Missing required device: no camera found
Hello!
CONTEXT:
I am new to the Arduino community and am currently exploring the UNO Q.
I am currently working on a project involving a USB camera for object detection.
Hence, I wanted to begin with making sure AppLab given projects involving USB cameras were working fine: "Face Detector on Camera" and "Detect Objects on Camera"
I have read similar posts but could not make it work.
ISSUE:
After trying to run on Network Mode I have this issue in the console:
Starting app "Detect Objects on Camera"
python provisioning
missing required device: no camera found
I imagine the issue is coming from my connections which are described in the "HW" section of this post.
HW:
USB HUB
Camera
Does the issue arise from the fact that my UNO Q is not detected as the host for the camera?
Should I get a new USB HUB? Like this one I just saw it on different projects which seemed to work.
Thank you in advance!
Thomas
Hi @thomaslenges ,
Welcome to the forum..
try using the usb-c in port next to power..
using the q in SBC mode might be easier but yes you would need a different dongle..
here's what I use..
only ever used mine in SBC (single board computer) mode..
try the in port, you need the cam to get into the q..
good luck.. ~q
My understanding is a USB camera will require a dongle with power pass-through. Well that is what I use when I use a USB camera in Network mode. The hardware difference between network mode and SBC mode is that in Network mode you do not need a keyboard, mouse or HDMI output. The Uno Q needs to act as a host so it needs to be connected to the pass through output from the dongle.
Hey thanks guys for your responses!
The issue seems to have come from the USB HUB indeed.
I got another to test and it works fine!
New hub
I followed the schematic found here.
Thanks again for the quick responses.
Best,
Thomas
