwcdDXyp8VDJod/PZ3CEQP/qj/dPtTjNpnPOJyHh21S5klnfn5cbfX5TV68uQlqyEbCkS8A888dO9R+Frfybe6w/mIYyynGMcf/X/AEqrcytdXF2ODAxCqFHzADDde3auyL5jjmmeifCjRvtnxD0O5t1DwwW7kswwcgc/rmvrC2l3lsnBBr5v/Zvje1vLsS8pFbxiMk52qWLcfiDX0XDgHj/PFebX1Z5lVamjHISvFLIz7eGNMiOTirOBJjNcVyLGLcSmWTBzmnwlolwK0ZNPjMm4cE1XuIGhfbjipSGerfGld/7WFsOn/FEoc/S+lqK6baFNS/Gxtv7Vdsf+pMj/APS2aq15IBEQTyelermv8ZehdL4WYl/xv96xZW+X1rYvnGwjqaxLyURqc9a8aJuzEd8zyMQePQV1mmeCtYubZLg2TW0PYzEIT6kA9uTVDwnrGn+Hhf61eRLPc2qqLRH+6JGON2O5ABI965vVPjXbatez6fJdXENzMoSG4lUrHu/hxkD0z+dapxv7zPSw2BlXXNfQ+Ivij4TvvAvxE1vTNQtfs9x9reTAbKsjElWU9CMHqKp2cv2jyoW+WPPPvwP8K7z9pHULfWPHVk0ZcyRw+XKz8bifmGPz9a88sEkadCq5xzj09817NOScLl+y9nPlPd/2c/C51rWNR1WWMpDA/kR5H4/1r6r0myb5MHCqMCvKP2ctAex8Gxhl2meZnB9R3r3W2hWKNcLgDgismdC0LUFvlAScAe3bvUF/rtpZZG/cU59M1zWv6xeec6xK6W0fUk4ye3euD1G4kuFG5pAzrkkkD+tOw7tnW6z47jkYyxtsA+8vXgVwGs/GW0tul0cfTr+lZGp6QJosS3M8qHPyEgr+WKw7rRrdIdhRcfTH9KNELU6O1+Mi3SlhJIv1Q/4VdtvigJ2x5rY9xivJ9V8PRrMfI+VRzt64rOhsJLeXfHIc+hqec0v2PdbfxhHd5MZJA681cXVWn+6D+deTaPqEyyAN8rAZzXa2ExnRGUlcjnFVGVwTOthuCy5IqV7gBeRn8ayrJ2KgE5Aqe6fEGcVbZVx02qLbkEnAPoapS+MILdyvmHI681zur3BCuVODmuK1N5POO9iQazchOR6VL8U7SAjbIxx6c1NB8bLN5Ai3Kr7O3P8AKvE7uFpW2qC2frVP/hHJbw4wSO2KjmFe59Lad8T4rmAGOZJRnqr5rodN8aRXUg2nOOvNfL1h4NvoGQpO8a5BwpI/lXX6dDqtocSXBljPAEgyR+PX863i7mTZ9IW2vB3UbsbvfpUl6ouY9hDc8hiMA/SvGdK1O+t/Lc4dACGQk8j/AD7V0Gm63dx5kD/JniMZGD6U3axZu6lYLOHjcbsZrwr49/Dhtd0NrqFA0kSF9wHbrXv0N+moyBhGY5OjAnPNGpaH/aen3Nvsz5qFCD0OawtqS9Ufm/pN7c6VcSWpJbI24PQZGM1euLWS3S4uAdhxuK4BBAH8ueldT8S/CqaN4gjaNDGySNBKMcnnKn8Qf0rlLlJrm/fTolMssygIucYznJx+FaxlY4Jx7H0H8BLAjQob7ezm5iy6tjCkMyjHtgdK9qhkJfGMkdq2P2e/hT4e0L4f6QuuJPJdyISYYp2jUKSWHA69T+eMnGT6X4s+F3hi58PTXvh+4e3vbJA01rLJ5iumccHsa5Kt5bHHPDztzWPKYJtmO5q4t1nHpWWC0MjAjkH1/wA+lTo5I9K47nE9NzUXdJjaKnFuXGWUZ96oWr4I5rSR8qOaqO4r3O2+O0nl/tVWZ6f8UYg/8nJqzrm480Lz0GKm/aJcR/tRWB6f8UhHz/2+TVhS3OMYPTvXo5v/ABl6GlJk9yRtJPpXP6ghcn0xV+5utxOTWbcyl1IFeJfY3uZt1ZfbNFvoFba4Kyrxnlc/414p4oGy/wBh6D/Z4r3nQ7qN7meDdiSSFwvucdK8X8VW5/ttYsAbpF4NU1dn2+StSpyTMHxL4Pj8T+V9pVWvIkxE5H38HOwn+VeWa14Tm0TxA0L/ACFmQqhOepH519Ma3oDSxqImEci/MG9COh/M15J8SW+3eINKlRf3hgLyA9VxgY/PFenTqJKx51aHvto+m/g7YC08IWS42rsGFzx27V3V7KYoDjjjrXO/D2Aw+HbX/d4rob6EyQHHWtkZWOJ1XUvIBMjb9ucCvO/F/je30q3eeaT5OnHUnsAMc/n+ddn4msLiINgZ3dBzxXjfif4ca14hlcw7y7cCZ1ARF9FGcAn16+mKevQNjzvxh8dL6Eyw2EYhuDxHGx8xyfdR938Tn2ryu8+JvxF1q/uIUuBZFPmZNqrge5I5617jpP7PUnhfVYdVVvtswGdsjHBPfoMgn+7yenArj/ij8KNWbxHJqek6dc3VldKGkihj3yRuBzwDyPcenQV6FOnG2qPNryneyPNLnxD48gskuH1qS4gK52wuCxGcbuOcZB7dq7Pwj4p1+G2tZ70/aILpPMjW5UYcZwcOCOePSsLS/ht4gAkSPRL+OWdsNPNF5SoPXLHJxXuGueFYIvCNjo1lYzzfZY1Xeickjq34/wBKc6NNrYilOrF6k2h6tFqIjkVNhOQynqvt0r0zToDcSAKOD3rh/A3hG6GnRi8Qw3ABJXGTjjGffGK9T8LacROVZCQMYrz+XlPRW5dt9MkhhUkZBpb/AE5/s/yrzXo1j4fjubFS8fCjPNVNS0JY4Su3HcUza54b4hh8qJ2x3rzPxDrcdgrTS7m7IqDLMfSvZvFmnP8AvEAwN+PrXl3i/wAD3ctgH0+2e6uiQiqoxsB6t9QBUNX2JerPKLrxv4h1Cd4tM0+KIgEneDI6gdc54rlrL4qePdQknktZ7WCJG581Exj29RX0x4B8IWvhzT5EuLWZZ5FMb5jO4qfp36Gvn3xZ8INc0vWb6Kwsbm/sJJC0E1vEWymScNg8Hnp7V6UKMFG7PLnKq5FaL4++OdHCedbWd5EW2qUTaCfwNdvof7Q07Xqw6zpLWrNgZjbjJ9iK5rQfhXrGrSWFpcaPc21ksyvPLOmOB/CFzkk9K9S8dfBXUPGsyPa2kNjEvQO/zn8fX/DmoqUo2901pym5ana+G/FtrrcKtazA8coWwR+FdnZ3IYqMfKSCQPxrwHwt8IPFnhOVXXfPGpyCOHX244b6V7XoVlqEtvH50L7+CTsx+navOalF2PRPRdDYP5ZAPXNdOF2wmTk+gHWub0KylhQFuc10zrstApqkSz5L/al8PrY6ml9bRbTKcgjpkY6+/WvO/hpoI1zxkly6grAimRumwgY2j3r3L9pyHzdLtlDMmW6r644rE+C/g9tO8G2kskeGu7hrhnbooA2qp9ualszjDmnZnoV58SNT0HQUtrOIHYQkckg4jHfPHfj8qu/DHxzeT+N7W21C4kmt70NCw3cDKnpz0rL8R6Yx0e6+Qf6s8xtx2xXOfCSCf/hLFldSYrVTJk9iBXi1YydTc+gjCn9XnJrZHot42LqVT2anRvuGMVCkZLE9yeasxxEdq6LaH5zPcmSTGOMYq8lzhR8uazxGc1KA2MelJbmaO5/aXfy/2m7DjOfCMY/8nJq5cuVxgGum/aflSD9pXTpH6DwnF/6WTVxI1mJdvyk8V6ubK9ZehcCxM/DNz+NYtxdkHg45p+oayjFgoxXPzXJnk69K8VI6Lkx1GW21OKeBsGJw+D39qq+ONCin1qzvogBDK6OR6CpY4snJ+lbV7F/aXhUZO6W3JZTn8q2jG7Pcyyu6c7HI+JtSkt2ddwJxj/AfrXieu3clzq000hIkchd5yQoznHA74r2L4hQDyY72Ebo3jDYxXM2XhyK98L3BKb5ZmBz6YNaR3PemlyM+jvAx3eG7I9P3YOM+tdlBD5isCevtXG+Dv3elQLnH7lOPwz/Wu0tT8gwe9d1zy7FebSIJG3SIHFYmuJbeWyhMBfSurkG5cetY91oMFym1mZQe4rSLdybHBXt41kAVVCvJO4ZrktV8VQCYZhh5P8KYr0PUvAlrdSMDG+O3NYU/wrtZZC204+tdHvdGTyp9DzW48YqZBGiq2B2BFJFqU10wSOJyxOcdq9Mi+FNlniIZ963tN8AW9tGqrGoqkpdWFrdDh/D2lTtGZJAMlTkYrr9A0Z0uMhQc9q6MaAluAuFAFXbGw8uVWXgLUSsM2NOtmhgjQoeR2FVtctN9mwA6e1dHZwKlspA5PJqlqtvmFiOah7DSPG9Z0RnWEuPMw2eK5rWbG6slWS1Uo3PB6V6rfad5gIXhiec1VfRI502mJX46mpiyrHiL61exkrLwV9F4qZvEjsAHRGBP8Qz/APXr0PV/AUd1uIUKc+lYcvw6Y9SB/wABrXXoxcqRl6VrsAdMwRZB/hXFdRbaxbSvgIsbHvis62+HLEcvj0xwa6DS/AT2u35yQP71NTk9xWRpaLBHcyhmXIPtXTxaHa8Exrn6UmkaOtsgJGCBWuEGB06Vk7DaKH9mWyLgRge9Zd+RArqcfWtq4cBSQcYrmtYfYJGzWZFjxH492B1aCxgU4y4Jbrj8Kw/Bnia+gtl02FxDbQOFjVVxkDgH9B+VeheLNJOuSpgjdEm/B5zXH3nhdtK1qB4lCLOgbg8f55rnmnc2opXdzs9SQXPh69kUFfkG0Y7ZFN8L6OukWRkUBJJc59QDW5pmnBPDziYHMu1F9zmmzsucKMBSVwPauepC+osZifY4dwT3GKq5AA6VOg9qiV8DNSB881GyPjnZEjxjA96if5TinySZx7VVkc7s1CRMjsf2tGK/tE6X/wBivF/6VT15dcXP7vIH3RXtf7RfhDVvGf7Slla6PZm9uYfCUc7xqwBCC7mBYZI7sPzrzHX/AAXqmgOY9Q0y604448+Fhkflj8iete9mdOTqp20sVGyOJkunuZjVm2B8wHrVubTPLY5XPriokh8uQEA/Q14VjpvcupjGQOfSruk3CtK1o2AJxtFVIzu6jFQ3ERUg7sHqD6GrWhvTn7OaY27sBb6ibDUBusZDiJ+wB9qf4j8IJ4OshcQt51gFD5HQDvx7V0+lTjxNpn2eXi4HyhQPm46GuogJktBa3sYlkVNksbHhh3/pXQl1Pp41vaIzfCTZ0exOeRCo+vFdXbyY2iuYtEityIoIzFCpwi+g9K3tPcnnJrVGTldm4jeYAakMZNQWzAAVdDKOTzW0NGAi2bSAYGfanjSdwyVAP0qxbzBcHpirH9pREYwcV0KRNjPGmKDzgU5bZEGcA4qaa5iIyo6etYGq+JIbVSoO7PHBocgsXLmAb85BzU9npkjJv421haXqUuos8qLiINjk13OhYmjIYZ57VnuIuWsI+yKh4wKoajE0cJBHauhTy1XOMbRiszU4/PicrS8ijipIB5hZlzUQjw7YGBirF8WhbHvWPLqhglIPTOKzA2Ft1mAVlzkelTrpsbx7SoA+lUdPv1lDAduK2o8c8/hXRCSQblVNKhXgJ+QqddPWPjbj8KuxlR3A9qk8tZG6g0NjskZUqKnQVRuJHjHyn61tXMIFYt2NjkE8VL1Fa5SurglM9K5jWLoSI67gMetbF3IQWwflrmdSRZZSCMqRyKxkrAYdzcpaWs5ZvnkUpGg5JJ7gewzWdpllLq+o27zIYY7b5cOOn4fh+ldt4f8ADFlcaxHdzuzNgKgYZCfT/Pao5fDk2q6/cW1q4htInZHc9SB0H5YpNJmkdNSWW9jlt5ZYxi0txgDoGbBrkTdgHp16/X61pePdbttHjtdHtJAsUIJbHcnp/KuFXVS+P3nWuKclsfMY2rKdSx1TXqKBwaYb/wBCRWAdTfaAcH3qN9UYDkAVkebzXZ0DagT/AB/nUR1Ik/frnjqO7+PFNe+K453U0tSz7TvZZYv2wpBAiPM3gNNokyFONQbIJAOPrj0r0W38ZWlzdrpmp2N1pd1KRGsd9CPJmYjO1JRmNyRyFyG9gQQPHvHHjO28DftdQ395DLLayeCFgdohkx5v3bdjqeFPA5rW+NfxD03XvAaWmhX8epvfSjDWf71kCHfuGOhBCcn61+hSs1Zq514fCVa7jZaPr0NrUPgv4G1rUdTtJLVoNSd/tJCEx4Vu8YxhkzweDg8HrXgHj34L3/hrxFeWenGXU7VYku0cJhzEzFR8vcgqcleTkccivV/iBrVnr3w58DanezldWcpNFfWlyYrmEmIhyhQ5wWwGQ5B7jIGOj+Enj2bxNb3llrEkNxPZqssGouFBkjOR83bcCOcdQfbJ8qvhMPVl7NaSZ3/UK1PDvEtXinb9Lo+RJLV4ZCmGyOCGGOe4x/n6dKbJbtIASMe1fRXj74a2fjnxnfXGna1YS3At0AhRRvdwWzuYHBH4E+uMc+U+Jvh/rHheYNqNo8VvnAuI1zHn69q+bqYedGTb1SOOpCcEnNWucp4elbTfEVk5JVGfYxPTHevQLmK5l1xGcRtDOdu9foT/AErhXtQSuQTtOQa0D4hntunLNjLEgZx06/WnGWh6OCrJO02dHcRxLeyxxybpEXeV9uP8asWjlHGDgV59oepanP4uFzLhbWRWiYMwJ5+709wK7Rp2hPJyD1pp3Z6MnCT906K1vdvBOasm/wCMZx6cVyyakgPepP7Sz90Zx61qjVRudNHqcZO1m/SoJtTCq21vlHaubuNSJOc7R6Vk3mqhIztbk1aZdjoNS8R+VbsF+UH0auTuL57mQnnB7ZrF1XVS8gCtVrTIZrqHJ654qrmTPbtIs7a10S2TaFV0D5zTZfE9tpsbQJnk/eFeL+M/ibd6BpkbC3ll2oMKvG78e1eW6L8ctZv9SddR0R7a0dyq3UU3mFR7rtFT7RoUYpn1ovixJF2hz9aUeIVPO9jXhUHjAsA0cgkQ9GU8/wD1qlvPHH2O2Msku09lBLE/gAaXN1LSR7cJE1Kb5e1ZPi7SFFmbmOYxmP589jjtXhVt8cHsb7A0+/ZO7hQB+Wc/oK67/hYp8U2clvE7/Op3IwOVHqc1HPd2Bm3pet+Vcj5sk46Guot9fJIAavLIrK4sbZX3lgOuBVvTdXkeT7xBHqa2ehKPXItb+UZO7NTLqqkj5sfSuBh1Yttw3OO9Xk1IhgM8+1TzGqR10uqkdGJrMu7wyg5zzWI2rkcYNL9sEoGGIPpV8xLiOu5SEI7VizOrSMS23jrWq/z/ADE1ieLIJoNOiktUMzl9zRp98qOuB3rKbtqZO0d2bGl2iwlY1BXcAwYjt2q5fyroFndX3ATZhkB5Z+35/wBK42x8TXFxCgMM2B3ZduKytd8QzXX7gOWhXPyE1m52Rx4nERpwtFnI6zfvqeozTu24u2cmo4UBGTSiRPMZvf0pyyBe2a4pK7PmZNtkgzggU0RqTkjPtSswVhUigcVfIyLNDUgBOQuKk+znA4xUiqAQasKoxinylI+uPEvh208U/tZ3+mXwJtbr4eCJ9pw4zqD8qexHUHsQK7v4e/CzT/hza3SW8huZriQyy3jjDEfwoOc4A9+SSfYeYePvHOl+A/2wtNudWvBYW174OSySdo2dRI19IyhscgHafm6DvXQfEv47xeFtYGi2Uqy6oVDtuiJjhUng4yC5x2/wr7aviaeGjzzeyPWweHxmJtQo7S+4p/GLwlomteO/COh2sMlvrWpST3M8tkFTFnFhpXkGCuWcxoGxn5iexr0HTfhvo9pol5pa6dEltPC1u5C/O6EdCxyfp36fj41rnj3xh4S8OHxjItjq8eoOsMl2FXbZRKSEjYDBC7ixz/ePPaui8IftAyGxE+oWUcqgAEWwKt+C9D+YrCWOw0HFvd9T11luY1KNqcuZRdrJ9fQ+cfivomufCrxHFYCWS2lQCez1C2YruTJww9Dxyv554r2T4I/GJPiTC/hvxnbxx6xMojt7jLRw35xwHx0fjOR+HpWf+0L438O/EDw7pc9ql1BeWc7uDcxbXGcZUduoXn2rwuS8mt4Y5kW5tpSTJBNCdrIVbBYH1HH5+1ecuZ4nkp3lCR9s8LHMctSxseSolo/T9D3X4jfDKbw/Je31m6zaXDN5bsu5vIbAOGJHTnqCR64NeU3jBtmflAGOe3t9ff3FfS/wQ+Msfxj8FPFfpC2oWINvqlmQGWZSMK4z0DDOR65FeKfGfwG/gHVluYFP9i3bMIJHbmOQDPlscce3sCO1PF5ZUo+9A/I5xdOTjfY46ylWz1C3nONqNyc12GqYG7ZyoPBFHgr4WPr+nS6vq+of2R4f/wCf5cb5G7qgPX/GtTxpHpSXAOkXL3NkkSxrLKQWYjg5xXnrD1Ix53GyPSwc3zWZyE10UPBzVd9SkVCfTtVW5lwxOenFV2bg8n8KLHup20LbayHQ78r9axdT1DeDj7tLdPg85IrIvGLIck5PQY6UldFt6FqyBv50HJFd7ploIrdRgD8K4LSZ4oJVUsK9BsZy8WTW0F3Mgv8ARrXU4SkyjJ6luRXHal4ItYVaOKJNvYqK7kvVO9jeaMhBk9K0koktM8luvD0kEzJC7RL/AHRSWmjyyy7ZWaTHQk9K7y60R0bKqBnk5pkWhu06yLwP7orn5U2aKLWpg2HgdLy4RnIAHqK73StCttNiAhjVTj65pbTTWjXDNgnn6Vs2g8sIfStFBJ3E3Ip3toXg2sM5HAxXH36GynDqOM4Neh3Lx7SrNjNcL4iUeY+PWlNNkrfUIr5Smd1XrfVyAFz0rlLeYhtpOOa1IsrgjkHrXO2+p0Jm5JJ9qYMZCPYVctJyVCsckVz8cxB4NaNnKcg1d7g9jdSc4wP8/wCf6VuXPgDWtd0KHUdNtmuY48/u4yNxHfv29ua52yBlZVAzk4FfRHgmRdP0aztQAhijGcHnJ5z7Yya7aGFWITTPKxjfKfJupNcQExurKwbaQwPHt1rm50IOW719d+PvhvpPjCwlP2UQaruyt3HgBmPaRehBOOetfMHiHw/caLdTW9xGUaN2RkPUEcZ+lcGKw8sL8WqPn5XZxTvsmbHTNOMu8g1LLZbZyPmwec042iqoySa8++plcr7ipqxAxyOKQwL2zUsYAAGOfWt7h0JVb8akV89qjAwORinLVRJPYP2woIrn9obTIpjiNvC8QPv/AKVOP61wvj/xLLqVv4WvJZHmvhayW07SHa7eU+AW9Mgk+4rr/wBtS8Sx+P8ApUjDP/FMRD063U9fO+rPdajNDDbrJPI27bGmST09AT+Q712ZrTcptJ3v0P2ThelGWAjUfRvU9/8Ahr8fbXwhY3Wh69BDqehXhO6GQjcmfv7Acgqe6nuT079f4R+C88tzLd6VqSweF7xVudM85GeZ4HUEZXjbg5AJOcc45586+C/7KltrWkpr/jpdQ3XEh+z6OZDChiHR5f4zvzuUZXAAPOePrnwFodloOlWemaaZBYWgKQwyOX8pf7oJ7DsO1etl2BlKiliLNI8HNs0p4SrKWW3Unv2+Rz3h34L6VoM5vJo21O8YDa15taNO+VTGM8dTnpxXI/HP4Van4n+x6j4fhSXUIEaKayX92065JDJ0G7k56Z9eK99v5xZWskxjaXYpbYnU47CsQXVtrtilzbuHB5VgeQe/4ivpqEYU/gjsfGvM8TOr7WpO99D4q+EGoa78G/i3bXviHRbvRNK1k/2bd/bEKIoYgxvj2baD/vNX2brWmaVq+kXNtrNpBfaeQXliuEyhwDz7Ec8jn06msjXfDlp4gtJ9M1q3XUNPuUKSwzHh1P079CD2xnNSeI5Y7Dwpc2nmNLHBZmNXc5YhUCgsTyTxz/Lmu7E1I1nF21PJgpKbctj56/aB+KOm/wDCN2+m6bbNbWtsNkFrH8qxLx2x7cV5H8OPHy63Peaa24SPFujDnO4g8nGOODXS/tBXRvraw8+7gsd9urIoUMxB/P09K+Z7bxDJ4S1az1WJxM1uxlCRsfnA4IGcHkflXymNUkrLY9nDaM+krqXaG471UWYscD1qCDWLfWrK3vbNxLa3ESzRuOMgjoR6g5FAkwc+vvXgSVj34u61Lc9vvXPFULq1aKHeqmrkEoGAWyPTNLdzRtAy5z7UkT6HlviDxcfDV/58sckiM2CsQy35Vs6V8c9Fa2CLdhpV4MbZUj65rWuNAg1GQM8SvjoGHSqeqfCbStaiImtgHI3AjsfWqTaLp25tSOf46Wccuwsg9CZV/wARVa4+L04YzRSx7GHGxsmqQ+D2m2Mga6sYLhSpQb1HGepq6nwn8L3pMotQwJztjYKB+FbJNnoKNMv6X8doARFf25k4x8vf60al8bYyDFZWzLF2YsKxbv4IeHZpA8UT2r9mjdgR+tSWHwP0Pzw1xeXcjdAfMPT8T09qPZsbjCxNB8cZYJQJwr5BAVpFWt7SPjpYzP5E0TRsBnerBx+YrGufhZ4XtZCkVllCxb5jk84745HGM+1ZV58H9AuJA8Fp5EmePLOARQ4NanO7I9Cuvidp0lsZBdBT3BfFcu/xHsL+YCK8SRjxgNmsBfgLoywiSaMzuR8u85B9607T4a2em2wVLdVx324rmm5HI1qbOn3wu5TtNdNpxJiwf1rn7Cxjsowq9u9a8EhCgg4qEu5S0NdYwSMACr8Q8pV71lWczSSYbnFaKydCOvPTr0rVIps3NPk8l1kxwvPWvUdD8TMfL2SmPjsa8MuNbSPVIbJXcmJA8qoSApblRx7DP412PhnWA5+Zjx0Br38FFHjYx6HtVlr2ydfPbz9/DD7u4e5/zziqvij4Zad8T7bZHdJp2ox4ZbsjIlTn5ZFyN3s3UCuTtr43ESJuJWNt4z2rtPCc1zDqdubfkSOI3U8q6nsRXrVsPCtG00fP3Z5Fqv7O19p18ljcanp8c8i7oSrO3mehHFcJq/wp8QaPrB019PmluDkoYYzIjD2IHvX25r2sR6NfbVwkjc5z9Of8+lVn8TtIgJCyP/e215ryWjVs4aGcptPY+K9Y+FPibRIBNc6VdeVs3mRIS6Ad8kHjHc1y32JlGSo554OR+FffEniy5VgdoOO3T9O9eU/Ez4TWXieBtQ8P28dlqgP76yX5Em914O0jn659q5cRksoQ5qbuEZ3Z8sSJzxSxwMwOBmvWdO+AXi/V5iseimDGPnmkREI5+6fT8BVXVfgH4z0y48saDc3A/vQJ5y/mpP64rwpYatHRxZtpc679onwND8QP2pNP0+4lkigh8IR3DeVwzYvJhtB7Z3eh6Vt+F/BOkeBEZ9HsfJuWA3Xc7ebORz/EeADnt6dfTS+ICO37XI2Lux4EUnnoPt0nNas9jdl2jmGHXrx1r7qnh6cmqjirndTx2Ip0nQhNqJ5t8Z7/AMaXdrYX3hrWJ7T7CzSyafA4DXjdFyxHIAJGzjNeE237XHxU1z4g6LoukCz0+WC5EEtobdWS+LHB80kZUYGAFIwectgCvqa8h8q4SKYiMMflJB9R+dea6zpngj4YeJ7r4kaxpN1J9mieRxZQiUJMcgSFcjAJOMk4Gcmrrxbh7jLwdSKqWqK9z6EtPFH2iLcWCNnawByuehwe46jPtTfDaJarfeSNpmvJbg4PXecj9MV8SL+1Frsl0yafYW1la5OyN5DNIB/tMev4Y7/hveGv2sdc0XVoJNf061vNGdhHcS2geK4hB/jVixV8H+E4/wBkg9eCGZUObkb1PdnwzjXB1YrTc+xdeu9Qja3W3iSZjIoYscbVJALfgDn8KzfH8Im8KaukJ3M0J6d+O36V5FD+2v8ACC38SXWk6r4hnsL2O8W0g860eSO5DsFWVWUECM5zluma9k1pw8FxDxtaJwQT04/wNepGSmro+ZqUJUHyyVmfI3xh12y8QaDY26B0mtV8vYw4KjGK+YPHFgIIXEW0hyWKqzHI4+bn69ugFfS3xk0ZordLy1jC7OJnUdCMZPv06V4d4i02bVtGLKC0LSlHlCHG7HJIHC8gdffr0PDiqTlE68O0qibIfgZ4yFlE/h67k2ozmW0Zz0Y/eTPYE8j3LDvXsbMT36f5/wAj3r5LiWS3d3XMVxCxKkdVYH/P519LeE9efXNGtrmUgyvGpcjoWxyfrXx70k0z6nEQjR5WupumYjtTo2L8E1X3ZxxU9uPmzml1OVO5s2MCKoOOSK1MYQEdhiqtqoZV+lXFj3YNNglYq3LBMZHHvXKa6Njb0Y8ZwfSuwniO4qV49axL/S2IICbh7U7u1kPmZwB8UajY3OQitjsafD4qvbjBIAJ9Pqa6KTwpcXHzpbkofamp4PuScfZz+ApXki/atbFTT7p3IklJY56A10unSrOwAXAPWq9j4UuYjloWUD2rYs9GkhcP09sUc8nuS5Se5bSKNYwAvTuKpagmYSAM1otAUGCODWffnaOD0pN6CMB8oxB4Oakgchh2pJhlyaIsZqIp3KbNWyby3ZicgCuf+KXxL0/4aeEpNXuSkt3IGWwtHbHnzAZ5A5Kr/EB2IHerOp+ILLw9p019fyeXbRDJ55Y9lA7k18oftBeKLrxpcw3k77X+WK3hX7kK9lHr7k8k5J7V3UqfOzmrVOVHt3wK1O+8QeGLPVtRYzXWos9xJL/fZnYk+w4r6K8Kx+asbYHNeLfCjQm0bwpo1jEoVbS3WLBPUgc/rmvbvC4e3EYPynOa+jw1Kx42IneJ6l4fsoZIWWWLKlDg9MHsa3vDMgtryKdyVjBDOeoAwAT+lYfhq4S9ttqYUhSWB9O9bGizrHNH5pDW7sVfBzkYJP8AL9a9JppHlCeIPGGia546mtNO1mDVNxWKW2trtJF3OMp0JHIDHAJOMcc1txI1pGqK2QO/rXl+o/DrwbLrkN9pnhnStJWG6N9GNNg8hTOVC78IQpO0bcle9dxZ3Py9W2nn5mzitKTsrENdzcWQy9TUBZ4JzKjcdCM062ieZd45HGKV4GkBI7GulamVknobcGpebbbfMwD26YriNX+PvgPRtSuLC98YWFrdwNtkhklZWU+/A5rTmdoXGSV7fX/69eU/EX9n/wAMfETX21m5e+07UJVAuH04qEmYdGII647961pUac3745ydzrfiRd/Z/wBrQJu2mXwKqg8dft0hH8q7LS9f8x7SG8jIfO1jgNvz0Oa8z+OEHn/tW2YVmSVfBkbIVJHP26Wol13UNLlWC/BdR0JBya4KMbwRtqey+JvD9pq+nhSojZc7XX+E+v8AKvIzH9r+16VqsCykEpKjDKzKeM/kSD7Gu/8AB/jeG/RbSdgTjAJP6GoviZ4Lk1KwivrD5LiDDrKg7dx+lOS11HzSWq3PlDXf2XdP0PUZLvTtchsdHkkwkF9yLZmzhFcnhOwycjgEkVzPjj4f+GPCmn3kUniSKTV1XEdltAHX5ufXGRz619ENfWfi7Qr7TLqJZ/Pia2uITwCCCCfb1z2IFfDWteHNc0Txtreia1JJdXtrcbVuXwftEPJjlB/2lxn3Br5TMcNGnH2kY6s/TeH80q4maoVZ7bHlPxZ0y3uI5J1UpKoJU5zj/OBX65+BdeTWvCnhzU1Yst3p1tMecffhRuv1zX5c+M/BWu6muyy0m7vXY7USCFpC57KAoJ5PHTqRX6Lfs1eGNZ8GfA/wdoHiJVi12wsVjukzl4yWLJGxHBZFKqcE4II7V3ZXOcoWlseVxPThGupR3OA+KumyQ3+pWhj81I5Syg8AFuc49RnArwWzhDx3sUk08eHKyLEglVgc/LIp4Zc4zX1h8b9F2anFeRblingJJjOBkfzr5it7dB4/FpJ5MaXKZBlTMbYDfeGQDnHTr6EV7FWN0fKRklY8N1OxOneJL+B2JZZTz655H6EflXd/CrVQLCXS5GIeBsxjphCSV/rWd8WfDb+HPGCgRmGG4iEiRNIHCHJBVSCRtHGP68GuU0PUJNH8SWtwrBFb5W9CK+Mrw5ajPt5yVbCRl2PoGO/2hVY4NadndKzVysUgmjWRTuVhn2qe3u3tmxyy/wB0dRXD1PJTPRrB8gc54rpbKJXjXIzxXmuka0GZV38+hPNdxpepoQozx9ab1Nlsbn2RODtyamtrGN5hlQOD1Wqw1BAvynH40g1goTjnHerSRVkbUjxwWw4GOmKqI8TNh1UE+lc3qPiZYYiA3JrKtvFG6XlmNWx2O+YW8kRwBkdKx5ovyzWPba5LLKSuQKvSXwmiwoKnqfasmrha4ToEjb6Vz9/wdxPFX77UVjVgTk4rlNS1dRu3vx2A61PLYhuw+5lGcAVTkvhGSN2Mc1mT6szDCLgep61gatqYggnkZ8LEpZ2z049KpdDNyueefGzxRPqGt2elRynyo08x1+oIHH4mvLtdim1DUNOtB+8JuEJBHUAgn6cA1vyS3GpalfapcD57lvk3fwoowo9uMfnV34ZaRb6r46aO4UN5VuWj7/OxwD+Wa9/CUtLnmVptux9BeH7y907S7V/IEpYbgM9M/hXpfgrxo1vewm4sJJkGBiJwT+oHtXJ29i1tbQJnew+Vl24x0x+f9K6vwxpXlajE+wE5HGa9mEPM8yrK+h77o8+n3FtHc6eXCmMtJG64K9MD0/KovD8hWOe5EU0se4qqxR72OM4wMj+719M1m3Fy2l6a06DdIIyi45JJ6D/PpWtozf2BY26Mw2rasHcYwWOCf51uzlasUoJy9wcoELclV6CtK3m2nb15/of8a54akA5MfIJyfpWjb6mkf+sHuKuJLR2VtcCS1VY2KEKOR+X9KtROyYHXjmuOj8UWdoRukwx+8uQMVqad4vsZGP7xVA/vPXVG5NjobuNJbcko2cdxisqONrcEsPvdKi1rxPDb7IUDM+N7kLwi9mPoK5zVvFbpJFHbxvcuF3MF7A9D+OD+RrZMloq/FtoV/a7sfNGf+KLTafQ/bpKv6u8Nxm2uwBuzsk9/84qn8WbC31D9rmyjuGZMeC4yjoeQ326WtO50K4NrJA6i4jjOI2z84PY1z4dL2USm9TlWifQb1XGSvByrV634G8TLqdpFazSEkxny8+np/n1ryHUFkt5TGxE23uPSq2j662kXisCQuc5Bxt9a1nFWHdGr8V/Dg8F+Mf7RtYtljenJXsDgcfmM1nXPwi8L/Fa/0mfV3uLe8hT5Lizk2GVM52vnOVzlh3HOOtd942h/4WR4CkUqPtCJuiYf3h/j3+grzz4bavPcaPPbp/yEbCQmNz3P936AgH864JWkrS1NqVWVGfPB2PW7TQdN8MWEWmaPZR2VvDGE8xRukbHcseT1qLT7Y29woJ3sTknnrVmXXbObR49WkdILcqTI0jhVQqcMCSQOCCPzrxzxd+1N8O/CnnzP4ltblkODBZE3EjfQKGzWLnCmuyOpqtiNU22eoeMdFtvEen3WnzEJLEuYZO/0618ofEfwjP4cvrXXYIAZbSYx3Eez5kPr7gn+Ve6fDn49eDvjDp13Jo+qJNPCMTW0ytFcRZ6b42G7twRkHB54o8ZeH4vFOj31lOMTXERCyr8pDrnBroTjUjo7o5nGVN8slZnzD+0V4ZGs+H9M12xQEgBdij7wfrx2wVX868MtdLMlwsjgDAyAetfS3gmaLxX4U8S+DtV3C+tA0EcanEiZ+4V9wVH518+TNJa3FxbXa+RcxStFIhPRwSDj2yDXj4ygpK8UfXZVL2tOVG51vhbUGG62kblDtA9B2reZs555rzKw1lLHVkBcAsCDg9SMV39ldC4i3kYz2zXzNelKlJKXUh6OyJZAytlGIPrWvpXih7RVSbOV/irJc7ulVrlPUZrBS1GeiW/i1JEBDA/jTp/Eyzxld+36GvL0nkgbKMR7UNqs6Z+YmtXMpM7KbW90jJvOBUa6uqHLHiuHfV2RjgMKjOrO3rTcrlXPSLfxCsYDBsf8CqxL4s6FJG+vpXmX9pn1b8KDf+YQMtU3JcjtNQ8TvMzKkp+uazFuy4yzFj61hJJmrKXSqMNn8KDJts05bnYhYc45rzn4k+KY9KtWVTkykAIjYck/0ra8Q+KYdItZWL/d5AJ614reajJ4m1OW+uCWRcwxjsP88VrRpurNIipJRjdmn4b8RWMEX9narN9nSSU+TcMAQuex56DHWvZPhL4Si0vxLrUyzR3VpZz4jukUESKFXCYxyMtj8a+Z9c0TUNTvbS3htZMXVwbeNxyN3Ffang7RD4K8GWWjLsMsEQlnYr99+y+xzyOMcV9jSpckbHgVKl3dHW2GJbkAj2JJGc+n05r03wpp/kzRnhT16A59q8b0Szknm3qBgcDj/P8AkivaPBUksdu80i5Bynl9zjuAeCPrXVCOhyzdy/q1wJ9YtLFZP9uUHGNvYfXIrl/jz8ebT4SeEHupLJtQu5nEMFgnLSEnknjgLgk/gO9dP4atTf3l5qUnymRyikjKgLwpx78mvk79o3UV8X/EK5Bud9rYf6LChbfjGCzZ92J/ALXmZhivqlPTqe3lOXPMa3L9lbnougfH/wAOeKtJSVdZt7G58tHe0v1KyKwHOBkcEcjGcYP1qhe/tC+GdOnaOTxJp64w2VmUFwDhhnOScZwTn7vft8q+KLa1022l3WcF05jdFaVMlNwxke9eItZyKAWGPSry/GyxFPm5dh5ngVgqnKnofoXfftNeDo5JHl8XWokXpJFBuYHnleGC9TkYwST0qjaftVeErWcKmvRSJIQzxw2mBkcbgMYUlcg44OB6V8KadoYaMvK3XoPStG10xLWQurZz6jgfrXdUxNSC0ieNGKlKx+k3gP8AaC8F+JZoNNj8Z2P2u5lCw/bJBFIWY7