MKR GSM 1400 Send SMS COde
Having an issue getting the Arduino to send an SMS once button pressed, then resetting ready to send another SMS when a button is pressed again. The code I am using is below! Thanks
#include <MKRGSM.h>
#include "arduino_secrets.h"
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[] = SECRET_PINNUMBER;
// this constant won't change:
const int  buttonPin = A2;    // the pin that the pushbutton is attached to
const int ledPin = 13;       // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
// initialize the library instance
GSM gsmAccess;
GSM_SMS sms;
// connection state
bool connected = false;
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT_PULLUP);
  // initialize the LED as an output:
  pinMode(ledPin, OUTPUT);
  // initialize serial communication:
  // initialize serial communications and wait for port to open:
  while (!Serial);
  // read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState)  {
    // if the state has changed, increment the counter
    if (buttonState == LOW) {
      // if the current state is HIGH then the button went from off to on:
      buttonPushCounter++;
      Serial.println("Button has been pressed");
      Serial.print("number of button pushes: ");
      Serial.println(buttonPushCounter);
      sendSMS();
      delay (500);
  // save the current state as the last state, for next time through the loop
  lastButtonState = buttonState;
void sendSMS()
  Serial.println("SMS Messages Sender");
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while (!connected) {
    if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
      connected = true;
      Serial.println("Not connected");
      delay(5000);
  Serial.println("GSM initialized");
  const char remoteNum[] = ("xxxxxx");
  // SMS text
  const char txtMsg[] = ("Gate Opened");
  Serial.println("SENDING");
  Serial.println("Message:");
  Serial.println(txtMsg);
  // send the message
  sms.beginSMS(remoteNum);
  sms.print(txtMsg);
  sms.endSMS();
  Serial.println("\nCOMPLETE!\n");
  exit(0);
exit(0); won't help having the code go back to the loop after you send the SMS...
you need better code to handle the button. The easiest way is to use (or study how it's done) a library like OneButton
(don't share your phone number)
Ok,
sorry, forgot to take the phone number out! I will have a look at the library you have suggested
