" MIDI.sendProgramChange(10, 1); " is transmitted auto in code
i am so sorry to repeat my question . i don't want waste your costly time . but i have to do so for edit topic title to get best solution from expert.
please look at this part of code
    int val = analogRead(0);
                if (CC_Mode =="ON")  { SLIDE1 =   map(val,100,950,1,22);  }
              if (val<100) {  SLIDE1=0;  }
              if (val>950) {  SLIDE1=23;  }
              if  (SLIDE1 !=SLIDE1_OLD) {
                if  ((SLIDE1>0) && (SLIDE1<23))
                  for (int ch=0; ch<16; ch++)  {  MIDI.sendNoteOff(Last_Note,0,ch); }
                     int New_Note = White_Note [SLIDE1-1] ;  // TRANS_KEY MISSING
                      MIDI.sendProgramChange(78, 1);
                  for (int ch=0; ch<16; ch++)  {  MIDI.sendNoteOn(New_Note,127,ch);  }
                    Last_Note = New_Note;
                    for (int ch=0; ch<16; ch++) {  MIDI.sendControlChange(120,0,ch);  }
                    for (int ch=0; ch<16; ch++)   {   MIDI.sendControlChange(123,0,ch);  }
                       MIDI.sendProgramChange(PATCH, 1);
           SLD_SCN (SLIDE1);
                SLIDE1_OLD = SLIDE1;
here i wrote in 11th line MIDI.sendProgramChange(78, 1); if i don't do so
current selected patch will be ignored & all Notes will be played on patch no.11 .
Ques:
i wrote in 29th line MIDI.sendProgramChange(PATCH, 1); here my int "PATCH" is not equal to 10, "PATCH" changed is assigned from another button inputs . but i am getting command MIDI.sendProgramChange(10, 1); Automatic after running this function
instead of MIDI.sendProgramChange(PATCH, 1); please how it is occur????
in fact i am useing this funtion
to stop any playing note or voice in last.
Q1: is this funtion is my problem ??
Q2: if yes can i use another function to do so ??
Function MIDI.sendProgramChange(10, 1); is occured only when slide Pot connected to A0 is moved And "SLIDE1" is changed to 0 or 23.
I seemed you can find any missing in above code.
if you don't see missing in above code ,you can also read my full code . sorry for lenthy code.
#include <RH_ASK.h>
#include <MIDI.h>
#include <Keypad.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include<EEPROM.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET     -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define NUMFLAKES     10 // Number of snowflakes in the animation example  -96,-97,-98,-99
#define KEY_UP    -115
#define KEY_DOWN  -113
#define KEY_ZERO  -114
#define KEY_FIND_SCN  -110
#define A    -106
#define B    -107
#define C    -109
#define D    -108
#define AA    -96
#define BB    -97
#define CC    -98
#define DD    -99
#define PATCH_UP    -126
#define PATCH_DOWN  -127
#define MONO        -125
#define POLY        -124
#define DRUM        -116
#define KEY_128     -128
#define ORANGE_A    -123
#define ORANGE_B    -122
#define BLUE_A      -121
#define BLUE_B      -120
#define Bank_WriteA      -119
#define Bank_WriteB      -118
#define Key_Mode_Sw    -117
char *data;    //  RF
const byte ROWS = 16;
const byte COLS = 10;
char keys[ROWS][COLS] = {
{1,2,3,4,5,6,7,8,9,10},
{11,12,13,14,15,16,17,18,19,20},
{21,22,23,24,25,26,27,28,29,30},
{31,32,33,34,35,36,37,38,39,40},
{41,42,43,44,45,46,47,48,49,50},
{51,52,53,54,55,56,57,58,59,60},
{61,62,63,64,65,66,67,68,69,70},
{71,72,73,74,75,76,77,78,79,80},
{81,82,83,84,85,86,87,88,89,90},
{91,92,93,94,95,96,97,98,99,100},
{101,102,103,104,105,106,107,108,109,110},
{111,112,113,114,115,116,117,118,119,120},
{121,122,123,124,125,126,127,128,129,130},
{131,132,133,134,135,136,137,138,139,140},
{141,142,143,144,145,146,147,148,149,150},
{151,152,153,154,155,156,157,158,159,160}