RGoOMFicDr1xg17p5sfgW1ijls5b+7ui0s8kB43DAwBk4GOAM9jXwj+yR+yzeaprunfEbxNbtaafYSi50qymG2S4lU/LOR2VSQV/vHH8Iwft3VbObU/IDpcIsakqtvvJGf7wXpwARn1rSjVqVFeRNaMYOyLnxS0aXXf2vbeCB9kieBkkBzgf8AH9KB+pFa2n6xcRs0N0FRgT8xHBx1Oe46fmKwPi7420vwP+2Dps2r3sen2174MSzSeY4QSNezFQTjjOG/HjvXc6jHpfie2kFtKkV8ZBIXik+XZz8y8cbuSc+ue9GHqJRUWYPcy/EnhwzWUl5ax4csWOxMH3DDsc5/OvMdWsnWMSOu0Aksw/SvVgt3pc0lvM/nRbgDKwzuY4LIw6b0yB+PU9DzupachuJZSoZZjliTww56jpkf1rt3QFT4d66YZ5dPmbMcvRSevrXJ3sL+BfiW9uzN/ZuoElC3Rd2OP51Leh9G1KO4eIuiN3OCPr7H1o+LcdvrnhO01KM4ktyAkg+9n/a9D0z9RXHJalG1q3iPSbPRNcsNWto7zT7mKR0jkXcryBflXH+2gx+HWvz81jwFbaN4guZ4kgigupDPGltGVjVGJ2qm75sKOMNzX2dbala+JfD1tNOBMqhYbiNfvh1fcrL78EA4PJHrWj4u/Y00fxHYySad4ivLK7CeZbyfZY5IzEfu5jIByAOufwrw8woVazSi9D7jIsfhcHF+3WvofA3h/wCHfxC8WfEK1T4aR3UeuWX7x9QgnFsluhPWSVvlUEgYU9cdDjFfpX8NdC8S2/grTrfxtLYXPiKEMlzLprl4ZcHCvyAdzAZIHAJ4xV74afB3Rvhz4cTSdOgCxMTLczP80tzMfvO7e/YdAOBwK6qSS0tJDGDlk4IxnH/68dO9ephaPsaXKfO5lioYrEOrT2Pin9oM3XwZ+Lun+LLGA/2TqP7q4CnAZuN30ODn8D061S+NHw+t/E+hx+N/DcSTwCESXnkqQ0yYH74KO6/xAc8ZHQ5+qvjV8KNN+KngqbTrp4oLiL57cTZ2Fv8AeHKnjj618u+EdR1z9nfUl0DxHby3Ph24ZvIu0UyRxse4z+RB44rocVpdHLRrzpO8WfIuqX0wutwcpIrB0YHow/i/z7V6v4H8UpqumRMw+cgBh6H0rb/aC+DNnpyN408LSx3nhq8bfOtt832R25DAdPLJ4x1ViR0xXj/gmSXR75xKdsTtgDOcf5/liuPOoU69CM4/Ej0MHKblJPZnuKXRXocCntcCUfezWNZ3f2hQc5yAc1bBwK+BPXJZCCcioH5707dUbc0cwFSdfmPNR7ferEhw3IqFznkCrTugHGPAzmmCTY3Wjccc8VWdvm64p7gXRe4XjrVDUNfSziZmcbh2qG7nZBkHmuQ164cLLI/IUZ64x3/pWkYrYltI5vxlr91r1/FY2+WkuX2J7DufwGT+FYdwXWR7e04hhXccnAAB5JPbr1wa9Y+Cvwc17xxZar4jt7XZFdQva6a938itniSQnsAAwHrzXF+G/B2sal49uPDckL2GpW84Se8gfiOPkSKAMhsqRj64719Ll9BL3jxMXUb0R2X7O/hufVdVuPEmoq8mn2jgQrkZkuQuMjscAnHHU9ete96pfvP+5DKZR/rEVcbmrD08WPh7R7LT9NRBZ2sIW2CKoLMerF1GGUj5jjqW9qtaHA08u9lYyS7m7kn8Meh/LivVcnJ2R552/hKOS6eK0jTNxK33R95QPf056d/wr2byzpmnQ2cMrLdSBY1yc8nPI+nXPtXOfD/w+NDsXuZystwylzvJYkZ+6wz7n8a6OCKaQm9ugfNALIo6he//AAI/yFdUNEZS3N62spdP0hxbWkt3JFExhhiUBp2AyEUnjJ6cnvX56+K9Ril8UalGukXuiXMMxS6tL+UySrLkl855HPYiv0XjvzpOlQqsSeddp5pkB+UIeg6enft6enmvxb+Gnhn4m7rrW9Ct7m+KiP8AtCPMVyig/LiRCCcc9c18/mWEljGlF7H02T5hDAN8ydmfnX4/1NYYVVCMvu4/KvMZiGY8+5xXu3xs/Zu8VeFXutT0a6bxFpEC+ZJCw2XUKDqxA4cDuVyeOmK8++F/w/n+IOr2FlDFJLJfyeVFbwAGWXPACnpnOBnt7YOPdyLLlTpuM3r19Dzc4zH61U5obHOwTefIkVuGmlZgqJGCSWJAAAGcnJHABJ9K+1f2WP2Hp47yDxb8SbQwKSstp4bm6nBJElxg/iIupyN2OFPtX7Pf7E/hT4GzQa/fyt4g8WMC0bXBUw2G7tGi5Uv/ANNOf9ng8++zXiwEeYOPmJB2kkAf3SPx6Zz616Nf2O0NTw4zm+ljN1G3hEagm3hDEKqsBsRR0IHsQMDpkipYtNW+jEbYfyuguA+QDznA6Z5OT1z6AVnXurGaQESLLcuoEYJwiL/tcdumemeO3Oloc7Wtqdr7dx9Mfp2+nbpXPCn1HZvc+U/+Cm1jc6n8bfD1raf6yTQLfPX7v2m6z3968G+F3xg8ffDO9b7LczX+mWjEhJ5DkfT178dK+pP+CjqJ4U+Inhzxiy/bdthb6b9iPydZbl9+/n2429utfEusfGD7PdSeRpJjBJV1+1ZDc/7nvXzNSq4tWZ3wpuWp94/Cb9r/AMNePTYWt/cDSNZAEYs9SwA4HKqD93HmFWyPwr2jUbe0vVkmsZWdCiybGOeMfMwPTk5PPUMK/H/XfFcPiKTedOW3fbgMJd2P0HpXo/ww/ap8bfC218izuv7S0wgeZY3zF0b1APVfwPFehRxqj8Q3Rb2P0Vv7cXdm6TwgA4wepB9j0Bxg1ywtW+x6jp7v5kEvylSPu+/5Zz6dO1eJSft+PO+ybwKkjH5Xb+1fvNj73MJx0rnbn9tv7Tcif/hC9snIbOqZVseo8it/rdNk+xkj0DwZFJp/iC/0W4UqZOcBuVZWLDDemAa+uPgtrMGueAzbXBWK/wBNka1xIfmaLG6LA7rtO3Pqhr82H/aWkj8ZDWo/D4XBYm3N6SGBGMZ2e/pXX+Cv22W8F+OoNW/4Q1byEWzQta/2nsG7lFdW8k4wrEYwc+1YyrU5xbLVKZ+g88/2XTLifaGOWYg8cDtXlvwdvH8SS6jqN/lbe5uiyb+cjkf1x/wGvn/Vv+CiT6xpl1Yp4BEBnV1806yW25GM48gZ78Z71neHv254dBsbW2PgJZorZVGF1bZuxx/zwPrTp4qEY6kPDzufZ3jK40rQdMM+qXtrpNq52pLezLGJB0yM8n8K8T8beHNK8daHfWUF3a+ItEmADm1YOYv9peScj/PGc/nl44+K3jHxz4s1