Missing terminating character
Another question on terminating charactoers
I have been given a programme for a motorcycle blue tooth controller so that I can control my tablet without touching the screen by the use of a blue tooth button set.
I have created the unit and am trying to programme it.
I seem to be successful until and error is thrown up stating:
exit status 1
Compilation error: missing terminating > character
Checking through answers on the forum I seem to have all of the prerequisites not to get this error.
Could someone tell me where I am wrong?
My code (its 527 lines) ....
`// RALLY RAMPAGE BLUETOOTH BIKE HANDLEBAR NAVIGATION CONTROLLER
// www.rallyrampage.com
// Version: 2.5.1 (Stable BLE and LED Status Update)
// Updated: 2024-10-14
// Ownership: Rally Rampage
// Published by: Rally Rampage
// Target Hardware: ESP32 Wroom Development Board
// UNIQUE FEATURES
// Five apps commands including Terra Pirata Roadbook Reader
// Remembers the last app when lost power
// reconnects on power up again
#include <Arduino.h>
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEScan.h>
#include <BLEAdvertisedDevice.h>
#include <Preferences.h>
#include <WiFi.h> // For getting the MAC address
#if SOFTWARE_SERIAL_AVAILABLE
#include <SoftwareSerial.h>
#endif
// Declare function prototype for generating a serial number
String generateSerialNumber();
// Create a BLE Keyboard instance
BleKeyboard bleKeyboard;
// Create a Preference instance for saving settings
Preferences preferences;
// Define variables
const String RR_Version = "V2.5.1";
const int button1state = LOW;
const int button2state = LOW;
const int button3state = LOW;
const int button4state = LOW;
const int button5state = LOW;
// Define the pins for the LEDs
const int ledBLUE = 23;  // Blue LED pin
const int ledRED  = 22;  // Red LED pin
// Define the pins for the pushbuttons
const int button1 = 19;  // Button 1 pin
const int button2 = 18;  // Button 2 pin
const int button3 = 17;  // Button 3 pin
const int button4 = 16;  // Button 4 pin
const int button5 = 4;   // Button 5 pin
// Define the pin for the mode switch button.
const int modeSelect = 21;
// Default value for the selected app. Change this if you want a different default app.
// 0: No softapp yet
// 1: Locus Maps
// 2: Rally Navigator
// 3: OsMand
// 4: Piste Roadbook Reader
// 5: Terra Pirata
int softApp = 0; //Locus set as default when starting unit
int softAppSaveValue;   // temp softApp value for EEPROM
// Define the delay time in ms between button presses and between toggle switches.
const int buttonWait = 250;  // Button delay time
const int toggleWait = 20;  // Toggle switch delay time
const int ledFlashDelay = 150;
const int ColorBlack = 0;
const int ColorBlue = 1;
const int ColorRed = 2;
// Function to blink the blue LED
void blinkBlueLed() {
  digitalWrite(ledBLUE, LOW);
  delay(150);
  digitalWrite(ledBLUE, HIGH);
// Function to generate a serial number based on the last 3 bytes of the MAC address
// Function to generate a 6-digit serial number based on the last 3 bytes of the MAC address
String generateSerialNumber() {
  uint8_t baseMac[6];
  esp_read_mac(baseMac, ESP_MAC_WIFI_STA); // Read the MAC address
  // Extract the last 3 bytes of the MAC address and convert them to a 6-character string
  char serialNumber[7]; // 6 hex digits + null terminator
  sprintf(serialNumber, "%02X%02X%02X", baseMac[3], baseMac[4], baseMac[5]);
  return String(serialNumber); // Return the 6-character serial number
// Function to get the unique chip ID as a serial number
/*String getChipID() {
  // The chip ID is based on the last 24 bits of the MAC address
  uint32_t chipId = 0;
  for(int i=0; i<17; i+=8) {
    chipId |= ((ESP.getEfuseMac() >> (40 - i)) & 0xFF) << i;
  return String(chipId);
// Forward declarations
void flashLedIndicator(int FlashCount, int FlashDelay, int FlashColor);
void storeSoftApp(int softAppVal);
// This function is called once when your program starts. It's used to initialize variables,
// input and output pin modes, and other libraries needed by your sketch.
