I´m working on a project in which I want a mkr 1300 wan LoRA to work together with a SX1262 868M LoRa HAT for a Raspberry PI in point to point communication mode.
I know the sending mkr 1300 WAN is working since I have another mkr 1300 who receives and interprets the transmission correctly.
However, I cannot get the Raspberry PI top hat to receive. Since I´m new to Lora, does anyone know where I can find how the mkr LoRa is parametrized? I´m assuming parameterizing the Raspberry PI top hat in the same way would enable communication.
Thanks in advance for any kind of support or hints
Thanks for the reply. The only parameter in the code is setting the LoRa frequency, in my case 868 Mhz. I cannot find any parameters in the included .h files; (SPI.h, LoRa.h, MKRWAN.h) but maybe I´m just simply stupid
You will need to trawl through the documentation for the library, LoRa.h, that you are using, to see what the default LoRa parameters are, or set them your self.
For two LoRa devices to communicate these settings need to match;
Frequency
Spreading factor (SF)
Bandwidth
Coding rate
Syncword
Optimisation
Implicit\Explicit mode
Packet CRC on\off
Preamble Length
IQ Normal\Inverted
You cannot mix SX127x and SX126X devices at SF5 or SF6. Most SX127X devices wont work at lower than 62500hz bandwidth.
