Hello,
I made this post in the Audio forum but it doesn't get much traffic, so I'm retrying here
I've currently got a MIDI project going, and I'm trying to use a SR04 sensor to control pitch bend.
Here's what I've got:
 a=sr04.Distance();    Â
 if (a <= 20){             //If Distance is less than 20cm, start pitch bending.
 pitchBend = map(a,0,20,8191,-8192);  // Map 0-20cm to Pitch Bend Parameters (close is higher, further is lower pitch).
 if (pitchBend>8191){pitchBend=8191;};if (pitchBend<-8192){pitchBend=-8192;} // Debug
 PitchWheelChange(pitchBend);  Â
void PitchWheelChange(int value) {Â Â Â Â Â // Pitch Wheel Function taken from here: [url=https://forum.arduino.cc/index.php?topic=119790.0]https://forum.arduino.cc/index.php?topic=119790.0[/url]
  unsigned int change = 0x2000 + value; // 0x2000 == No Change
  unsigned char low = change & 0x7F; // Low 7 bits
  unsigned char high = (change >> 7) & 0x7F; // High 7 bits
  midiMessage(0xE0, low, high);
 Â
void midiMessage(int commandByte, int data1Byte, int data2Byte) {Â // Midi Output Function
  Serial.write(commandByte);
  Serial.write(data1Byte);
  Serial.write(data2Byte);
So essentially I've mapped 0-20cm distance to pitch bend midi parameters, which outputs to a MIDI Message Function.
The issue I'm having is that Hairless MIDI freaks out with its "Received a Status Byte when we were expecting 1 more data byte" message. And my DAW (FL Studio) simply states that I'm sending pitch bend of 158/168 cents no matter what the distance is. I guess therefore, SOMETHING works, but there is obviously something wrong.
Any ideas on this? Perhaps my coding is wrong? I also heard the default library for those ultrasonc modules are very temperamental. Maybe worth getting a new library?
Any help's appreciated,
