Hi, I am working on developing a speed detector for road safety. I used an Arduino car kit and HB 100 MH ET Live sensor together.
When I upload the code of HB100 and the car together, the HB100 sensor cannot work. The, I tried some troubleshooting that the line pinMode(2, OUTPUT); is the cause of this. HB 100 only works if this coding line is disabled. However, if the line is disabled, my car won't move because that is the coding for the DC motor.
It is weird that one line of coding can make a sensor stopped working.
This is the compiled coding for car to move and for the sensor to work. Thank you for your help.
#include "FreqPeriod.h"
#define in1 5 //L298n Motor Driver pins.
#define in2 6
#define in3 10
#define in4 11
#define LED 13
double lfrq;
long int pp;
int command; //Int to store app command state.
int Speed = 50; // 0 - 255.
int Speedsec;
int buttonState = 0;
int lastButtonState = 0;
int Turnradius = 0; //Set the radius of a turn, 0 - 255 Note:the robot will malfunction if this is higher than int Speed.
int brakeTime = 45;
int brkonoff = 1; //1 for the electronic braking system, 0 for normal.
Serial.begin(9600); //Set the baud rate to your Bluetooth module.
FreqPeriod::begin();
Serial.println("FreqPeriod Library Test");
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(LED, OUTPUT); //Set the LED pin.
pp = FreqPeriod::getPeriod();
if (pp) {
Serial.print ("period: ");
Serial.print(pp);
Serial.print(" 1/16us / frequency: ");
lfrq = 16000400.0 /pp;
Serial.print(lfrq);
Serial.print(" Hz ");
Serial.print(lfrq/19.49);
Serial.println( " km/h ");}
if (Serial.available() > 0) {
command = Serial.read();
Stop(); //Initialize with motors stoped.
switch (command) {
  case 'F':
    forward();
  case 'B':
    back();
  case 'L':
    left();
  case 'R':
    right();
  case 'G':
    forwardleft();
  case 'I':
    forwardright();
  case 'H':
    backleft();
  case 'J':
    backright();
  case '0':
    Speed = 100;
  case '1':
    Speed = 140;
  case '2':
    Speed = 153;
  case '3':
    Speed = 165;
  case '4':
    Speed = 178;
  case '5':
    Speed = 191;
  case '6':
    Speed = 204;
  case '7':
    Speed = 216;
  case '8':
    Speed = 229;
  case '9':
    Speed = 242;
  case 'q':
    Speed = 255;
Speedsec = Turnradius;
if (brkonoff == 1) {
  brakeOn();
  brakeOff();
void forward() {
analogWrite(in1, Speed);
analogWrite(in3, Speed);
void back() {
analogWrite(in2, Speed);
analogWrite(in4, Speed);
void left() {
void right() {
void forwardleft() {
analogWrite(in1, Speedsec);
void forwardright() {
analogWrite(in3, Speedsec);
void backright() {
analogWrite(in4, Speedsec);
void backleft() {
analogWrite(in2, Speedsec);
void Stop() {
analogWrite(in1, 0);
analogWrite(in2, 0);
analogWrite(in3, 0);
analogWrite(in4, 0);
void brakeOn() {
//Here's the future use: an electronic braking system!
// read the pushbutton input pin:
buttonState = command;
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == 'S') {
if (lastButtonState != buttonState) {
digitalWrite(in1, HIGH);
digitalWrite(in2, HIGH);
digitalWrite(in3, HIGH);
digitalWrite(in4, HIGH);
delay(brakeTime);
Stop();
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
void brakeOff() {