byte rowPins[ROWS] = {4,5,6,7,8,9,10,11,12,14,15,16,17,22,23,24};
byte colPins[COLS] = {32,33,34,35,36,37,38,39,40,41};
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
String msg;
MIDI_CREATE_DEFAULT_INSTANCE();
       byte sysexArray[8] = {0xF0,0x7F,0x7F,0x04,0x04,0x00,50,0xF7}; // 0x28         // byte sysexArray[8] = {0xF0, 0x7F, 0x7F, 0x04, 0x04, 0x0, 0x50, 0xF7};   //   MIDI.sendSysEx(8, sysexArray, true);
  byte User[8] = {0xB0,0x00,0x55,0x90,0x20,0x00,0xC0,0x00};
  RH_ASK driver(2000, 2, A1, 5); // ESP8266 or ESP32: do not use pin 11  rx_2 ,tx_A1
   int UP = 0;
   int DOWN = 0;
  int Bank = 61;
  String  Key_Mode;
  String  CC_Mode;
  int PATCH = 0;
 int SHIFT1 = 0;
 long COUNT = 0;
 int  TRANS_KEY = 0;
 int  TRANS_KEY_Old = 0;
 int KEY_SHIFT_MODE = 0;
 int NOTE_NUMBER = 0;
 int RAG_NOTE[15] = {49,51,52,54,56,57,59,61,63,64,66,68,69,71,73 };
 int Bells_DRBR[22] = {61,63,64,66,68,69,71,73,75,76,78,80,81,83,85,87,88,90,92,93,95,97 }; // 22 notes
 int White_Note [] = { 48,50,52,53,55,57,59,60,62,64,65,67,69,71,72,74,76,77,79,81,83,84 };
  int last_val = 0;
 int SLIDE1 = 0;
 int SLIDE1_OLD = 0;
 int Last_Note = 0;
 int Pitch_Value = 0;
 byte C_Status = 0;
 byte D_Status = 0;
 byte Last_Gear = 0;
 int   my_value = 0;
 int AAA[128];
int data = 1;
         if (!driver.init())
         Serial.println("init failed");
  for (int i = 1; i < 128 + 1; i++)  {
    AAA[i]=0 ; }
    pinMode(LED_BUILTIN, OUTPUT);
     kpd.setHoldTime(1000);
    MIDI.begin(4);
     MIDI.turnThruOff();
     digitalWrite(13,LOW);
    if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
 display.display();
 display.clearDisplay();
    msg = "";
    Key_Mode="Bank";
    CC_Mode =="OFF";
  WEL_COME_SCN ();
  AAA[i] = EEPROM.read(i);
 MAIN_SCN ();
void SCN (int gg) {
  display.setTextSize(1);             // Normal 1:1 pixel scale
  display.setTextColor(SSD1306_WHITE);        // Draw white text
  display.setCursor(0,0);             // Start at top-left corner
  display.println(gg);
  display.setCursor(50,0);             // Start at top-left corner
  display.println(msg);
  display.setCursor(0,16);             // Start at top-left corner
  display.println(analogRead(A0));
  display.display();
               //   Serial.println(SLIDE1);
           SLD_SCN (SLIDE1);
    if (kpd.getKeys())
        for (int i=0; i<LIST_MAX; i++)
        {      int mykey = kpd.key[i].kchar;
            if (( kpd.key[i].stateChanged ) && (mykey < 128 )  &&  (mykey > 0 ) && (mykey != 13))
                switch (kpd.key[i].kstate) {
                    case PRESSED:
         if     (Key_Mode == "Perform")        {      Perform_Mode (mykey);  MAIN_SCN ();    }
        else if (Key_Mode == "Bank")        {   Bank_Mode (mykey); }      MAIN_SCN ();
                    case RELEASED:
                  //   if     (Key_Mode == "Perform")        {      Perform_Mode_Released (mykey);  MAIN_SCN ();    }
                   if (Key_Mode == "Bank")        {   Bank_Mode_Released (mykey); }      MAIN_SCN ();
                  if (( kpd.key[i].stateChanged ) && (mykey == KEY_128)) // --------------------------------------
            {  switch (kpd.key[i].kstate) {
                    case PRESSED:
                     if     (Key_Mode == "Perform")  { PATCH = 127;     MIDI.sendProgramChange(PATCH, 1);       MAIN_SCN (); }
               if (( kpd.key[i].stateChanged ) && (mykey == PATCH_UP)) // --------------------------------------
                    case PRESSED:
                    PATCH++;    MIDI.sendProgramChange(PATCH, 1);   MAIN_SCN ();
                    if (DOWN==1) {PATCH = PATCH+10;    MIDI.sendProgramChange(PATCH, 1);   MAIN_SCN (); }       UP = 1;
