I have my clg project on dual axis solar tracking
i have attach two mg995 servo (metal gear) as per schematic
but it behaves badly sometimes and sometimes it works perfectly (rarely)
what will be the reason ??
is my code having a bad execution or any hardware issue ?
Please help
My code :
#include <Servo.h>
// 180 horizontal MAX
Servo horizontal; // horizontal servo
int servoh = 180; // 90; // stand horizontal servo
int servohLimitHigh = 180;
int servohLimitLow = 0;
// 65 degrees MAX
Servo vertical; // vertical servo
int servov = 45; // 90; // stand vertical servo
int servovLimitHigh = 80;
int servovLimitLow = 15;
// LDR pin connections
// name = analogpin;
int ldrlt = 0; //LDR top left - BOTTOM LEFT <--- BDG
int ldrrt = 1; //LDR top rigt - BOTTOM RIGHT
int ldrld = 2; //LDR down left - TOP LEFT
int ldrrd = 3; //ldr down rigt - TOP RIGHT
{ Serial.begin(9600);
// servo connections
// name.attacht(pin);
horizontal.attach(9);
vertical.attach(10);
horizontal.write(180);
vertical.write(45);
delay(3000);
{ int lt = analogRead(ldrlt); // top left
int rt = analogRead(ldrrt); // top right
int ld = analogRead(ldrld); // down left
int rd = analogRead(ldrrd); // down right
// int dtime = analogRead(4)/20; // read potentiometers
// int tol = analogRead(5)/4;
int dtime = 10; int tol = 50;
int avt = (lt + rt) / 2; // average value top
int avd = (ld + rd) / 2; // average value down
int avl = (lt + ld) / 2; // average value left
int avr = (rt + rd) / 2; // average value right
int dvert = avt - avd; // check the diffirence of up and down
int dhoriz = avl - avr;// check the diffirence og left and rigt
/*Serial.print("Bottom Left");
Serial.print(" ");
Serial.print(lt);
Serial.print(" ");
Serial.print("Bottom Right ");
Serial.print(" ");
Serial.print(rt);
Serial.print(" ");
Serial.print("Top Left");
Serial.print(" ");
Serial.print(ld);
Serial.print(" ");
Serial.print("Top Right ");
Serial.print(" ");
Serial.print(rd);
Serial.print(" ");
if (-1*tol > dvert || dvert > tol) // check if the diffirence is in the tolerance else change vertical angle
if (avt > avd)
servov = ++servov;
if (servov > servovLimitHigh)
servov = servovLimitHigh;
else if (avt < avd)
servov= --servov;
if (servov < servovLimitLow)
servov = servovLimitLow;
vertical.write(servov);
if (-1*tol > dhoriz || dhoriz > tol) // check if the diffirence is in the tolerance else change horizontal angle
if (avl > avr)
servoh = --servoh;
if (servoh < servohLimitLow)
servoh = servohLimitLow;
else if (avl < avr)
servoh = ++servoh;
if (servoh > servohLimitHigh)
servoh = servohLimitHigh;
else if (avl = avr)
// nothing
horizontal.write(servoh);
delay(dtime);
Schematic :
About mg995 :
Dimension: 40.7×19.7×42.9mm
Operating voltage range: 4.8 V to 7.2 V
Stall torque: 9.4kg/cm (4.8v); 11kg/cm (6v)
Operating speed: 0.2 s/60º (4.8 V), 0.16 s/60º (6 V)
Rotational degree: 180º
Dead band width: 5 μs
Operating temperature range: 0ºC to +55ºC
Current draw at idle: 10mA
No load operating current draw: 170mA
Current at maximum load: 1200mA
Sorry But i dont have knowledge about voltage and power supply
But i read something like servo require external power supply
{i tried with mobile charger ( 5.0 v and 1 A)}
please suggest me if any changes required in code or in any hardware part
Thank You!!!!!!!!!!!!!!!!!!
Note : SG90 non-metal gear servos also behaves badly sometime with same schematic
Almost all servo issues reported here are power related - yours is no different. Your servos require 4.8 to 7.2 volts and each of them can draw up to 1.2 Amps. The power supply you tried isn't really sufficient for one of them. Ideally, you need something that's six volts and can supply three amps or more.
Please give some details of "behaves badly". What exactly do the servos do that isn't what you wanted and when?
I don't know if this is the only problem but it certainly sounds as though you have too little power. MG995s work best at 6V and need at least 1.5A each, preferably more. Try a separate 6V 3A or 4A power supply and see if that improves things.
Steve
wildbill:
u mean each single servo requires 6 v and 1.5 A current
so i have to connect each servo to each battery seperate
right ?
slipstick:
Steve
behaves badly means
- sometimes it produces long beep like noise
2.sometime it rotate too slow
3.sometime it fluctuate its rotator
4.sometime it vibrate from inside but shaft doesnt rotate
i want to know that ,from my code ,which type of pwm is i am using (soft/hardware)
please let me know !!!
No. One power supply for both servos, 6V, 3A minimum. Don't forget to connect all the grounds.
Simple servo test code you might use to troubleshoot your servo issues using the serial monitor.
// zoomkat 7-30-10 serial servo test
// type servo position 0 to 180 in serial monitor
// for writeMicroseconds, use a value like 1500
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.attach(9);
while (Serial.available()) {
if (Serial.available() >0) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
delay(3);
if (readString.length() >0) {
Serial.println(readString);
int n = readString.toInt();
Serial.println(n);
myservo.writeMicroseconds(n);
//myservo.write(n);
readString="";
zoomkat:
// Powering a servo from the arduino usually DOES NOT WORK.
String readString;
#include <Servo.h>
myservo.attach(9);
delay(3);
Serial.println(n);
//myservo.write(n);
readString="";
Thank You!!!
jremington:
Than You !!!!
'' Don't forget to connect all the grounds.''
yes and also with Uno's ground !!!!!!!
i just google for 6v 3 amp battery but it showing
battery with 3.3 AH !
means it will supply 3.3 A current for 1 hr only
if current in Amp reduces then it will last for more time
i am newbee in electricity , somewhere i read this info about volts amps and AH
Hoping my answer is correct !!!
shivamgokarankar:
Than You !!!!
Maybe. Knowing the Amp hours of the battery is useful, but you also need to know the maximum current it can provide to decide whether it's adequate for your needs.
The power supply must be able to supply the servo stall current, but the servo running current is usually much less.
If you stall a servo for long, it will be likely be destroyed.
Please check the attackment
I have this battery
does this creates any problem to driving those 2 servos??
That close-up picture of a label tells us nothing about what type of battery it is or what current it can provide. A datasheet would be more use but even a picture of the whole battery might give some idea.
I'm guessing it's some sort of lead-acid battery but there loads of different types with different characteristics.
Steve
Extremely Sorry but motor which i have only have this info on that
And i tried this by connecting to my circuit
motor are working fine
Thank You to all who helped me !!!!
