Basically, I have followed the Youtube tutorial provided by the channel Notes and Volts about a MIDI in circuit, but I would prefer writing my own code for handling the midi information.
I have figured most of the code and I decided to use the MIDIUSB arduino library available on the library manager. The part on where I'm getting stuck is actually sending the midi message to external programs or VSTs. By simply printing the information on the serial monitor, everything seems to be working alright, but whenever I actually try to place the noteOn or noteOff functions in the place where the printing was happening I am experiencing some weird bugs, such as having to press notes 8 times and after then i actually recieve the signals of the notes pressed.
Here is the code:
#include "MIDIUSB.h"
int byte1; // 1st byte is command or "status" byte
int byte2;
int byte3; // 2nd byte is program change number
int theBytes[3];
void noteOn(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
Serial1.begin(31250);
void controlChange(byte channel, byte control, byte value) {
midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
MidiUSB.sendMIDI(event);
if (Serial1.available() >= 3) {
for (int i=0; i<3; i++) {
theBytes[i] = Serial1.read();
byte1 = theBytes[0];
byte2 = theBytes[1];
byte3 = theBytes[2];
Serial.print(byte1);
Serial.print(", ");
Serial.print(byte2);
Serial.print(", ");
Serial.println(byte3);
And here is an example of code that is not working and I can't really figure out why:
int byte2;
int theBytes[3];
if(byte3 > 0){
noteOn(0, byte2, byte3);
} else if(byte3 == 0){
noteOff(0, byte2, byte3);
