I'm in an "out of RAM" situation so I have use PROGMEM for const char arrays (basically these arrays are AT commands for a GSM shield).
My question is about the related PROGMEM tutorial in Arduino Documentation, specifically about this code section:
PROGMEM string demo
How to store a table of strings in program memory (flash),
and retrieve them.
Information summarized from:
http://www.nongnu.org/avr-libc/user-manual/pgmspace.html
Setting up a table (array) of strings in program memory is slightly complicated, but
here is a good template to follow.
Setting up the strings is a two-step process. First, define the strings.
#include <avr/pgmspace.h>
const char string_0[] PROGMEM = "String 0"; // "String 0" etc are strings to store - change to suit.
const char string_1[] PROGMEM = "String 1";
const char string_2[] PROGMEM = "String 2";
const char string_3[] PROGMEM = "String 3";
const char string_4[] PROGMEM = "String 4";
const char string_5[] PROGMEM = "String 5";
// Then set up a table to refer to your strings.
const char *const string_table[] PROGMEM = {string_0, string_1, string_2, string_3, string_4, string_5};
char buffer[30]; // make sure this is large enough for the largest string it must hold
while (!Serial); // wait for serial port to connect. Needed for native USB
Serial.println("OK");
/* Using the string table in program memory requires the use of special functions to retrieve the data.
The strcpy_P function copies a string from program space to a string in RAM ("buffer").
Make sure your receiving string in RAM is large enough to hold whatever
you are retrieving from program space. */
for (int i = 0; i < 6; i++) {
strcpy_P(buffer, (char *)pgm_read_ptr(&(string_table[i]))); // Necessary casts and dereferencing, just copy.
Serial.println(buffer);
If I don't want to use a string_table[] , then e.g. string_0 can be copied to buffer like this?
strcpy_P(buffer, pgm_read_ptr(string_0));
Thanks in advance.
