johnwasser:
Why use intervals of 4 microseconds when you can use intervals of 1/16th microsecond? Connect your signal to Pin 8 and this sketch will give you periods, duty-cycle, and frequency:
// Measures the HIGH width, LOW width, frequency and duty-cycle of a pulse train
// on Arduino UNO Pin 8 (ICP1 pin).
// Note: Since this uses Timer1, Pin 9 and Pin 10 can't be used for
// analogWrite().
while (!Serial);
// For testing, uncomment one of these lines and connect
// Pin 3 or Pin 5 to Pin 8
// analogWrite(3, 64); // Pin 3: 512.00, 1528.00, 2040.00, 25.10%, 490.20 Hz
// analogWrite(5, 64); // Pin 5: 260.00, 764.00, 1024.00, 25.39%, 976.56 Hz
noInterrupts (); // protected code
// reset Timer 1
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
TIMSK1 = 0;
TIFR1 |= (1 << ICF1); // clear Input Capture Flag so we don't get a bogus interrupt
TIFR1 |= (1 << TOV1); // clear Overflow Flag so we don't get a bogus interrupt
TCCR1B = _BV(CS10) | // start Timer 1, no prescaler
_BV(ICES1); // Input Capture Edge Select (1=Rising, 0=Falling)
TIMSK1 |= _BV(ICIE1); // Enable Timer 1 Input Capture Interrupt
TIMSK1 |= _BV(TOIE1); // Enable Timer 1 Overflow Interrupt
interrupts ();
volatile uint32_t PulseHighTime = 0;
volatile uint32_t PulseLowTime = 0;
volatile uint16_t Overflows = 0;
ISR(TIMER1_OVF_vect)
Overflows++;
ISR(TIMER1_CAPT_vect)
static uint32_t firstRisingEdgeTime = 0;
static uint32_t fallingEdgeTime = 0;
static uint32_t secondRisingEdgeTime = 0;
uint16_t overflows = Overflows;
// If an overflow happened but has not been handled yet
// and the timer count was close to zero, count the
// overflow as part of this time.
if ((TIFR1 & _BV(TOV1)) && ICR1 < 1024)
overflows++;
if (PulseLowTime == 0)
if (TCCR1B & _BV(ICES1))
// Interrupted on Rising Edge
if (firstRisingEdgeTime) // Already have the first rising edge...
// ... so this is the second rising edge, ending the low part
// of the cycle.
secondRisingEdgeTime = overflows;
secondRisingEdgeTime = (secondRisingEdgeTime << 16) | ICR1;
PulseLowTime = secondRisingEdgeTime - fallingEdgeTime;
firstRisingEdgeTime = overflows;
firstRisingEdgeTime = (firstRisingEdgeTime << 16) | ICR1;
TCCR1B &= ~_BV(ICES1); // Switch to Falling Edge
// Interrupted on Falling Edge
fallingEdgeTime = overflows;
fallingEdgeTime = (fallingEdgeTime << 16) | ICR1;
TCCR1B |= _BV(ICES1); // Switch to Rising Edge
PulseHighTime = fallingEdgeTime - firstRisingEdgeTime;
noInterrupts();
uint32_t pulseHighTime = PulseHighTime;
uint32_t pulseLowTime = PulseLowTime;
interrupts();
// If a sample has been measured
if (pulseLowTime)
// Display the pulse length in microseconds
Serial.print("High time (microseconds): ");
Serial.println(pulseHighTime / 16.0, 2);
Serial.print("Low time (microseconds): ");
Serial.println(pulseLowTime / 16.0, 2);
uint32_t cycleTime = pulseHighTime + pulseLowTime;
Serial.print("Cycle time (microseconds): ");
Serial.println(cycleTime / 16.0, 2);
float dutyCycle = pulseHighTime / (float)cycleTime;
Serial.print("Duty cycle (%): ");
Serial.println(dutyCycle * 100.0, 2);
float frequency = (float)F_CPU / cycleTime;
Serial.print("Frequency (Hz): ");
Serial.println(frequency, 2);
delay(1000); // Slow down output
// Request another sample
noInterrupts();
PulseLowTime = 0;
interrupts();
Your code works flawlessly and it's so precise. Now I'll try to understand how it works. Thank you so much!
