Merging two codes into one
Hey guys, I am relatively new to Arduino and I have two separate working codes and want to merge them into one. So basically I am using an UNO R3 and a NEMA 17 stepper motor. In one code I am controlling the stepper motor with an IR Remote and the second code I am using a hand gesture module to control the motor in the exact same way but I am unsure of how to merge it so I can control the motor with both the IR Remote and with Hand Gestures simultaneously. Please help!
IR Remote Code:
#include "Stepper.h"
#include "IRremote.h"
/*----- Variables, Pins -----*/
#define STEPS  200   // Number of steps per revolution of Internal shaft
int  Steps2Take;  // 2048 = 1 Revolution
int receiver = 5; // Signal Pin of IR receiver to Arduino Digital Pin 6
/*-----( Declare objects )-----*/
// Setup of proper sequencing for Motor Driver Pins
// In1, In2, In3, In4 in the sequence 1-3-2-4
Stepper small_stepper(STEPS, 8, 9, 10, 11);
IRrecv irrecv(receiver);    // create instance of 'irrecv'
decode_results results;     // create instance of 'decode_results'
  irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) // have we received an IR signal?
    switch(results.value)
      case 0xFFE01F: // UP button pressed
                      small_stepper.setSpeed(50); //Max seems to be 700
                      Steps2Take  =  2000;  // Rotate CW
                      small_stepper.step(Steps2Take);
                      delay(2000);
      case 0xFF906F: // DOWN button pressed
                      Steps2Take  =  -2000;  // Rotate CCW
                      delay(2000);
      irrecv.resume(); // receive the next value
}/* --end main loop -- */
Hand Gesture Code:
#include <Stepper.h>
#include "RevEng_PAJ7620.h"
// Create gesture sensor driver object
RevEng_PAJ7620 sensor = RevEng_PAJ7620();
#define STEPS  200
int  Steps2Take;
  Serial.println("PAJ7620 sensor demo: Recognizing all 9 gestures.");
  if( !sensor.begin() )           // return value of 0 == success
    Serial.print("PAJ7620 I2C error - halting");
    while(true) { }
  Serial.println("PAJ7620 init: OK");
  Serial.println("Please input your gestures:");
  Gesture gesture;                  // Gesture is an enum type from RevEng_PAJ7620.h
  gesture = sensor.readGesture();   // Read back current gesture (if any) of type Gesture
  switch (gesture)
    case GES_UP:
        small_stepper.setSpeed(70);
                      delay(2000);
        Serial.print("GES_UP");
    case GES_DOWN:
                      delay(2000);
        Serial.print("GES_DOWN");
    case GES_NONE:
  if( gesture != GES_NONE )
    Serial.print(", Code: ");
    Serial.println(gesture);
  delay(100);
Hello
You are not alone. Take a view here:
Дайте миру шанс!
You’re going to learn some new tricks here.
In both programs you have several delay()s
These are basically incompatible with your ultimate goal.
You’ve heard about millis() timing, now’s a good time to read about it and get cooking.
I didn’t look closely at your code, but there’s a good chance you’ll need to look into states and the switch-case statement.
Sorry is anybody able to put the code together for me? I am still so lost ): After this Uni assessment I'm never touching an arduino again ahhahaha
Wow how to encourage people to do your homework for you!
So basically you are wanting us to cheat for you in order to get a degree. Well speaking as an ex university lecturer, I do hope no one cheats for you as it will contribute to the ever lowering standards we sadly find in higher education today. Be very ashamed of your self.
People here are very willing to help you learn, they are less keen on being taken for a mug.
sorry grumpy mike