                 case HOLD:               break;
                  case RELEASED:     UP = 0;              break;
                if (( kpd.key[i].stateChanged ) && (mykey == PATCH_DOWN)) // --------------------------------------
                    case PRESSED:
                    PATCH--;    MIDI.sendProgramChange(PATCH, 1);   MAIN_SCN ();
                     if (UP==1) {PATCH = PATCH-10;     MIDI.sendProgramChange(PATCH, 1);   MAIN_SCN (); }   DOWN = 1;
                  case HOLD:                break;
                  case RELEASED:     DOWN = 0;              break;
             if (( kpd.key[i].stateChanged ) && (mykey == KEY_FIND_SCN)) // --------------------------------------
                    case PRESSED:
                    FIND_SCN ();
                    KEY_SHIFT_MODE = 1;
                    case RELEASED:
                     KEY_SHIFT_MODE = 0;
                     All_Note_Off ();                  MIDI.sendProgramChange(PATCH, 1);     MAIN_SCN ();
              if (( kpd.key[i].stateChanged ) && (mykey == KEY_UP)) // --------------------------------------
                    case PRESSED:
                    TRANS_KEY++;  MAIN_SCN ();
                if (( kpd.key[i].stateChanged ) && (mykey == KEY_DOWN)) // --------------------------------------
                    case PRESSED:
                    TRANS_KEY--;   MAIN_SCN ();      data = 31;
                    if (( kpd.key[i].stateChanged ) && ((mykey == KEY_ZERO) || (mykey == -112) || (mykey == -111))) // --------------------------------------
                    case PRESSED:
                    TRANS_KEY = 0;
                    MAIN_SCN ();
              if (( kpd.key[i].stateChanged ) && (mykey == A)) // --------------------------------------
                    case PRESSED:
                     data = 11;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent();
                 case HOLD:
                data = 13;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent();
                 case RELEASED:
                data = 12;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent();
              if (( kpd.key[i].stateChanged ) && (mykey == B)) // --------------------------------------
                    case PRESSED:
               data = 21;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent();
                 case HOLD:
               data = 23;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent();
                 case RELEASED:
               data = 22;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent();
                if (( kpd.key[i].stateChanged ) && (mykey == C)) // --------------------------------------
                    case PRESSED:
              if (D_Status==0)  {  data = 31;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent(); Last_Gear = 31;}
              if (D_Status==1)  {  data = 10;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent(); } // Speeed  full
                  C_Status = 1;
                 case HOLD:
          //     data = 33;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent();
                 case RELEASED:
                if (D_Status==0)  {  data = 32;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent();   }
              if (D_Status==1)  {  data = 5;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent(); } // Speed  LOW
                C_Status = 0;
                   if (( kpd.key[i].stateChanged ) && (mykey == D)) // --------------------------------------
                    case PRESSED:    //41
              if (C_Status==0)  {  data = 41;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent(); Last_Gear = 41;}
