Methods defined in .ccp are not defined in sketch
I am trying to create a library, mostly to test my understanding, prior to starting a larger project where libraries will be useful.
I have a basic class (simple) which has no public data and three public methods.
I'm using the approach suggested by several threads where you develop the sketch, move things to a .h and get it running again, then move the methods from the .h to a .cpp file. The approach seems to separate basic code debugging from library debugging.
Everything works correctly as a single sketch and as a sketch + .h
The functions are declared in the class definition in the .h file.
A pointer to additional reading or a suggestion of why I'm blowing up would be appreciated.
Code, libraries, and errors follow
#include "lib_classtest.h"
class simple tst;
  Serial.begin(9600);  // set the baud rate
  Serial.println(" -- Begin test program, in Setup");
  tst.add();
  tst.printResult();
  tst.setVal(3, -1, -1);
  tst.add();
  tst.printResult();
  Serial.println("All done, long delay");
  delay(10000);
}  // end of LOOP
lib_classtest.h
// Library to use in Class Test
class simple {
public:
  void add();
  void printResult() ;
  void setVal(int, int, int) ;
}; // end class declaration public variables and methods
lib_classtest.cpp
// This is the CPP file for classtest -- it gets all the methods
#include "Arduino.h"
class simple {
private:
  int i = 0;
  int j = 1;
  int k = 2;
  int sum;
public:
  void add() {
    sum = i + j + k;
  }  // End ADD
  void printResult() {
    Serial.print(" Sum = ");
    Serial.println(sum);
  }  // end PrintResult
  void setVal(int l = -1, int m = -1, int n = -1) {
     if (l == -1) {
      Serial.println(" L = -1");
      Serial.println("L <> -1");
      i = l;
    if (m == -1) {
      Serial.println(" M = -1");
      Serial.println(" m <> -1");
      j = m;
    if (n == -1) {
      Serial.println(" N = -1");
      Serial.println(" N <> -1");
      k = n;
  }  // End SetVal
};   // End Class
and errors:
C:\Users\glenn\AppData\Local\Temp\ccIJh9P0.ltrans0.ltrans.o: In function `loop':
C:\Users\glenn\OneDrive\Documents\Arduino\ClassAndLibraryTest/ClassAndLibraryTest.ino:14: undefined reference to `simple::add()'
C:\Users\glenn\OneDrive\Documents\Arduino\ClassAndLibraryTest/ClassAndLibraryTest.ino:16: undefined reference to `simple::printResult()'
C:\Users\glenn\OneDrive\Documents\Arduino\ClassAndLibraryTest/ClassAndLibraryTest.ino:18: undefined reference to `simple::setVal(int, int, int)'
C:\Users\glenn\OneDrive\Documents\Arduino\ClassAndLibraryTest/ClassAndLibraryTest.ino:20: undefined reference to `simple::add()'
C:\Users\glenn\OneDrive\Documents\Arduino\ClassAndLibraryTest/ClassAndLibraryTest.ino:21: undefined reference to `simple::printResult()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
All three files are open in the Arduino IDE (2.3.2 which I think is current)
That's not how you use classes. The following compiles and links with your existing .ino file.
lib_classtest.h
class simple {
public:
  simple();
  void add();
private:
  int i;
  int j;
  int k;
  int sum;
lib_classtest.cpp
simple::simple() {
  i = 0;
  j = 1;
  k = 2;
void simple::add() {
 sum = i + j + k;
}  // End ADD
void simple::printResult() {
void simple::setVal(int l = -1, int m = -1, int n = -1) {
  if (l == -1) {
   i = l;
 if (m == -1) {
   j = m;
 if (n == -1) {
   k = n;
}  // End SetVal
public:
  simple();
@van_der_decken Thanks for the response.
I think you did two things:
You added an #include for the .h and
You added a constructor simple(); to the definitions in .h and used it to initialize the private variables i, j, and k.
Is the constructor a part of the solution?
Regards, Glenn
Look again at the .cpp file. Yours was completely different. If all you can see is that I added a constructor... I wash my hands of this.
OK -- a more careful review shows that you removed the repeat of the class definition from the .cpp and restated the functions as members.
I accept that your solution works. I went back and sorted out the tutorial I was using and see where I misunderstood what was said there.
In any event, thanks for your help in correcting my failed understanding.
Regards,
Glenn