  // Initialize serial communication for debugging
  Serial.println("Starting Rampage Controller ...");
  // Load previous softApp selection from preferences
  preferences.begin("my-app", false);  // Open preferences
  softAppSaveValue = preferences.getUInt("counter", 0);  // Retrieve saved value
  preferences.end();  // Close preferences
  // Set the softApp to the saved value
  if (softAppSaveValue > 5) {
    softApp = 0;  // Reset to 0 if the value exceeds the number of apps
    softApp = softAppSaveValue;  // Otherwise, set to the saved value
  // PRINT STARTUP STATUS
  Serial.print("Rampage Controller Version: ");
  Serial.println(RR_Version);
  Serial.print("You are in softApp: ");
  Serial.println(softApp);
  // Generate BLE name with version and chip ID
  String bleName = "Rampage_" + generateSerialNumber();
  Serial.print("BLE Name: ");
  Serial.println(bleName);  // Print to check the full name
  // Initialize BLE with the generated name
  bleKeyboard = BleKeyboard(bleName.c_str());
  bleKeyboard.begin();
  Serial.println("BLE Keyboard started and advertising...");
  Serial.print("BLE Advertising with name: ");
  // Set up button pins as input with built-in pullup resistors
  pinMode(button1, INPUT_PULLUP);
  pinMode(button2, INPUT_PULLUP);
  pinMode(button3, INPUT_PULLUP);
  pinMode(button4, INPUT_PULLUP);
  pinMode(button5, INPUT_PULLUP);
  // Set up LED pins as output
  pinMode(ledBLUE, OUTPUT);
  pinMode(ledRED, OUTPUT);
  // Set up mode select switch pin as input with built-in pullup resistor.
  pinMode(modeSelect, INPUT_PULLUP);
  // Indicate ready state by setting the blue LED on
  digitalWrite(ledRED, LOW);
// THIS IS THE LOOP SECTION OF THE CODE THAT KEEPS LOOPING AND RUNNING
  // START SOFT APP SELECT LOOP
  // The digitalRead(modeSelect) function checks if the mode select button has been pressed (LOW means button press)
  if (digitalRead(modeSelect) == LOW) {
    // Turn on the red LED (HIGH) and turn off the blue LED (LOW)
    flashLedIndicator(0,0,ColorRed); //Set Red Led
    // Check if button 1 has been pressed
    if (digitalRead(button1) == button1state) {
      // If button 1 has been pressed, set the softApp variable to 1
      softApp = 1;
      storeSoftApp(softApp);
      // Output a message to the serial console
      Serial.println("While in Mode Select you have selected softApp 1: Locus Maps.");
      // Send a message via Bluetooth to the connected device
      if (bleKeyboard.isConnected()) {
         bleKeyboard.println("App 1: Locus"); }
      // Call function to flash LED according to softApp # selected
      flashLedIndicator(1,ledFlashDelay,ColorBlue);
    // End of select softapp 1
    // Check if button 2 has been pressed
    // The sequence of operations is the same as for button 1, but softApp is set to 2
    if (digitalRead(button2) == button2state) {
      softApp = 2;
      Serial.println("While in Mode Select you have selected softApp 2: Rally Navigator.");
         bleKeyboard.println("App 2: Rally"); }
      flashLedIndicator(2,ledFlashDelay,ColorBlue);
    // End of select softapp 2
    // Check if button 3 has been pressed
    // The sequence of operations is the same as for button 1 and 2, but softApp is set to 3
    if (digitalRead(button3) == button3state) {
      softApp = 3;
      Serial.println("While in Mode Select you have selected softApp 3: OsMand.");
         bleKeyboard.println("App 3: OsMand"); }
      flashLedIndicator(3,ledFlashDelay,ColorBlue);
    // End of select softapp 3
    // Check if button 4 has been pressed
    // The sequence of operations is the same as for button 1, 2, and 3, but softApp is set to 4
    if (digitalRead(button4) == button4state) {
      softApp = 4;
      Serial.println("While in Mode Select you have selected softApp 4: Piste Roadbook Reader.");
         bleKeyboard.println("App 4: Piste"); }
      flashLedIndicator(4,ledFlashDelay,ColorBlue);
    // End of select softapp 4
    // Check if button 5 has been pressed
    if (digitalRead(button5) == button5state) {
      softApp = 5;
      Serial.println("While in Mode Select you have selected softApp 5: Terra Pirata.");
         bleKeyboard.println("App 5: Terra Pirata"); }
      flashLedIndicator(5,ledFlashDelay,ColorBlue);