              if (C_Status==1)  {  data = 10;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent(); } // Speeed  full
               D_Status = 1;
                 case HOLD:
            //   data = 43;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent();
                 case RELEASED:   // 42
                  if (C_Status==0)  {  data = 42;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent();   }
              if (C_Status==1)  {  data = 5;   driver.send((uint8_t *)&data, sizeof(data));    driver.waitPacketSent(); } // Speed  LOW
                 D_Status = 0;
               if (( kpd.key[i].stateChanged ) && (mykey == AA)) // --------------------------------------       P
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
             if (( kpd.key[i].stateChanged ) && (mykey == BB)) // --------------------------------------
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
             if (( kpd.key[i].stateChanged ) && (mykey == CC)) // --------------------------------------
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
              if (( kpd.key[i].stateChanged ) && (mykey == DD)) // --------------------------------------
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
               if (( kpd.key[i].stateChanged ) && (mykey == Key_Mode_Sw)) // --------------------------------------
                    case PRESSED:
                  if ( Key_Mode=="Perform") { Key_Mode="Bank";  }
                  else  if ( Key_Mode=="Bank") { Key_Mode="Perform";  }
                  MAIN_SCN ();
              if (( kpd.key[i].stateChanged ) && (mykey == DRUM)) // --------------------------------------
                    case PRESSED:
                  MAIN_SCN ();
             if (( kpd.key[i].stateChanged ) && (mykey == Bank_WriteA)) // --------------------------------------
                    case PRESSED:         Write_Bank ();    Key_Mode="Bank";     MAIN_SCN ();       break;
             if (( kpd.key[i].stateChanged ) && (mykey == Bank_WriteB)) // --------------------------------------
            if (( kpd.key[i].stateChanged ) && (mykey == MONO)) // --------------------------------------
                    case PRESSED:     for (int i=1; i<11; i++) { MIDI.sendControlChange(126,0,i); } // (cc#,value,channel)    MONO
                    break;     // CC# 126
            if (( kpd.key[i].stateChanged ) && (mykey == POLY)) // --------------------------------------
                    case PRESSED:      for (int i=1; i<11; i++) {  MIDI.sendControlChange(127,0,i); } // (cc#,value,channel)     POLY
                    break;  //  CC#127
             if (( kpd.key[i].stateChanged ) && (mykey == ORANGE_A )) // --------------------------------------
                    case PRESSED:
                     MIDI.sendProgramChange(111, 1);
                 for (int i=21; i>(-1); i--) {
                  MIDI.sendNoteOn((Bells_DRBR[i]+TRANS_KEY),127,1);
                 delay(100);
                 MIDI.sendNoteOff((Bells_DRBR[i]+TRANS_KEY),0,1); }  // (note,velocity,channel)
                         MAIN_SCN ();
             if (( kpd.key[i].stateChanged ) && (mykey == ORANGE_B )) // --------------------------------------
                    case PRESSED:
                    if (CC_Mode =="OFF")    {   CC_Mode ="ON";  }
                    else {    CC_Mode ="OFF";  }
                         MAIN_SCN ();
             if (( kpd.key[i].stateChanged ) && (mykey == BLUE_A )) // --------------------------------------
                    case PRESSED:
                 case RELEASED:
        if (MIDI.read())                // Is there a MIDI message incoming ?
