Millis Ultrasonic sensor
Hello.I have an arduino mega and an ultrasonic sensor.
I have found many codes in internet about millis AND ultrasonic sensors,but nothing worked.
I tried a code of mine ,but I get 0.00 in serial monitor
CODE:
const int Trig_pin_front = 42;
const int Echo_pin_front = 43;
long duration_front;
float distance_front;
boolean first = true;
boolean second_ = false;
unsigned long prev = 0;
  pinMode(Echo_pin_front , INPUT);
  pinMode(Trig_pin_front , OUTPUT);
void ultrasonic_sensor_forward()
  unsigned long cur = millis();
  if (first)
    if (cur - prev >= 2)
      digitalWrite(Trig_pin_front , HIGH);
      first = false;
      second_ = true;
      prev = cur;
  if (second_)
      digitalWrite(Trig_pin_front , LOW);
      duration_front = pulseIn(Echo_pin_front , HIGH);
      distance_front = duration_front * 0.034 / 2;
      Serial.println(distance_front);
      second_ = false;
      first = true;
      prev = cur;
ultrasonic_sensor_forward();
Any advices?What wrong my code has?
Thanks...
250 pings per second?
About 15 times too many.
Also, a trigger pulse is normally of the order of 10 microseconds, not 2 milliseconds.
It didn't work.
I changed it to 20 milliseconds and after to 10 milliseconds ,but I get 0.00 distance again....
  static unsigned long prev;
  if (cur - prev >= 50) // no more than 20 pings per second
      digitalWrite(Trig_pin_front, HIGH);
      delayMicrosceonds (10);
      digitalWrite(Trig_pin_front, LOW);
      prev += 50;
Uncompiled, untested.
Better still, use the NewPing library
I do not want to use delay() or delayMicroseconds().
Only millis() function.
Is this possible?
arduiNICK:
Is this possible?
Yes, of course.
My version doesn't use delay, and pulseIn blocks longer than the delayMicroseconds I used, but hey, knock yourself out.
I don't understand.
Can I use ultrasonic sensor with only millis (no delay no delayMicroseconds) ?
Yes, I think you can - the out-going pulse train isn't sent until the falling edge of the trigger pulse (at least, that's how it should be), so I guess it shouldn't matter how long the trigger pulse is.
Can't see why you'd want to, though.
Like I said, if you're worried about blocking, then get rid of pulseIn.
Ok ,thank you.
Do you know how to do it or does anyone know about it?
Yes - use the NewPing library.
Thanks again .I will try
