Mi arduino ide no compila los archivos de esp32
tengo un esp32 el cual ya he usado en otras laptops y he subido codigos pero al momentos de querer subir algo en mi lap me salen estos errores
FQBN: esp32:esp32:esp32
Using board 'esp32' from platform in folder: C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0
Using core 'esp32' from platform in folder: C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0
cmd /c if exist "C:\\Users\\DELL\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202542-3572-xw6bqv.3z7q\\sketch_may2a\\partitions.csv" COPY /y "C:\\Users\\DELL\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202542-3572-xw6bqv.3z7q\\sketch_may2a\\partitions.csv" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino\\sketches\\9D0B7419DADE5E119BF30DEF74C17CBA\\partitions.csv"
cmd /c if not exist "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino\\sketches\\9D0B7419DADE5E119BF30DEF74C17CBA\\partitions.csv" if exist "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32\\partitions.csv" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino\\sketches\\9D0B7419DADE5E119BF30DEF74C17CBA\\partitions.csv"
cmd /c if not exist "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino\\sketches\\9D0B7419DADE5E119BF30DEF74C17CBA\\partitions.csv" COPY "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\tools\\partitions\\default.csv" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino\\sketches\\9D0B7419DADE5E119BF30DEF74C17CBA\\partitions.csv"
        1 archivo(s) copiado(s).
cmd /c IF EXIST "C:\\Users\\DELL\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202542-3572-xw6bqv.3z7q\\sketch_may2a\\bootloader.bin" ( COPY /y "C:\\Users\\DELL\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202542-3572-xw6bqv.3z7q\\sketch_may2a\\bootloader.bin" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino\\sketches\\9D0B7419DADE5E119BF30DEF74C17CBA\\sketch_may2a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.2.0\\variants\\esp32\\bootloader.bin" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino\\sketches\\9D0B7419DADE5E119BF30DEF74C17CBA\\sketch_may2a.ino.bootloader.bin" ) ELSE ( "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.9.dev3\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino\\sketches\\9D0B7419DADE5E119BF30DEF74C17CBA\\sketch_may2a.ino.bootloader.bin" "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32\\bin\\bootloader_qio_80m.elf" ) )
Traceback (most recent call last):
  File "esptool.py", line 37, in <module>
  File "esptool\__init__.py", line 1325, in _main
  File "esptool\__init__.py", line 1071, in main
  File "esptool\cmds.py", line 1075, in elf2image
  File "esptool\bin_image.py", line 1209, in __init__
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.4-2f7dcd86-v1\\esp32\\bin\\bootloader_qio_80m.elf'
[3516] Failed to execute script 'esptool' due to unhandled exception!
esptool.py v4.8.1
exit status 1
Compilation error: exit status 1
Su publicacion se MUEVE a su ubicacion actual ya que es mas adecuada.
Reinstala el core del ESP32, parece como que esta corrupto.
Versión 2.0.14 o similar en lugar de la versión 3.X que tiene cambios notorios.
