Hi there, thank you in advance for any help. I am very new to using these microcomputer, codes, relays etc. I am trying to build a synchronized light show.
Hardware:
- ESP32 development board
- 8 channel relay
- Computer
Software:
- Arduino IDE
- Hairless MIDI
- LoopMIDI
- DAW software
Steps taken so far:
- Set up the ESP32 board in the Arduino IDE and uploaded a sketch.
- Connected the MIDI controller components to the ESP32 board and wrote a code to read the inputs from the components and send MIDI signals out through the MIDI interface or cable.
- Set up the Hairless MIDI software and created a virtual MIDI port using LoopMIDI to receive and send MIDI signals to the ESP32 board.
- Configured the DAW software to recognize the virtual MIDI port and route the MIDI signals to the desired tracks
I created a MIDI arrangement that syncs to the beat of a song. Uploaded that at the song to DAW. Created virtual MIDI port and in the DAW and loaded that to the hairless MIDI bridge.
I think it's close, but I am not getting a signal from serial port in hairless midi bridge and also nothing on the output from the relay. I know I am probably missing some info to help solve the problem, please let me know any additional info needed.
#include "notes_bits.h"
const int relayPins[] = {4, 5, 6, 7, 8, 9, 10, 11}; // pins connected to the relay channels
const int numRelays = sizeof(relayPins) / sizeof(relayPins[0]); // calculate number of relays based on array size
int pitch, cmd, velocity;
boolean state;
byte relayData = 0;
for (int i = 0; i < numRelays; i++) {
pinMode(relayPins[i], OUTPUT);
digitalWrite(relayPins[i], HIGH); // set relay to initial state (off)
Serial.begin(38400);
if (Serial.available() > 2) {
cmd = Serial.read();
pitch = Serial.read();
velocity = Serial.read();
if (cmd == 144) { // note on
state = true;
} else if (cmd == 128) { // note off
state = false;
// set the corresponding bit in relayData
int relayIndex = getBit(pitch);
if (relayIndex < numRelays) {
bitWrite(relayData, relayIndex, state);
// turn on/off the relays according to the new data
digitalWrite(relayPins[i], bitRead(relayData, i));
notes.bits.h
#define C8 0b00000001
#define Cs8 0b00000010
#define D8 0b00000100
#define Ds8 0b00001000
#define E8 0b00010000
#define F8 0b00100000
#define Fs8 0b01000000
#define G8 0b10000000
byte getBit(int pitch) {
switch(pitch) {
case 96: return C8; // C8
case 97: return Cs8; // C#8/Db8
case 98: return D8; // D8
case 99: return Ds8; // D#8/Eb8
case 100: return E8; // E8
case 101: return F8; // F8
case 102: return Fs8; // F#8/Gb8
case 103: return G8; // G8
default: return 0; // default case for silence
