Memory of JPG after deleting from SD card.
Hello. I'm building a timelapse camera using the Arduino Nano, TTL JPEG camera, and micro sd card module. I am successfully capturing and storing photos at the interval desired. However, the photos being stored seem to have a remnant of a previously stored photo of the same filename. The windows photo viewer will flash the image of a photo that was stored and deleted before displaying the most recent. My code is mostly modified from the Adafruit tutorial for the camera module. I have deduced that the problem is a storage issue on the the Nano itself because the problem persist when I switch cameras, sd cards, and sd modules, but keep the same Nano board. If there's a way to "hard reset" the Nano board to clear left over memory between timelapse sessions, I'm not finding it with a search. Any advice for this newb or link to advice would be greatly appreciated.
#include <Adafruit_VC0706.h>
#include <SPI.h>
#include <SD.h>
#include <SoftwareSerial.h>
#define chipSelect 4
#if ARDUINO >= 100
SoftwareSerial cameraconnection = SoftwareSerial(2, 3);
#else
NewSoftSerial cameraconnection = NewSoftSerial(2, 3);
#endif
Adafruit_VC0706 cam = Adafruit_VC0706(&cameraconnection);
long fileIndex = 0;
int ledIR = 8;
int photoRead = A1;
#if !defined(SOFTWARE_SPI)
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
  if(chipSelect != 53) pinMode(53, OUTPUT); // SS on Mega
#else
  if(chipSelect != 4) pinMode(4, OUTPUT); // SS on Uno, etc.
#endif
#endif
pinMode(ledIR,OUTPUT);
  // Create an image with the name 0000000.JPG
  char filename[13];
  strcpy(filename, "00000000.JPG");
  for (long i = 0; i < 1000000; i++) {
    long value = i;
    for (int pos=7; pos >= 0; pos--) {
      filename[pos] = '0' + value%10;
      value = value/10;
// create if does not exist, do not open existing, write, sync after write
    if (! SD.exists(filename)) {
      fileIndex = i;
    Serial.println("VC0706 Camera snapshot test");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    //don't do anything more:
    return;
  // Try to locate the camera
  if (cam.begin()) {
    Serial.println("Camera Found:");
    Serial.println("No camera found?");
    return;
  // Print out the camera version information (optional)
  char *reply = cam.getVersion();
  if (reply == 0) {
    Serial.print("Failed to get version");
   Serial.println("-----------------");
   Serial.print(reply);
  // Set the picture size - you can choose one of 640x480, 320x240 or 160x120
  // Remember that bigger pictures take longer to transmit!
  //cam.setImageSize(VC0706_640x480);        // biggest
  //cam.setImageSize(VC0706_320x240);        // medium
  cam.setImageSize(VC0706_160x120);          // small
  delay(200);
  cam.setDownsize(0x22);
  // You can read the size back from the camera (optional, but maybe useful?)
  uint8_t imgsize = cam.getImageSize();
  Serial.print("Image size: ");
  //if (imgsize == VC0706_640x480) Serial.println("640x480");
  //if (imgsize == VC0706_320x240) Serial.println("320x240");
  if (imgsize == VC0706_160x120) Serial.println("160x120");
  Serial.println(analogRead(photoRead));
 Serial.println("Snap in 3 secs...");
  delay(2750);
  if(analogRead(photoRead)>500) digitalWrite(ledIR,HIGH);
  delay(250);
  if (! cam.takePicture())
    Serial.println("Failed to snap!");
   Serial.println("Picture taken!");
   digitalWrite(ledIR,LOW);
  char filename[13];
  long value = fileIndex;
    value = value/10;
  fileIndex = (fileIndex+1) % 10000000;
  // Open the file for writing
  File imgFile = SD.open(filename, FILE_WRITE);
  Serial.print(filename);
  // Get the size of the image (frame) taken
 uint16_t jpglen = cam.frameLength();
 // Serial.print("Storing ");
 // Serial.print(jpglen, DEC);
 // Serial.print(" byte image.");
  int32_t time = millis();
  pinMode(8, OUTPUT);
  // Read all the data up to # bytes!
  byte wCount = 0; // For counting # of writes
  while (jpglen > 0) {
    // read 32 bytes at a time;
    uint8_t *buffer;
    uint8_t bytesToRead = min(64, jpglen); // change 32 to 64 for a speedup but may not work with all setups!
    buffer = cam.readPicture(bytesToRead);
    imgFile.write(buffer, bytesToRead);
    if(++wCount >= 64) { // Every 2K, give a little feedback so it doesn't appear locked up
      //Serial.print('.');
      wCount = 0;
    //Serial.print("Read ");  Serial.print(bytesToRead, DEC); Serial.println(" bytes");
    jpglen -= bytesToRead;
  imgFile.close();
  time = millis() - time;
  Serial.flush();
  //Serial.println("done!");
  //Serial.print(time); Serial.println(" ms elapsed");
  //digitalWrite(6, LOW);
If you open the picture on a different computer, does this still happen? I don't think the Nano ever really stores the photos - they'd be way too large, especially for that to happen with multiple photos. It may be your computer having those memory effects? Just conjecture, and I guess it's not too big of a problem if you're getting your photos in the end.
It did not happen when I opened on another computer. Some times its the obvious things that I miss. Thanks, RI4ndom. Much appreciated.
