Instead of moving the application code forward another 1k after the bootloader, I've decided to move the config data to the end of the Flash.
So a working proof of concept is like this ...
// code in the Arduino sketch
typedef struct {
byte channel;
byte id;
} config_test;
config_test __attribute__((section (".myBufSection"))) configData[2] ;
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, configData[0].id);
// etc
and definitions in the linker script file
MEMORY
FLASH (rx) : ORIGIN = 0x00000000+0x2000, LENGTH = 0x00040000-0x2000-0x1000 /*-0x400 - First 8KB used by bootloader, last 1k by config data */
RAM (rwx) : ORIGIN = 0x20000000, LENGTH = 0x00008000
CONFIG_DATA (ar) : ORIGIN = 255K, LENGTH = 1K
// etc
SECTIONS
/* placing my named section at given address: */
.myBufBlock 255K :
/* keep my variable even if not referenced */
KEEP(*(.myBufSection))
} > CONFIG_DATA
/* other placements follow here... */
// etc
