Can someone please give me the code to make a micro servo 9g A0090 motor spin pweeaaaasseee please
Look at the servo library examples in the IDE
Spin? As in, rotate?
It's not a continuous rotation servo....
Very basic servo control code using the serial monitor.
//zoomkat 7-30-10 serial servo test
//type servo position 0 to 180 in serial monitor
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.attach(9);
Serial.println("servo-test"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the String readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured String
int n = readString.toInt(); //convert readString into a number
myservo.write(n);
readString="";
thnx zoomkat but how should i create the curcuit
Below is a typical servo powering setup.
