Millis timer help
I'm trying to use 3 timers in a project I'm doing. The first turns on a sensor, and the second turns it off. I have this section working but the third timer is the issue.
If the sensor is within a certain value range an output goes HIGH. The third timer is supposed to then set it LOW. Much like the first 2 timers
any help would be appreciated
const unsigned long DELAY_TIME = 10000;
const unsigned long DELAY_TIME1 = 1000;
const unsigned long DELAY_TIME2 = 2000;
unsigned long moisture_timer, moisture_on, solnoid_on = 0;
  for (int i = 5; i > 0; i--) { // just to give a little time before it all starts
    Serial.print(i); Serial.print(' ');
  pinMode(2, OUTPUT);// the power source for the moisture sensor
  pinMode(3, OUTPUT); // signal for the latch relay
  digitalWrite(2, LOW);// sets the pin to 0V
  digitalWrite(3, LOW); //sets the pin to 0V
  moisture_timer =  moisture_on  = solnoid_on = millis();
  Serial.println(analogRead(A0));
  if (millis() - moisture_timer > DELAY_TIME) {
    if (digitalRead(2) == LOW) {
      moisture_on = millis();
    digitalWrite(2, HIGH);
    if (millis() - moisture_on > DELAY_TIME1) {
      moisture_timer = millis();
    if (analogRead(A0) <= 500 && analogRead(A0) >= 1) {
      digitalWrite(3, HIGH);
    if (millis() - solnoid_on > DELAY_TIME2) {
Read a bit about state machines. You should check first in which state your device actually is. Only then check the appropriate delay whether to take an action.
try this instead of your two last conditions
Hello gitpeke
I could be easy when some comments for the functionality of the sketch would be added.
Provide functional names for the port pins in use.
tutorial about state-machines
Colleagues, I don’t think that state machines are needed here, as far I understand all three timers are independent of each other
tutorial easier to understand and easier to apply than the standard BWD