    {        COUNT++;
                         //  digitalWrite(13,HIGH);
                           byte A_TYPE = MIDI.getType();
                           byte A_CHANNEL = MIDI.getChannel();  // channel
                           byte A_NOTE =  MIDI.getData1();  // note number
                           byte A_VOL = MIDI.getData2(); // velocity
        if ((A_TYPE==144) && (A_CHANNEL == 4)&& (KEY_SHIFT_MODE==1) ) { //                           A_TYPE=144 noteOn    128 NoteOff    ///
         TRANS_KEY = (A_NOTE-73) + TRANS_KEY_Old;                                  //  ......52 = -12........64 = 0........76 = +12.......COARSE TUNE
  display.setCursor(0,0);       display.println(A_TYPE);          display.setCursor(50,0);       display.println(A_CHANNEL);      display.setCursor(90,0);      display.println( A_NOTE);
  display.setCursor(0,16);       display.println(A_VOL);          display.setCursor(50,16);            display.print( "Event-");  display.print( COUNT);
  display.display();
   if ( TRANS_KEY != TRANS_KEY_Old )  {
         byte sysexArray[8] = {0xF0,0x7F,0x7F,0x04,0x04,0x00,(TRANS_KEY+64),0xF7};
             MIDI.sendSysEx(8,sysexArray,true);
             MAIN_SCN ();
    TRANS_KEY_Old = TRANS_KEY;
         ////   if (UP == 1) {PATCH =PATCH+10;    MIDI.sendProgramChange(PATCH, 1); delay  }
          //  if (DOWN == 1) {PATCH--;    MIDI.sendProgramChange(PATCH, 1);  }
            if (PATCH < 0) { PATCH = 127; }
            if (PATCH > 127) { PATCH = 0; }
}  // End loop      ####################################################################################################################################################
    void  All_Note_Off ()   {
     for (int ch = 0; ch < 16 + 1; ch++) {  MIDI.sendControlChange(ch,123,0);  } //  (ch ,cc ,value)
  void FIND_SCN ()
  {  display.clearDisplay();
  display.setTextSize(3);
  display.println("Key ??");
  display.display();
    void SCN_SLIDE ()   {
  display.println(SLIDE1);
  display.display();
      void MAIN_SCN ()   {
  if   (TRANS_KEY > 0) { display.print("+");     }
    display.print(TRANS_KEY);
    display.setCursor(60,0);
    display.print(Key_Mode);
    display.print("__");
    display.print(Bank);
    display.setCursor(70,12);
    display.print("P:");
    display.print(PATCH+1);
   // display.print("");
     display.setCursor(70,21);
    display.print(CC_Mode);
    display.display();
          void SLD_SCN (int NUMBER_KEY)   {
    display.print(NUMBER_KEY);
    display.display();
    void function () {
      MIDI.sendControlChange(94,127,1);  // (cc#,value,channel)
     void WEL_COME_SCN ()   {
    display.setTextSize(2);
    display.println("Ex ctrl");
    display.display();  }
void Bank_Mode (int Bank_Key)  {
    if ((Bank_Key == i)  && (Bank_Key != 1)) {
      MIDI.sendProgramChange(AAA[i], 1);
      Bank = i;
      PATCH = AAA[i];
      if (Bank_Key == 1)   {       for (int i=0; i<16; i++) {  MIDI.sendControlChange(127,0,i); } } // (cc#,value,channel)     POLY
         void Perform_Mode (int mykey)
         {PATCH = mykey-1;  MIDI.sendProgramChange(PATCH, 1);}
       void   Bank_Mode_Released (int Bank_Key1)   {
        if (Bank_Key1==1)  {     for (int i=0; i<16; i++) { MIDI.sendControlChange(126,0,i); }  } // (cc#,value,channel)    MONO
          void  Write_Bank () {
  for (int i = 1; i < 128; i++) {
    if (Bank == i) {
         EEPROM.write(i, PATCH);
         AAA[i] = PATCH;
         Write_Bank_SCN ();
         MAIN_SCN ();
            void  Write_Bank_SCN ()  {
    display.print("Write Done");
  display.display();
i try to read about midi with arduino but i could not solve it myself
I ask to Arduino Midi Expert.... please check it , what code i can try in above code ???
thank you
In setup() this is wrong:
        AAA[i]=0 ;
AAA is declared to have 128 elements. In C/C++ they are indexed from zero to 127.
Your code will store zero in AAA[128] which exists outside the array. This can lead to unpredictable behaviour.
Later on you read eeprom data into the AAA array:
The index needs to be zero to 127 here as well. But make sure that the EEPROM addresses will be correct.
You make the same indexing mistake in the Bank_Mode function - find and fix it too.
Pete
Thank you Supremo,,,
EEPROM.read /write function doesn't distrub me it is working fine.
Please give your advice on
Functions. Are you seeing some thing , why it is throwing ProgramChange #10 midi message in last????
No, it is not. You are writing data outside the bounds of your array. Once your program does that, you have entered into "undefined behavior" which means anything can happen with your code. Most likely, you are stomping on some other global variable that happens to be located just beyond your array which could produce the issue you are seeing. @el_supremo pointed this all out. Fix it.
Thank you....
