I'm new at programing and not very good at it.
I know that my program could be written in a much more efficent way, but don't know how I can do that... My problem is memory size! (using an Arduino UNO)
How do I create a function that do the work in my Loop void?
And how do I put together my Strings in a better way?
#include <SD.h>
#include <SPI.h>
File myFile;
#define chipSelect 10
#define X21Pin A0
#define K200Pin A1
#define K330Pin A2
#define Y72Pin A3
#define Y74Pin A4
#define Y25Pin A5
unsigned long X21_F_TRIG;
unsigned long Y25_F_TRIG;
unsigned long K200_F_TRIG;
unsigned long K330_F_TRIG;
unsigned long X21_R_TRIG;
unsigned long Y25_R_TRIG;
unsigned long K200_R_TRIG;
unsigned long TIME_X21_DOWN;
unsigned long TIME_Y25_DOWN;
unsigned long TIME_K200_DOWN;
unsigned long TIME_K330_DOWN;
unsigned long X21_F_FILTERED;
unsigned long Y25_F_FILTERED;
unsigned long K200_F_FILTERED;
unsigned long K330_F_FILTERED;
unsigned long X21_F_FILTERED_OLD;
unsigned long Y25_F_FILTERED_OLD;
unsigned long K200_F_FILTERED_OLD;
unsigned long K330_F_FILTERED_OLD;
unsigned long X21_F_TRIG_DELAYED;
unsigned long Y25_F_TRIG_DELAYED;
unsigned long K200_F_TRIG_DELAYED;
unsigned long K330_F_TRIG_DELAYED;
int delay_ind_print = 150;
int filterTime = 20;
int StartUpTime = 3000;
int no_return = 15000;
int X21_OLD;
int Y25_OLD;
int K200_OLD;
int K330_OLD;
int X21;
int K200;
int K330;
int Y72;
int Y74;
int Y25;
int id = 0;
int init1 = 1;
String SdPrint1;
String SdPrint2;
//String SdPrint3;
String oc="Oc";
pinMode(10, OUTPUT);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Initializing SD card...");
pinMode(chipSelect, OUTPUT);
if (!SD.begin(chipSelect)) {
Serial.println("initialization failed!");
setup();
Serial.println("initialization done.");
pinMode (X21Pin, INPUT);
pinMode (K200Pin, INPUT);
pinMode (K330Pin, INPUT);
pinMode (Y72Pin, INPUT);
pinMode (Y74Pin, INPUT);
X21 = digitalRead(X21Pin);
K200 = digitalRead(K200Pin);
K330 = digitalRead(K330Pin);
Y72 = digitalRead(Y72Pin);
Y74 = digitalRead(Y74Pin);
Y25 = digitalRead(Y25Pin);
X21_F_TRIG = (!X21 && X21_OLD);
X21_F_FILTERED = (!X21 && (millis() - TIME_X21_DOWN) > no_return);
X21_F_TRIG_DELAYED = (X21_F_FILTERED && !X21_F_FILTERED_OLD && (millis() >= StartUpTime));
X21_R_TRIG = (X21 && !X21_OLD && (millis() >= StartUpTime) && (millis() - TIME_X21_DOWN) >= filterTime);
K200_F_TRIG = (!K200 && K200_OLD);
K200_F_FILTERED = (!K200 && (millis() - TIME_K200_DOWN) > delay_ind_print);
K200_F_TRIG_DELAYED = (K200_F_FILTERED && !K200_F_FILTERED_OLD && (millis() >= StartUpTime));
K200_R_TRIG = (K200 && !K200_OLD && (millis() >= StartUpTime) && (millis() - TIME_K200_DOWN) >= filterTime);
K330_F_TRIG = (!K330 && K330_OLD);
K330_F_FILTERED = (!K330 && (millis() - TIME_K330_DOWN) > delay_ind_print);
