Greetings to all,
I have a problem with my MKR1000. Im trying to make a tcp server in AP Mode. The Wifi network in AP Mode is created successfully. The first time i connected to the tcp server with code in my laptop the connection is made normally. After that i disconnect from AP, reconnect to it, and then i try to make a new tcp connection to the MKR1000 resulting in a timeout connection from my laptop.
Is there any problem with mkr1000 tcp server in AP mode?
Are you on the latest FIRMWARE and BOARDS ?
You might want to post the sketch also so somebody else can try it and see if its an issue there.
BTW use code tags to post any code / errors / text files ( </> )
Thanks for your response. Im using the latest firmware on MKR1000
The code is the a modification of the AP example for MKR1000:
#include <SPI.h>
#include <WiFi101.h>
int led = LED_BUILTIN;
char ssid[] = "TESTAP"; // created AP name
char pass[] = "1020304050"; // AP password (needed only for WEP, must be exactly 10 or 26 characters in length)
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
//Initialize serial and wait for port to open:
while (!Serial);
Serial.println("Access Point Server");
pinMode(led, OUTPUT); // set the LED pin mode
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue
while (true);
// by default the local IP address of will be 192.168.1.1
// you can override it with the following:
WiFi.config(IPAddress(10, 0, 0, 1));
// print the network name (SSID);
Serial.print("Creating access point named: ");
Serial.println(ssid);
// Create open network. Change this line if you want to create an WEP network:
status = WiFi.beginAP(ssid,keyIndex,pass);
if (status != WL_AP_LISTENING) {
Serial.println("Creating access point failed");
// don't continue
while (true);
// wait 10 seconds for connection:
//delay(10000);
// start the server on port 9000
server.begin();
// compare the previous status to the current status
if (status != WiFi.status()) {
// it has changed update the variable
status = WiFi.status();
if (status == WL_AP_CONNECTED) {
Serial.println("Device connected to AP");
// a device has disconnected from the AP, and we are back in listening mode
Serial.println("Device disconnected from AP");
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
currentLine = "";
} else { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// close the connection:
client.flush();
client.stop();
Serial.println("client disconnected");
Try adding:
server.begin(); // <- NEW LINE
Once the AP connection is lost, the server socket is no longer valid.
Thanks sandeepmistry!!!!, i havent see that point. With the line added it works perfectly.
Greetings