I tried it replace array code
with
   for (int i = 0; i < 128 ; i++) {
in Entire sketch where i used array [0-127]
#include <RH_ASK.h>     // ok working RadioHead 1.83
#include <MIDI.h>
#include <Keypad.h>
#include <SPI.h>
#include <Wire.h>
#include<EEPROM.h>
#define KEY_UP    -115
#define A    -106
#define B    -107
#define C    -109
#define D    -108
#define AA    -96
#define BB    -97
#define CC    -98
#define DD    -99
#define MONO        -125
#define POLY        -124
#define DRUM        -116
#define BLUE_A      -121
#define BLUE_B      -120
char *data;    //  RF
String msg;
   int UP = 0;
   int DOWN = 0;
  int Bank = 61;
  String  Key_Mode;
  String  CC_Mode;
  int PATCH = 0;
 int SHIFT1 = 0;
 long COUNT = 0;
 int  TRANS_KEY = 0;
  int last_val = 0;
 int SLIDE1 = 0;
 int SLIDE1_OLD = 0;
 int Last_Note = 0;
 byte C_Status = 0;
 byte D_Status = 0;
 byte Last_Gear = 0;
 int   my_value = 0;
 int AAA[127];
     Serial.begin(9600);    // Debugging only
int data = 1;
         if (!driver.init())  // RF
         Serial.println("init failed");  // RF
  for (int i = 0; i < 128; i++)  {
    AAA[i]=0 ; }
    MIDI.begin(4);
     MIDI.turnThruOff();
 display.display();
    msg = "";
    Key_Mode="Bank";
    CC_Mode =="OFF";
  WEL_COME_SCN ();
 MAIN_SCN ();
void SCN (int gg) {
  display.display();
void loop() {       //  from @blh64
               int val = analogRead(0);   //  int val = analogRead(0);         A3 pin for External Strip-
                       MIDI.sendProgramChange(PATCH, 1);    Serial.println("w");
           SLD_SCN (SLIDE1);
    if (kpd.getKeys())
                    case PRESSED:
                    case RELEASED:
                    case PRESSED:
                    case PRESSED:
                 case HOLD:               break;
                    case PRESSED:
                  case HOLD:                break;
                    case PRESSED:
                    FIND_SCN ();
                    KEY_SHIFT_MODE = 1;
                    case RELEASED:
                     KEY_SHIFT_MODE = 0;
                    case PRESSED:
                    case PRESSED:
                    case PRESSED:
                    TRANS_KEY = 0;
                    MAIN_SCN ();
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
                    case PRESSED:
                  C_Status = 1;
                 case HOLD:
                 case RELEASED:
                C_Status = 0;
                    case PRESSED:    //41
               D_Status = 1;
                 case HOLD:
                 D_Status = 0;
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
                    case PRESSED:
                  MAIN_SCN ();
                    case PRESSED:
                  MAIN_SCN ();
                    break;     // CC# 126
                    break;  //  CC#127
                    case PRESSED:
                 delay(100);
                         MAIN_SCN ();
                    case PRESSED:
                         MAIN_SCN ();
                    case PRESSED:
                 case RELEASED:
        if (MIDI.read())
    {        COUNT++;
  display.display();
             MAIN_SCN ();
  void FIND_SCN ()
  display.display();
    void SCN_SLIDE ()   {
  display.display();
      void MAIN_SCN ()   {
    display.display();
    display.display();
    void function () {
    display.println("MIDI ctrl");
      Bank = i;
      PATCH = AAA[i];
    if (Bank == i) {
         AAA[i] = PATCH;
         Write_Bank_SCN ();
         MAIN_SCN ();
  display.display();
but could not get it be fixed. ProgChange #10 is coming till now.
yes ,,,,, Today i tried it with this simple code
#include <MIDI.h>
  int PATCH = 51;
  int SLIDE1 = 0;
  int SLIDE1_OLD = 0;
  int Last_Note = 0;
         MIDI.begin(4);
         MIDI.turnThruOff();
in this simple code i have no problem ,slide rolling goes up/down correctly ,succesfully i got progchange with variable "PATCH".
but what problem is in my below code. i have everything Necessary in my code.
