MKR 1010 Battery
Hi
I am using the following code to monitor a 3.7V 800MAH lithium battery to power my MKR 1010, and I have all the required library. However, this code always shows the battery percentage as 100, do you have any idea how to solve?
#include "Battery.h"
Battery battery(2750, 4200, ADC_BATTERY);
	while (!Serial);
	analogReference(AR_EXTERNAL);
	analogReadResolution(10);
	battery.begin(3300, 1.47);
	Serial.print("Battery voltage is ");
	Serial.print(battery.voltage());
	Serial.print(" (");
	Serial.print(battery.level());
	Serial.println("%)");
Hi @afnansb_233, I would suggest you this Arduino tutorial to follow. It is quite easy to read and guides you through the steps to solve your issue in another way.
