Hi Forum, I have a question about the MKR wifi 1010 and its cryptochip ECCX08 build in, do someone know how to set tls certs on that chip?.. I found how to auto create them in source code but I really want to do is load my own self signed certs to able connect to a Mosquitto MQTT TLS Broker over a local LAN.. I had tried a lot of ways with no results, on internet there's no enough information able to do that. Anyone knows how to do that?
I tried unluckly with “WiFi1010 / WiFiNINA Firmware/Certificates Updater”
WiFiNINA Firmware Updater
This is the command I wrote in console (Windows 10):
./arduino-fwuploader.exe certificates flash -b arduino:samd:mkrwifi1010 -a COM4 -f c:/certs/ca.crt -f c:/certs/client.crt -f c:/certs/client.key
This one starts and connect with MKR but switch to COM6 and throws an error due to device not found, then I change the command to COM6 and get the error because it switches to COM4..
What I'm doing wrong?
This is the powershell output I got:
PS C:\Users\user\apps\arduino-fwuploader_1.0.0_Windows_64bit> ./arduino-fwuploader.exe certificates flash -b arduino:samd:mkrwifi1010 -a COM4 -f C:\certs\ca.crt
No device found on COM4
Error during certificates flashing: exit status 1
PS C:\Users\user\apps\arduino-fwuploader_1.0.0_Windows_64bit> ./arduino-fwuploader.exe certificates flash -b arduino:samd:mkrwifi1010 -a COM6 -f C:\certs\ca.crt
Set binary mode
readWord(addr=0)=0x20007ffc
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v2.0 [Arduino:XYZ] Mar 19 2018 09:45:14
chipId=0x10010005
Connected at 921600 baud
Atmel SMART device 0x10010005 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Mar 19 2018 09:45:14
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security : false
Boot Flash : true
readWord(addr=0x40000834)=0x7000a
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 1.077 seconds
Write 13688 bytes to flash (214 pages)
write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x1000)
[======== ] 29% (64/214 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x3000, size=0x1000)
[================= ] 59% (128/214 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x4000, size=0x1000)
[========================== ] 89% (192/214 pages)write(addr=0x20005000,size=0x580)
writeBuffer(scr_addr=0x20005000, dst_addr=0x5000, size=0x580)
[==============================] 100% (214/214 pages)
done in 0.223 seconds
Verify 13688 bytes of flash with checksum.
checksumBuffer(start_addr=0x2000, size=0x1000) = 828d
checksumBuffer(start_addr=0x3000, size=0x1000) = 746f
checksumBuffer(start_addr=0x4000, size=0x1000) = db2
checksumBuffer(start_addr=0x5000, size=0x578) = 1ec5
Verify successful
done in 0.079 seconds
CPU reset.
writeWord(addr=0xe000ed0c,value=0x5fa0004)
Error during certificates flashing: Serial port not found
