Hey guys.
I'm using MKR GSM 1400 board for an agro project. I'm getting some values from 2 NPK sensors and sending them to a server. This is done every 30 mins as you can see in the following code:
#include <MKRGSM.h>
const char PINNUMBER[] = "";
const char GPRS_APN[] = "";
const char GPRS_LOGIN[] = "";
const char GPRS_PASSWORD[] = "";
GSMClient client;
GPRS gprs;
GSM gsmAccess;
char server[] = "<server>";
char path[] = "<path>";
int port = <port>;
#define RE 5
#define DE 4
//sixIn
const byte moisSixIn[] = {0x03, 0x03, 0x00, 0x12 ,0x00, 0x01, 0x25, 0xED};
const byte nitroSixIn[] = {0x03, 0x03, 0x00, 0x1E, 0x00, 0x01, 0xE5, 0xEE};
const byte econSixIn[] = {0x03, 0x03, 0x00, 0x15, 0x00, 0x01, 0x94, 0x2C};
const byte phSixIn[] = {0x03, 0x03, 0x00, 0x06, 0x00, 0x01, 0x65, 0xE9};
const byte phosSixIn[] = {0x03, 0x03, 0x00, 0x1F, 0x00, 0x01, 0xB4, 0x2E};
const byte potaSixIn[] = {0x03, 0x03, 0x00, 0x20, 0x00, 0x01, 0x84, 0x22};
const byte moisTwelveIn[] = {0x01, 0x03, 0x00, 0x12, 0x00, 0x01, 0x24, 0x0F};
const byte econTwelveIn[] = {0x01, 0x03, 0x00, 0x15, 0x00, 0x01, 0x95, 0xCE};
const byte phTwelveIn[] = {0x01, 0x03, 0x00, 0x06, 0x00, 0x01, 0x64, 0x0b};
const byte nitroTwelveIn[] = {0x01, 0x03, 0x00, 0x1E, 0x00, 0x01, 0xE4, 0x0C};
const byte phosTwelveIn[] = {0x01, 0x03, 0x00, 0x1f, 0x00, 0x01, 0xb5, 0xcc};
const byte potaTwelveIn[] = {0x01, 0x03, 0x00, 0x20, 0x00, 0x01, 0x85, 0xc0};
Serial1.begin(9600);
//while (!Serial) {
//; // wait for serial port to connect. Needed for native USB port only
Serial.println("Starting Arduino web client.");
bool connected = false;
while (!connected) {
if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &&
(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
connected = true;
Serial.println("Connnected to network");
Serial.println("Not connected");
pinMode(RE, OUTPUT);
pinMode(DE, OUTPUT);
// put RS-485 into receive mode
digitalWrite(DE, LOW);
digitalWrite(RE, LOW);
delay(3000);
// SIX INCHES
Serial.println("SEIS PULGADAS: ");
float moisture6 = getValue(moisSixIn) / 10;
Serial.print("Humedad 6 en decimal: ");
Serial.println(moisture6);
float ph6 = getValue(phSixIn) / 100;
Serial.print("Ph 6 en decimal: ");
Serial.println(ph6);
uint16_t ec6 = getValue(econSixIn);
Serial.print("EC 6 en decimal: ");
Serial.println(ec6);
uint16_t nitro6 = getValue(nitroSixIn);
Serial.print("Nitro 6 en decimal: ");
Serial.println(nitro6);
uint16_t phos6 = getValue(phosSixIn);
Serial.print("Fosforo 6 en decimal: ");
Serial.println(phos6);
uint16_t pota6 = getValue(potaSixIn);
Serial.print("Potasio 6 en decimal: ");
Serial.println(pota6);
// TWELVE INCHES
Serial.println("DOCE PULGADAS: ");
float moisture12 = getValue(moisTwelveIn) / 10;
Serial.print("Humedad 12 en decimal: ");
Serial.println(moisture12);
float ph12 = getValue(phTwelveIn) / 100;
Serial.print("Ph 12 en decimal: ");
Serial.println(ph12);
uint16_t ec12 = getValue(econTwelveIn);
Serial.print("EC 12 en decimal: ");
Serial.println(ec12);
uint16_t nitro12 = getValue(nitroTwelveIn);
Serial.print("Nitro 12 en decimal: ");
Serial.println(nitro12);
uint16_t phos12 = getValue(phosTwelveIn);
Serial.print("Fosforo 12 en decimal: ");
Serial.println(phos12);
uint16_t pota12 = getValue(potaTwelveIn);
Serial.print("Potasio 12 en decimal: ");
Serial.println(pota12);
performRequest(
moisture6,
ph6,
ec6,
nitro6,
phos6,
pota6,
moisture12,
ph12,
ec12,
nitro12,
phos12,
pota12
// Declarar el tiempo de cada iteración en milisegundos
// 1 minute
delay(5000);
void performRequest(
float moisture6,
float ph6,
uint16_t ec6,
uint16_t nitro6,
uint16_t phos6,
uint16_t pota6,
float moisture12,
float ph12,
uint16_t ec12,
uint16_t nitro12,
uint16_t phos12,
uint16_t pota12
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, port)) {
Serial.println("connected");
String data = "moisture6=" + String(moisture6) +
"&ph6=" + String(ph6) +
"&ec6=" + String(ec6) +
"&nitro6=" + String(nitro6) +
"&phos6=" + String(phos6) +
"&pota6=" + String(pota6) +
"&moisture12=" + String(moisture12) +
"&ph12=" + String(ph12) +
"&ec12=" + String(ec12) +
"&nitro12=" + String(nitro12) +
"&phos12=" + String(phos12) +
"&deviceId=" + "<id>" +
"&pota12=" + String(pota12);
// Make a HTTP request:
client.print("POST ");
client.print(path);
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(server);
client.println("Connection: close");
client.println("Content-Type: application/x-www-form-urlencoded");
client.print("Content-Length: ");
client.println(data.length());
client.println();
client.print(data);
// Read and print the response from the server
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.print(c);
client.stop();
Serial.println("disconnected");
Serial.println("connection failed");
uint16_t getValue(const byte* command) {
uint16_t values[7];
Serial1.flush();
digitalWrite(DE, HIGH);
digitalWrite(RE, HIGH);
delay(1);
for (uint8_t i = 0; i < 8; i++) Serial1.write(command[i]);
Serial1.flush();
delay(200);
for (byte i = 0; i < 7; i++) {
values[i] = Serial1.read();
byte highByte = values[3];
byte lowByte = values[4];
uint16_t value = (highByte << 8) | lowByte;
return value;
For some reason, everything works fine for 3 or 4 days and then it stops sending data. Everytime we check the CHRG orange led is blinking. It's solved by connecting and disconnecting it.
I've seen a lot of posts here but none of them have worked for me. Do you have any idea what could be happening? We're using a 5V usb port to charge the arduino connected to a charger controller, which receives energy from a battery which is also charged by a solar panel.
It's important to mention this happens during the day and night, it doesn't matter.
