As a short introduction I used arduino a couple of years ago completing some basic tutorials - blinking LEDs and stepper motor control, so as you can imagine I'm very much a beginner.
I recently purchased the Sparkfun Midi Shield for my Arduino Uno board with the aim to send a sysex message to my Roland Alpha Juno synthesizer to control a VCF cutoff value on the synth.
I did some research and found some posts but a lot of them are complex for a beginner like myself, they seem to be involving lots of other elements such as button presses and not helpful for a beginner.
The sysex message is F0 41 36 00 23 20 01 10 00 F7
I'm really stuck - the jump from simple analog read and writes and blinking LEDs seems to be to far but i guess you have to start somewhere so thought best to post here.
so far I have (dont laugh!)
(how do i implement the analogRead into sending the byte to midi)
#include <MIDI.h>
#define VCFCUTOFF 0
int analogPin = A0 // VCF pot set to A0 pin on midishield
byte sendSysex;
vcfPot = analogRead(analogPin);
filter = vcfPot/8;
Sending MIDI is relatively straightforward, filtering the analog input and only sending MIDI messages when you're actually turning the knob could be a bit more involved.
You could use the Control Surface library I maintain, it supports many different MIDI interfaces and has functions for filtering analog inputs built-in, so you don't have to reinvent the wheel there.
You could do something like this, for example:
#include <Control_Surface.h> // https://github.com/tttapa/Control-Surface
// MIDI interface on “Serial” UART (TX/RX pins)
HardwareSerialMIDI_Interface midi { Serial };
// Reads, filters and detects changes of an analog input
// Produces a 7-bit output [0-127]
FilteredAnalog<7> potentiometer { A0 };
// MIDI System Exclusive data to send
uint8_t sysex_data[] {
0xF0, 0x41, 0x36, 0x00, 0x23, 0x20, 0x01, 0x10, 0x00, 0xF7,
// Reference to easily update the parameter value of the SysEx message
uint8_t &vcf_value = sysex_data[8];
// Initialize MIDI interface and analog input
midi.begin();
potentiometer.setupADC();
midi.update(); // Handle and discard MIDI input
// Check whether the potentiometer value changed
if (potentiometer.update()) {
vcf_value = potentiometer.getValue(); // if it did, update the message
SysExMessage msg { sysex_data, sizeof(sysex_data) };
midi.send(msg); // and send it out over MIDI