TW9V1+5upruV3SOcl1gQn5UQZwABgcADgcVR8KfEfxL4Euxfadq88VwhLb422k+x6gj2INcix0vaONtD0fqVNUOdP3vwPe7mPWv2b76Sy1ENr/gXUXZTGW3R7DgkdDnjOQMq2Dyetcn8V/hCfDttF4r8OWynwZqbq9ssbMxtFYD75bnbnOM5IJAyetdDpH7WS+LvC9zonjHwZaa9HIqhpra7NqcnneF2OFcNzuXH0rI8C/tIzad4dbwxe6CmqaYkmY0muuiORhCNhDAe459Aa3qzpYiNnoRhqs8PLY57QLySG3RpPnVed3Tp/nOK6xGA46+nPNea614jhsfHFxFpFm9hYTyYFrNP52wd13bQSvoDnHqa6HRfED3Et4qxbI7Zd4UsGJBzxnHt+tfKVsPGGzPenVhU1irHVke1FS+HIP8AhINJivs/Z95I8sjfjHvxW+vhPKxH7Vy77B+76frz1rj5DNyscw656VAIvar/AIrRfDnitNEA8/cgYz/d6/7PP860joK/aRCZc5Utu2/T3q1Azc0c60Rx0qBoA2eimuqutBWAxDzc7/8AZ6frXO+JJV0BEPli43Pt67cfzrWNJsn2tjKubdgG3AEfSvPPEWoW02vWOly21xdQSTobqO1P73yQwLhfcjP4ZreuvHMmpw3kMFr9laMsgJk3qSOhIwPyzXK+DPFcXhW9fWZ7OTU9SdSjyPOETlgBhQpwBzxk16WGoxcrz2OerXurI9l+MnxX0y0sLHwx8JtWv4lmkNrPpTQgRiB4sCNSQSCMsfzOcYzD4W0KD4e+Gv7Pi2z3TnddNOQpebOFVR3iHzZ9evAya8h8EfEez0fUdX1240GO9v7mRfJPn7EtlYHftBU5JGADxjHQ1dvPja+uzROdJ8gxMGjAud2zPJwSmSM+pP5YA9+NSFOLijyZ+8e36MkusMpmhcoBkkDJXJ+6R6e3XIFeweDtAS4lRof9RldyIQY3Az0PXGcZJ9OlfOngT4lixtS50wSSquS/n7cgAkjAXvj+vUV6Mf2p00Wwtrr/AIRUS+e53KNRKnA2lRu8sk445PJwOa1jVgQo32Pp+2mtVeMSPkIoXYox04yfVvf9K2LdLdUN5qimOzi+fAOPlHqe2f6V+dPxS/aI8W/EG+c2V9N4c0tQFjsrSTc3uXkwCxz9K4CLxj4pt7+3nn8T6ndqgIMclzJhlOMqfm6HFZzxUV7pCoykfSHirxv8V7v4h6rHpeuSw6Y8+60mgAEQiGdqhDwGJK59hX094Y8TlNKtLPVSdR1Vo8lgQA5H3mOB8qjI57nA718V+HPjw2nXEJfQo5o0CIqC5K46852k13kP7U8JMzf8ImVmmhEJkXUsbRjJIHldSeTRDEU7leykj6A8SXVhezIkahJ2bfEGPDY98e/9Oc13vg74LeBPg7ftqGgaDb2mqvE0a3BYubdXwWSHcSI15/h9gOMAfFi/tPwJq+l6lc+FGuLewfz/ALEupbI5HBAQn91xtIzjBycV6Y37b/8Aa7GX/hCzFndx/au7sR18kV1vGQpxfKyPYubPqe/142+xjISZPmyevb/PrXOtrFzrYZYwUVgQS3Rec/16d8V88Xn7X/8AaK7B4S8s4O4/2lncvGR/qqv6Z+2PBp1tLHF4ITzJF2721PO0dMAeT0xgYGOlYLGUrlfV5H0RFo6WvmedI9xeNvmO4cEAenXaASQB1AAGSQDK9/cWEpSD7SsJUFRboGIHoR0A9OSeua+XNS/b9e31E6a/gVJUxlGbVeI22BcgeR6E963F/bHMMayQeE3t/M+8seqYHH/bGutY2kjJUmz/2Q==";
//Size : 32.32 KB, 33096 chars
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password); // ingressa com as credenciais na rede wifi (linhas 214 e 215)
WiFi.setSleep(false); // desabilita o modo sleep do wifi, por precaução. Problema é que
Serial.println("Conectando ao WiFi");
while (WiFi.status() != WL_CONNECTED) { // aguarda a conexão wifi ser estabelecida
// Serial.print(".");
nowifi++;
Serial.println(nowifi);
if(nowifi > 3) {
ESP.restart();
// break;
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
config.frame_size = FRAMESIZE_CIF; // UXGA(1600x1200) / SXGA(1280x1024 / XGA(1024x768) / SVGA(800x600) / VGA(640x480) / CIF(352x288) / QVGA(320x240) / QQVGA(160x120)
config.jpeg_quality = 10;
config.fb_count = 1;
esp_err_t err = esp_camera_init(&config); // init cam
if (err != ESP_OK) {
Serial.printf("O início da câmera falhou com erro 0x%x", err);
ESP.restart();
sendphoto();
delay(2000);
void sendphoto() {
HTTPClient http;
http.begin(url);
http.addHeader("Content-Type", "application/json");
DynamicJsonBuffer jsonBuffer;
JsonObject &root = jsonBuffer.createObject();
root["phone"] = "5521999765666";
root["image"] = foto;
root.prettyPrintTo(json_str, sizeof(json_str));
int httpResponseCode = http.POST(json_str);
if (httpResponseCode > 0)
String response = http.getString();
Serial.println(httpResponseCode);
Serial.println(response);
Serial.print("Error on sending POST: ");
http.end();
delay(100);
And the problem is that it doesn't coexist well with camera startup.