    // End of select softapp 5
  // END SOFT APP SELECT LOOP
  // START SOFT APP RUN LOOP
  if (digitalRead(modeSelect) == HIGH) {
    flashLedIndicator(0,0,ColorBlue); // Set Blue Led
    delay(ledFlashDelay);
    if (!bleKeyboard.isConnected()) {
       flashLedIndicator(1,ledFlashDelay,ColorRed); }
    if (softApp == 0) { // App 0 No softApp value yet
       Serial.println("You are in softApp: ZERO");
    } // End softapp 0
    if (softApp == 1) {
       // App 1 Locus Maps : Button 1 : Zoom In : Vol +
       // App 1 Locus Maps : Button 2 : Zoom Out : Vol -
       // App 1 Locus Maps : Button 3 : Map Up : 'r'
       // App 1 Locus Maps : Button 4 : Centre Map : 'c'
       // App 1 Locus Maps : Button 5 : Display on/off : 'd'
       // PUSH BUTTONS
          Serial.println("Button 1 - Locus - Volume Up");
          // Sending the command for zooming in : Volume Up
             bleKeyboard.write(KEY_MEDIA_VOLUME_UP); }
             flashLedIndicator(1,10,ColorBlack);
          Serial.println("Button 2 - Locus - Volume Down");
          // Sending the command for zooming out : Volume Down
             bleKeyboard.write(KEY_MEDIA_VOLUME_DOWN); }
          Serial.println("Button 3 - Locus - 'r' key");
          // Sending the command for map up : the 'r' key
             bleKeyboard.write('r'); } // Key r
          Serial.println("Button 4 - Locus - 'c' key");
          // Sending the command for Map Centre : 'c' key
             bleKeyboard.write('c'); } // key c
          Serial.println("Button 5 - Locus - 'd' key");
          // Sending the command for Display : 'd' key
             bleKeyboard.write('d'); } // key d
    } // End softapp 1
    if (softApp == 2) {
       // App 2 Rally Navigator : Button 1 : Trip UP : Vol +
       // App 2 Rally Navigator : Button 2 : Trip Down : Vol -
       // App 2 Rally Navigator : Button 4 : Scroll UP : Media Next
       // App 2 Rally Navigator : Button 5 : Scroll Down : Media Previous
       // PUSH BUTTONS
          Serial.println("Button 1 - Rally - Volume Up");
          // Sending the command for Trip UP : Volume Up
          Serial.println("Button 2 - Rally - Volume Down");
          // Sending the command for Trip Down : Volume Down
          Serial.println("Button 4 - Rally - Next Media");
          // Sending the command for Scroll UP : Next Media
             bleKeyboard.write(KEY_MEDIA_NEXT_TRACK); }
          Serial.println("Button 5 - Rally - Prev Media");
          // Sending the command for Scroll Down : Prev Media
             bleKeyboard.write(KEY_MEDIA_PREVIOUS_TRACK); }
    } // End softapp 2
    if (softApp == 3) {
       // App 3 OsMand : Button 1 : Pan UP : Dpad_Up
       // App 3 OsMand : Button 2 : Pan Down : Dpad_Down
       // App 3 OsMand : Button 3 : Centre : 'c'
       // App 3 OsMand : Button 4 : Pan Left : Dpad_Left
       // App 3 OsMand : Button 5 : Pan Right : Dpad_Right
       // PUSH BUTTONS
          Serial.println("Button 1 - OsMand - Dpad_Up");
          // Sending the command for Pan UP : Dpad_Up
             bleKeyboard.write(KEY_UP_ARROW); }
          Serial.println("Button 2 - OsMand - Dpad_Down");
          // Sending the command for Pan Down : Dpad_Down
             bleKeyboard.write(KEY_DOWN_ARROW); }
          Serial.println("Button 3 - OsMand - Keycode_C");
          // Sending the command for Centre : Keycode_C
          Serial.println("Button 4 - OsMand - Dpad_Left");
          // Sending the command for Pan Left : Dpad_Left
             bleKeyboard.write(KEY_LEFT_ARROW); }
          Serial.println("Button 5 - OsMand - Dpad_Right");
          // Sending the command for Pan Right : Dpad_Right
             bleKeyboard.write(KEY_RIGHT_ARROW); }
    } // End softapp 3
    if (softApp == 4) {
       // App 4 Piste : Button 1 : Rb Scroll Fwd : w
       // App 4 Piste : Button 2 : Rb Scroll Rev : x
       // App 4 Piste : Button 3 : Trip + : a
       // App 4 Piste : Button 4 : Trip - : d
       // App 4 Piste : Button 5 : Medial Play/Pause : q
       // PUSH BUTTONS
          Serial.println("Button 1 - Piste - 'w' key");
          // Sending the command for Rb Scroll Fwd : 'w' key
             bleKeyboard.write('w'); }
          Serial.println("Button 2 - Piste - 'x' key");
