millis() good enough for a RTC
Hi, I want to make an alarm clock with arduino, I'm thinking of using millis() to provide me a real time clock, are they acurate enough even if the main loop program takes more than a secound or so (I will write to a LCD, and that)?
Is there any way to use AVR's internal counters?
Thanks
NEDM64, the millis() mechanism is driven by interrupts, so even if your loop function is 30 minutes long the value of millis() will be pretty accurate. That said, it's accuracy is limited by the accuracy of the crystal.
M
Thanks
Now, I can throw away the 1Hz signal/RTC from the project :wink:
