MKR1200 stacking original MKR GPS and IMU shields
Hi all,
Is it possible to stack up both shields GPS and IMU on the same MKR board?
Thanks in advance, regards, Theo
Yes, you can do that. The MKR GPS Shield uses pins 7, 13, and 14. The MKR IMU Shield uses pin 0 and the I2C bus (pins 11 and 12). So there is no conflict between the two shields.
Hi , if you use mkrgps not stacked but connected via the 4 wire cable provided to a mkrgsm what are the pin used?
