hi. i have a keypad and lcd code and tried to merge it with my fingerprint and enroll codes i tried tu run it and it returned no error but when i upload it to my project it doesnt work. currently i have to use the serial monitor to display the output and input. i want to use my 4×4 Matrix Keypad for input and 16X2 lcd for display output.
both of the above codes that i merged
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
#include <Keypad.h>
#include <Wire.h> // for I2C LCD
int getFingerprintIDez();
uint8_t getFingerprintEnroll(uint8_t id);
SoftwareSerial mySerial(2, 3);
LiquidCrystal_I2C lcd(0x27, 16, 2);
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keys[ROWS][COLS] =
{{'1','4','*','7'},
{'2','5','0','8'},
{'3','6','#','9'},
{'A','B','D','C'}};
byte rowPins[ROWS] = {
7, 6, 5, 4}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {
11, 10, 9, 8}; //connect to the column pinouts of the keypad
int count=0;
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
lcd.begin();
//pinMode(button, INPUT);
// set the data rate for the sensor lcd port
finger.begin(57600);
if (finger.verifyPassword()) {
lcd.println("Found fingerprint sensor!");
delay(50);
lcd.println("Did not find fingerprint sensor :(");
while (1);
void loop() // run over and over again
lcd.println("For Enrolling Press 1, For Searching Press 2");
delay(50);
char key= keypad.getKey();
while (true) {
while (! Serial.available());
char k = Serial.read();
if (! isdigit(k)) break;
key = k - '0';
if(key == 'A')
lcd.println("Type in the ID # you want to save this finger as...");
uint8_t id = 0;
while (true) {
char c = Serial.read();
if (! isdigit(c)) break;
id *= 10;
id += c - '0';}
lcd.println("Enrolling ID #");
lcd.println(id);
while (! getFingerprintEnroll(id) );
if(key == 'B')
lcd.println("Waiting for valid finger...");
int ret;
do {
ret = getFingerprintIDez();
delay(50);
} while (ret < 0);
//don't ned to run this at full speed.
uint8_t getFingerprintID() {
uint8_t n = finger.getImage();
switch (n) {
case FINGERPRINT_OK:
lcd.println("Image taken");
case FINGERPRINT_NOFINGER:
lcd.println("No finger detected");
return n;
case FINGERPRINT_PACKETRECIEVEERR:
lcd.println("Communication error");
return n;
case FINGERPRINT_IMAGEFAIL:
lcd.println("Imaging error");
return n;
default:
lcd.println("Unknown error");
return n;
// OK success!
n = finger.image2Tz();
switch (n) {
lcd.println("Image converted");
case FINGERPRINT_IMAGEMESS:
lcd.println("Image too messy");
return n;
return n;
case FINGERPRINT_FEATUREFAIL:
lcd.println("Could not find fingerprint features");
return n;
case FINGERPRINT_INVALIDIMAGE:
return n;
default:
return n;
// OK converted!
n = finger.fingerFastSearch();
if (n == FINGERPRINT_OK) {
lcd.println("Found a print match!");
} else if (n == FINGERPRINT_PACKETRECIEVEERR) {
return n;
} else if (n == FINGERPRINT_NOTFOUND) {
lcd.println("Did not find a match");
return n;
return n;
// found a match!
lcd.print("Found ID #"); lcd.print(finger.fingerID);
lcd.print(" with confidence of "); lcd.print(finger.confidence);
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (n != FINGERPRINT_OK) return -1;
// found a match!
lcd.print(" with confidence of "); lcd.println(finger.confidence);
return finger.fingerID;
uint8_t getFingerprintEnroll(uint8_t id) {
uint8_t p = -1;
lcd.println("Waiting for valid finger to enroll");
while (p != FINGERPRINT_OK) {
p = finger.getImage();
switch (p) {
lcd.println(".");
default:
// OK success!
p = finger.image2Tz(1);
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
lcd.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
p = -1;
lcd.println("Place same finger again");
switch (p) {
lcd.print(".");
default:
// OK success!
p = finger.image2Tz(2);
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
p = finger.createModel();
if (p == FINGERPRINT_OK) {
lcd.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
lcd.println("Fingerprints did not match");
return p;
return p;
p = finger.storeModel(id);
lcd.println("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
lcd.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
lcd.println("Error writing to flash");
return p;
return p;
and i have attached the keypad&lcd code and fingerprint&enroll code (combined codes)
thank you
KEYPAD___LCD_FYP.ino (1.09 KB)
COMBINED_CODES.ino (6.94 KB)
