i bought a MFRC522 and use the rfid-library to control it with an Arduino Nano.
My sketch:
#include <Wire.h>
#include <SPI.h>
#include <MFRC522.h>
#include <U8glib.h>
//RFID-Reader
#define RFID_RST_PIN 9
#define RFID_SS_PIN 10
MFRC522 nfc(RFID_SS_PIN, RFID_RST_PIN);
MFRC522::MIFARE_Key key; //Schlüssel für Schreiben/Lesen von Tag
bool rfid_da; //=1: Tag am Lesegerät, =0: kein Tag am Lesegerät
bool rfid_neu = 1; //=1: ID noch nicht gesendet, =0: ID wurde bereits gesendet
SPI.begin();
nfc.PCD_Init();
for (int i = 0; i < 6; i++) //Schlüssel ist 6 Byte lang
key.keyByte[i] = 0xFF; //Standartschlüssel FF FF FF FF FF FF
Serial.println("Setup beendet");
} //setup ende
long zeit = millis(); //in ms
zeit /= 1000; //in s
checkRFID();
if (rfid_da && rfid_neu) //neues Tag am Leser
Serial.print(zeit/60);Serial.print(" min ");Serial.print(zeit%60);Serial.print(" sec \t");Serial.println("Tag da");
rfid_neu = 0;
if ( ! rfid_da && ! rfid_neu) //Tag von Leser entfernt
Serial.print(zeit/60);Serial.print(" min ");Serial.print(zeit%60);Serial.print(" sec \t");Serial.println("Tag weg");
rfid_neu = 1;
} //loop Ende
void checkRFID() //schaut nach, ob ein Tag in Reichweite ist
bool check[2];
for (int i = 0; i < 2; i++)
check[i] = nfc.PICC_IsNewCardPresent();
if (check[0] == 0 && check[1] == 0) //kein Tag am Leser
rfid_da = 0;
else //Tag am Leser
rfid_da = 1;
// nfc.PCD_AntennaOff(); //Antenne des RFID-Readers ausschalten
// nfc.PCD_AntennaOn(); //Antenne des RFID-Readers anschalten
} //checkRFID Ende
With the function checkRFID i look if a card is at the reader or not. I found out that PICC_IsNewCardPresent() permanent returns 0 if no card is present and if the return switches between 0 and 1 there is a card present. So i save in the variable rfid_da, if a card is present (=1) or not (=0).
My problem: this doesn't work for a long time. If i place a card on the reader i get the message that the card is present. After some time (somtimes 1/2 minute, sometimes 3 minutes, sometimes 10 minutes) I got the message that no card is present and in the next program run the card is present again, but the card was placed the whole time on the reader.
Is there anyone understanding me and my problem ![]()
And is there anyone knowing a reason and a solution?
greetings markus