could you tell me , what part of code cause MIDI.sendProgramChange(10, 1);
even i changed my array[] in this code:
#include <MIDI.h>
#include <Keypad.h>
#include <SPI.h>
#include <Wire.h>
#include<EEPROM.h>
#define KEY_UP    -115
#define A    -106
#define B    -107
#define C    -109
#define D    -108
#define AA    -96
#define BB    -97
#define CC    -98
#define DD    -99
#define MONO        -125
#define POLY        -124
#define DRUM        -116
#define BLUE_A      -121
#define BLUE_B      -120
char *data;    //  RF
String msg;
   int UP = 0;
   int DOWN = 0;
  int Bank = 61;
  String  Key_Mode;
  String  CC_Mode;
  int PATCH = 0;
 int SHIFT1 = 0;
 long COUNT = 0;
 int  TRANS_KEY = 0;
  int last_val = 0;
 int SLIDE1 = 0;
 int SLIDE1_OLD = 0;
 int Last_Note = 0;
 byte C_Status = 0;
 byte D_Status = 0;
 byte Last_Gear = 0;
 int   my_value = 0;
 int AAA[127];
int data = 1;
    AAA[i]=0 ; }
    MIDI.begin(4);
     MIDI.turnThruOff();
 display.display();
    msg = "";
    Key_Mode="Bank";
    CC_Mode =="OFF";
  WEL_COME_SCN ();
 MAIN_SCN ();
void SCN (int gg) {
  display.display();
              if ((val<100) && (CC_Mode =="ON")) {  SLIDE1=0;  }
              if ((val>950)  && (CC_Mode =="ON"))  {  SLIDE1=23;  }
           SLD_SCN (SLIDE1);
    if (kpd.getKeys())
                    case PRESSED:
                    case RELEASED:
                    case PRESSED:
                    case PRESSED:
                 case HOLD:               break;
                    case PRESSED:
                  case HOLD:                break;
                    case PRESSED:
                    FIND_SCN ();
                    KEY_SHIFT_MODE = 1;
                    case RELEASED:
                     KEY_SHIFT_MODE = 0;
                    case PRESSED:
                    case PRESSED:
                    case PRESSED:
                    TRANS_KEY = 0;
                    MAIN_SCN ();
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
                    case PRESSED:
                  C_Status = 1;
                 case HOLD:
                 case RELEASED:
                C_Status = 0;
                    case PRESSED:    //41
               D_Status = 1;
                 case HOLD:
                 D_Status = 0;
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
                    case PRESSED:
                 case HOLD:
                 case RELEASED:
                    case PRESSED:
                  MAIN_SCN ();
                    case PRESSED:
                  MAIN_SCN ();
                    break;     // CC# 126
                    break;  //  CC#127
                    case PRESSED:
                 delay(100);
                         MAIN_SCN ();
                    case PRESSED:
                         MAIN_SCN ();
                    case PRESSED:
                 case RELEASED:
        if (MIDI.read())
    {        COUNT++;
  display.display();
             MAIN_SCN ();
  void FIND_SCN ()
  display.display();
    void SCN_SLIDE ()   {
  display.display();
      void MAIN_SCN ()   {
    display.display();
    display.display();
    void function () {
      Bank = i;
      PATCH = AAA[i];
    if (Bank == i) {
         AAA[i] = PATCH;
         Write_Bank_SCN ();
         MAIN_SCN ();
  display.display();
please check if possible
What Arduino board are you using?
In your new code, you shrunk the size of your AAA array
so now when you iterate from 0..127
You have the exact same problem. You are still writing beyond the last element in the array by 1. You need to keep the array declaration as 128 elements
int AAA[128];
and then iterate from 0..127.
I would suggest you take some time and study how C/C++ works.
Thank you,,,,,,, blh64
Thank you,,, el supremo
Thanks a lot,,, it solved. Reply from el_supremo pull my interest in array study.I am sorry I used wrong array size. As I set it int AAA[128]; now it is working. Thank it taught me correct size /use of array according to numbers of elements. Sorry I was consider 0 as 1st .
Thank you again. ,,, issue got solved...