If I uncomment the lines that start the camera it gives a memory allocation error. You don't need anything else to give this error, just have two things in the code: This String and the camera configuration must be enabled in the setup.
This is the error that Verbose mode shows:
How do I resolve this ? Anybody know ?
Thanks++
gfvalvo
February 24, 2023, 3:13pm
4
To be sure I understand ... this is the line that causes the "SSL - Memory allocation failed" message?
gfvalvo:
In my understanding, which is almost none, the camera settings consume a lot of memory, so if they were activated and adding that huge String, there is no memory left to work.
I say this because if I comment this line, the error no longer occurs.
When the HttpClient goes to work, it doesn't find enough available memory to handle that large String.
I say this because if the String is small there, even if the cam is enabled in the setup, it also works without giving the error.
== Just an opinion from someone who doesn't know what they're talking about.
gfvalvo
February 24, 2023, 3:36pm
7
Let me rephrase my question. Is this the exact line you're talking about commenting and uncommenting??????
I ask because it's not commented in the code you posted.
Yes, comment this out and the error no longer occurs
ESP.restart();
gfvalvo
February 24, 2023, 3:58pm
9
Guess there's not enough memory to hold the big char array "json_str", the big String "foto" and storage space that the camera functions need and what ever storage is needed by the SSL stuff all at the same time.
Does your ESP32 CAM board have PSRAM? That usual provides about 4MB. If so, I'd start by allocating the space for "json_str" and/or "foto" in PSRAM.
And that. It does have PSRAM. 4Mb.
But what would be the piece of code that makes this allocation for the PSRAM ?
I need to leave now, come back later. See you soon.
gfvalvo
February 24, 2023, 4:24pm
11
For example:
char *json_str = reinterpret_cast<char*>(ps_malloc(34000 * sizeof(char)));
if (json_str == nullptr) {
log_e("PSRAM Allocation Failed");
gfvalvo:
For example:
I went back. Thank you for the code snippet. I kept the char json_str[34000]; up there at the beginning of the code.
And after the HttpClient I put this code snippet.
PSRAM enabled.
And I also put a Serial.print to see the json_str, like this:
Serial.print("json_str é: ");Serial.println(json_str);
It no longer gave that memory allocation error, but the json_str has only {, the rest of it is empty. The root "phone" and the root "image" should appear.
json_str é: {
[D][HTTPClient.cpp:579] sendRequest(): request type: 'POST' redirCount: 0
[V][ssl_client.cpp:59] start_ssl_client(): Free internal heap before TLS 139780
[V][ssl_client.cpp:212] start_ssl_client(): Performing the SSL/TLS handshake...
[V][ssl_client.cpp:233] start_ssl_client(): Verifying peer X.509 certificate...
[V][ssl_client.cpp:242] start_ssl_client(): Certificate verified.
[V][ssl_client.cpp:257] start_ssl_client(): Free internal heap after TLS 99296
[D][HTTPClient.cpp:1146] connect(): connected to api.z-api.io:443
[V][ssl_client.cpp:295] send_ssl_data(): Writing HTTP request with 242 bytes...
[V][ssl_client.cpp:295] send_ssl_data(): Writing HTTP request with 3 bytes...
[V][HTTPClient.cpp:1237] handleHeaderResponse(): RX: 'HTTP/1.1 400 Bad Request'
[V][HTTPClient.cpp:1237] handleHeaderResponse(): RX: 'Date: Fri, 24 Feb 2023 18:54:55 GMT'
[V][HTTPClient.cpp:1237] handleHeaderResponse(): RX: 'Content-Type: application/json;charset=UTF-8'
[V][HTTPClient.cpp:1237] handleHeaderResponse(): RX: 'Content-Length: 272'
[V][HTTPClient.cpp:1237] handleHeaderResponse(): RX: 'Connection: keep-alive'
[V][HTTPClient.cpp:1237] handleHeaderResponse(): RX: 'CF-Cache-Status: DYNAMIC'
[V][HTTPClient.cpp:1237] handleHeaderResponse(): RX: 'Report-To: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=KiSk9qlBDyCqBWflcss%2F0R%2FHTcxIjKl%2FvrkjGsVxTuyuDcBlvaTiJtAGYCbqPylbEGMIAomirddraX9xz8T1mitKNlml59g3T8KXmZfoGe0drO49QlLWTfEFFgIVsg%3D%3D"}],"group":"cf-nel","max_age":604800}'
[V][HTTPClient.cpp:1237] handleHeaderResponse(): RX: 'NEL: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}'
[V][HTTPClient.cpp:1237] handleHeaderResponse(): RX: 'Server: cloudflare'
[V][HTTPClient.cpp:1237] handleHeaderResponse(): RX: 'CF-RAY: 79ea699e6f579ca0-GIG'
[V][HTTPClient.cpp:1237] handleHeaderResponse(): RX: ''
[D][HTTPClient.cpp:1278] handleHeaderResponse(): code: 400
[D][HTTPClient.cpp:1281] handleHeaderResponse(): size: 272
[D][HTTPClient.cpp:624] sendRequest(): sendRequest code=400
[D][HTTPClient.cpp:1415] writeToStreamDataBlock(): connection closed or file end (written: 272).
[D][HTTPClient.cpp:385] disconnect(): tcp keep open for reuse
400
{"error":"Unexpected end-of-input: expected close marker for Object (start marker at [Source: (org.jboss.resteasy.reactive.server.vertx.VertxInputStream); line: 1, column: 1])\n at [Source: (org.jboss.resteasy.reactive.server.vertx.VertxInputStream); line: 2, column: 1]"}
My free trial time on the API ended, but that wouldn't stop showing the correct json_str.
What could I have done wrong ?
gfvalvo
February 24, 2023, 7:08pm
14
No way of knowing. I can't see your new complete code.
Here he is:
#include <WiFi.h>
const char* ssid = "xxxxxxxxxxxx";
const char* password = "yyyyyyyyyyyyyyyy";
int nowifi;
nowifi++;
if(nowifi > 3) {
ESP.restart();
// break;
ESP.restart();
sendphoto();
delay(2000);
void sendphoto() {
HTTPClient http;
http.begin(url);
http.end();
delay(100);
gfvalvo
February 24, 2023, 11:25pm
16
sergioarduino:
Here he is:
I don't know enough about ArduinoJson to advise further. But I can recommend that you get rid of this variable definition as it servers no purpose other than to waste memory:
Trying to help with codes is already too much.
I'll wait, suddenly someone comes along who knows how to solve it and also wants to help.
Thanks
