MKR1010 to AWS Core IoT
Hi All,
I will start by apologizing. There has been similar requests before, but I just cannot find a solution that works. So sorry if this is a duplicate of previous questions. Please help.
I followed everything in the AWS tutorial, but I only get the following:
NB XXXX I removed my personal info.
"You're connected to the network
Attempting to MQTT broker: XXXXX-ats.iot.ap-southeast-2.amazonaws.com
Here is the code:
#include <ArduinoBearSSL.h>
#include <ArduinoECCX08.h>
#include <ArduinoMqttClient.h>
#include <WiFiNINA.h> // change to #include <WiFi101.h> for MKR1000
#include "arduino_secrets.h"
/////// Enter your sensitive data in arduino_secrets.h
const char ssid[]        = SECRET_SSID;
const char pass[]        = SECRET_PASS;
const char broker[]      = SECRET_BROKER;
const char* certificate  = SECRET_CERTIFICATE;
WiFiClient    wifiClient;            // Used for the TCP socket connection
BearSSLClient sslClient(wifiClient); // Used for SSL/TLS connection, integrates with ECC508
MqttClient    mqttClient(sslClient);
unsigned long lastMillis = 0;
  while (!Serial);
  if (!ECCX08.begin()) {
    Serial.println("No ECCX08 present!");
    while (1);
  // Set a callback to get the current time
  // used to validate the servers certificate
  ArduinoBearSSL.onGetTime(getTime);
  // Set the ECCX08 slot to use for the private key
  // and the accompanying public certificate for it
  sslClient.setEccSlot(0, certificate);
  // Optional, set the client id used for MQTT,
  // each device that is connected to the broker
  // must have a unique client id. The MQTTClient will generate
  // a client id for you based on the millis() value if not set
  mqttClient.setId("iotconsole-XXXXXXXX");
  // Set the message callback, this function is
  // called when the MQTTClient receives a message
  mqttClient.onMessage(onMessageReceived);
  if (WiFi.status() != WL_CONNECTED) {
    connectWiFi();
  if (!mqttClient.connected()) {
    // MQTT client is disconnected, connect
    connectMQTT();
  // poll for new MQTT messages and send keep alives
  mqttClient.poll();
  // publish a message roughly every 5 seconds.
  if (millis() - lastMillis > 5000) {
    lastMillis = millis();
    publishMessage();
unsigned long getTime() {
  // get the current time from the WiFi module
  return WiFi.getTime();
void connectWiFi() {
  Serial.print("Attempting to connect to SSID: ");
  Serial.print(ssid);
  Serial.print(" ");
  while (WiFi.begin(ssid, pass) != WL_CONNECTED) {
    // failed, retry
    Serial.print(".");
    delay(5000);
  Serial.println("You're connected to the network");
void connectMQTT() {
  Serial.print("Attempting to MQTT broker: ");
  Serial.print(broker);
  Serial.println(" ");
  while (!mqttClient.connect(broker, 8883)) {
    // failed, retry
    Serial.print(".");
    delay(5000);
  Serial.println("You're connected to the MQTT broker");
  // subscribe to a topic
  mqttClient.subscribe("arduino/incoming");
void publishMessage() {
  Serial.println("Publishing message");
  // send message, the Print interface can be used to set the message contents
  mqttClient.beginMessage("arduino/outgoing");
  mqttClient.print("hello ");
  mqttClient.print(millis());
  mqttClient.endMessage();
void onMessageReceived(int messageSize) {
  // we received a message, print out the topic and contents
  Serial.print("Received a message with topic '");
  Serial.print(mqttClient.messageTopic());
  Serial.print("', length ");
  Serial.print(messageSize);
  Serial.println(" bytes:");
  // use the Stream interface to print the contents
  while (mqttClient.available()) {
    Serial.print((char)mqttClient.read());
Read the pinned post re 'How to get the most from the forum'
@sonofcy Not sure what your reply is supposed to mean. I explained that although there has been similar questions asked, I have not been able to get a resolution. Not sure what you are implying I did wrong.
It means there is information there that will get you better help.