          // Sending the command for Rb Scroll Rev : 'x' key
             bleKeyboard.write('x'); }
          Serial.println("Button 3 - Piste - 'a' key");
          // Sending the command for Trip + : 'a' key
             bleKeyboard.write('a'); }
          Serial.println("Button 4 - Piste - 'd' key");
          // Sending the command for Trip - : 'd' key
          Serial.println("Button 5 - Piste - 'q' key");
          // Sending the command for Medial Play/Pause : 'q' key
             bleKeyboard.write('q'); }
    } // End softapp 4
    if (softApp == 5) {
       // App 5 Rally Navigator : Button 1 : Fwd scroll : Media Next
       // App 5 Rally Navigator : Button 2 : Rev scroll : Media Previous
       // App 5 Rally Navigator : Button 3 : Trip + : Vol -
       // App 5 Rally Navigator : Button 4 : Trip - : Vol +
       // App 5 Rally Navigator : Button 5 : Lock screen : x
       // PUSH BUTTONS
          Serial.println("Button 1 - media next scroll forward");
          Serial.println("Button 2 - media previous scroll down");
          Serial.println("Button 3 - Volume - trip +");
          Serial.println("Button 4 - Volume + Trip -");
          Serial.println("Button 5 - Lock screen");
             bleKeyboard.write(KEY_MEDIA_LOCK_SCREEN); }
    } // End softapp 5
  } // End of HIGH state button loop
} // End of loop code
void flashLedIndicator(int FlashCount, int FlashDelay, int FlashColor) {
  if (FlashCount == 0) {
     if (FlashColor == ColorBlue) {
        digitalWrite(ledBLUE, HIGH);  // Turn on the blue LED
        digitalWrite(ledRED, LOW); }  // Turn off the red LED
     if (FlashColor == ColorRed) {
        digitalWrite(ledBLUE, LOW);   // Turn off the blue LED
        digitalWrite(ledRED, HIGH); }  // Turn on the red LED
     if (FlashColor == ColorBlack) {
  else {
     int ledBlueState = digitalRead(ledBLUE);
     int ledRedState = digitalRead(ledRED);
     delay (FlashDelay);
     for (int i = 1; i <= FlashCount; i++) {
        if (FlashColor == ColorBlue) digitalWrite(ledBLUE, HIGH);
        if (FlashColor == ColorRed) digitalWrite(ledRED, HIGH);
        delay(FlashDelay);
        delay(FlashDelay);
     digitalWrite(ledBLUE, ledBlueState);
     digitalWrite(ledRED, ledRedState);
void storeSoftApp(int softAppVal) {
  preferences.putUInt("counter", softAppVal); // Use softAppVal instead of counter
  preferences.end();
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Please post your sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
Is something missing from this line ?
It is, I have added it and still am getting an error.
I have formatted the code
Please post the full error message, using code tags when you post it
No, I really don't think you did.
The results of compiling your sketch, after removing extraneous back ticks and adding an #include for the BleKeyboard library.
arduino-cli compile -b esp32:esp32:firebeetle32 --warnings all --output-dir ~/tmp --no-color (in directory: /home/me/Documents/sketchbook/ESP32/test)
Sketch uses 1105917 bytes (84%) of program storage space. Maximum is 1310720 bytes.
Global variables use 38136 bytes (11%) of dynamic memory, leaving 289544 bytes for local variables. Maximum is 327680 bytes.
Used library       Version Path
ESP32 BLE Arduino  2.0.0   /home/me/.arduino15/packages/esp32/hardware/esp32/2.0.14/libraries/BLE
ESP32 BLE Keyboard 0.3.2   /home/me/Documents/sketchbook/libraries/BleKeyboard
Preferences        2.0.0   /home/me/.arduino15/packages/esp32/hardware/esp32/2.0.14/libraries/Preferences
WiFi               2.0.0   /home/me/.arduino15/packages/esp32/hardware/esp32/2.0.14/libraries/WiFi
Used platform Version Path
esp32:esp32   2.0.14  /home/me/.arduino15/packages/esp32/hardware/esp32/2.0.14
Compilation finished successfully.
I have to say this is all new to me. I cannot see the wood for the trees.
I'd need to be shown whats wrong
@UKHeliBob showed you what was wrong.
You claimed you corrected that and got the same error.
I did correct it and did not get the same error.
What conclusion can you draw from that?
Indeed, constantly modifying the code in post #1 makes it impossible to make sense of the thread. Always post new revised code and the error messages with each revision.