K330_F_TRIG_DELAYED = (K330_F_FILTERED && !K330_F_FILTERED_OLD && (millis() >= StartUpTime) && (millis() - TIME_K330_DOWN) >= filterTime);
Y25_F_TRIG = (!Y25 && Y25_OLD);
Y25_F_FILTERED = (!Y25 && (millis() - TIME_Y25_DOWN) > no_return);
Y25_F_TRIG_DELAYED = (Y25_F_FILTERED && !Y25_F_FILTERED_OLD && (millis() >= StartUpTime));
Y25_R_TRIG = (Y25 && !Y25_OLD && (millis() >= StartUpTime) && (millis() - TIME_Y25_DOWN) >= filterTime);
if (K330_F_TRIG_DELAYED){
NormalStop();
if (K330){
TIME_K330_DOWN = millis();
if (K200_F_TRIG_DELAYED || K200_R_TRIG){
RemoteShutdown();
if (K200){
TIME_K200_DOWN = millis();
if (X21_F_TRIG_DELAYED || X21_R_TRIG ){
X21Las();
if (X21){
TIME_X21_DOWN = millis();
if (Y25_R_TRIG || Y25_F_TRIG_DELAYED){
RadioBlink();
if (Y25){
TIME_Y25_DOWN = millis();
SdPrint1.remove(0);
SdPrint2.remove(0);
X21_OLD = X21;
Y25_OLD = Y25;
K330_OLD = K330;
K200_OLD = K200;
X21_F_FILTERED_OLD = X21_F_FILTERED;
Y25_F_FILTERED_OLD = Y25_F_FILTERED;
K330_F_FILTERED_OLD = K330_F_FILTERED;
K200_F_FILTERED_OLD = K200_F_FILTERED;
init1 = 0;
void X21Las() {
id++;
if(X21_R_TRIG){
SdPrint1 = int(id) + String(" ; ") + long(TIME_X21_DOWN) + String(" ; ") + String("7") + String(" ; ") + long(millis() - TIME_X21_DOWN) + String(" ; ");
SdPrint2 = String(" X21 OFF ON, DOWNTIME: ") + long(millis() - TIME_X21_DOWN) + String(" TIME OF FALLING EDGE: ") + long(TIME_X21_DOWN);
if(X21_F_TRIG_DELAYED){
SdPrint1 = int(id) + String(" ; ") + long(TIME_X21_DOWN) + String(" ; ") + String("8") + String(" ; ") + long(millis() - TIME_X21_DOWN) + String(" ; ");
SdPrint2 = String(" X21 OFF MORE THAN 15s, TIME OF FALLING EDGE: ") + long(TIME_X21_DOWN);
SdWrite();
void NormalStop(){
id++;
if(Y72 || Y74){
SdPrint1 = int(id) + int(" ; ") + long(TIME_K330_DOWN) + int(" ; ") + int("0") + int(" ; ") + long(millis() - TIME_K330_DOWN) + int(" ; ");
SdPrint2 = String(" NORMAL STOP: ") + String(" WRONG STOP INDICATION Y72: ") + int(Y72) + int(" Y74: ") + int(Y74) + String(" TIME OF FALLING EDGE: ") + long(TIME_K330_DOWN);
if(!Y72 && !Y74){
SdPrint1 = int(id) + String(" ; ") + long(TIME_K330_DOWN) + String(" ; ") + int("1") + int(" ; ") + long(millis() - TIME_K330_DOWN) + int(" ; ");
SdPrint2 = String(" NORMAL STOP") + String(" TIME OF FALLING EDGE: ") + long(TIME_K330_DOWN);
SdWrite();
There is more code in between...
void SdWrite(){
Serial.println(millis());
myFile = SD.open("Log.txt", FILE_WRITE); // open the file.
if(myFile){ // if the file opened okay, write to it:
Serial.print("Writing to Log.txt...");
myFile.print(SdPrint1);
myFile.println(SdPrint2);
// close the file:
myFile.close();
Serial.println("done printing...");
Serial.print(SdPrint1);
Serial.println(SdPrint2);
else {
// if the file didn't open, print an error:
Serial.println("error opening Log.txt");
Logger code.txt (8.9 KB)
