MLX90316 Magnetic Rotary input signal
Hi guys,
I am having some issues with a MLX90316 Magnetic Rotary on an Arduino UNO.
The code I am using is
/* MLX90316 Rotary Position Sensor
* KHM 2010 /  Martin Nawrath
* Kunsthochschule fuer Medien Koeln
* Academy of Media Arts Cologne
* MLX90316KDC-BDG-100-RE Rotary Position Sensor
* K=Temperature Range -40ºC to 125ºC
* DC = SOIC150
* BDG = SPI Version
* 100 = SPI
* RE = Reel
* MOSI (Master Out Slave In) the master sends a commant to the slave to get the angle out.
* MLX90316.cpp sets _SS, SCLK, and MOSI to OUTPUT in beginning, sets MOSI to INPUT at the end.
* readAngle is 10 x angle, thus 3600 is 360.0º
// in this sketch the sensor does not communicates using the "SPI.h library"
#include "Metro.h"     //Include Metro library
#include "MLX90316.h"  // Include MLX90316 library
int pin_SS = 10;  // White Wire
int pinSCLK = 13; // Violet Wire
int pinMOSI = 11; // Grey Wire
int ii;
int angle;
Metro mlxMetro = Metro(5);
MLX90316 mlx_1  = MLX90316();
void setup(){
  Serial.begin(115200); //Initializes the SPI bus by setting SCK, MOSI, and SS to outputs, pulling SCK and MOSI low, and SS high.
  mlx_1.attach(pin_SS,pinSCLK, pinMOSI );
  Serial.println(" MLX90316 Rotary Position Sensor");
  if (mlxMetro.check() == 1) {
    ii = mlx_1.readAngle();
    angle = ii/10; //readAngle gives 10 * degrees, thus 3600 = is 360.0º
    /* if ii = -1 then no SPI signal
     * if ii = -2 then signal too strong
     * if ii = -3 then signal too weak
     * "angle" will read 0 if signal is lost
    Serial.print(angle);
    Serial.println("");
  MLX90316.cpp -  Library to use with Melexis MLX90316 rotary encoder chip.
  Created by Martin Nawrath KHM 2010.
  http://interface.khm.de
  Released into the public domain.
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
// constructor
MLX90316::MLX90316(){
// attach
void MLX90316::attach(int pinSS, int pinSCK, int pinMOSI )
	_pinSS = pinSS;
	_pinSCK = pinSCK;
	_pinMOSI = pinMOSI;
	pinMode(_pinSS , OUTPUT);
	pinMode(_pinSCK , OUTPUT);
	pinMode(_pinMOSI , OUTPUT);
int MLX90316::readAngle() {
  byte bb;
  int ret=-1;
  unsigned int rr;
  long int lo;
  digitalWrite(_pinSS,0);
  delay(2);
  bb=_spiByte(0x55);  // send sync byte ( AA reversed order = 55?)
  bb=_spiByte(0xFF);  // send sync byte FF)
  bb=_spiByte(0xFF); // receive 1. byte of mlx msb data
   rr= (bb << 8);
   bb=_spiByte(0xFF); // receive 2. byte of lsb mlx data
   rr=rr+bb;
  if ((rr & 3) == 2) {
    if ( rr & (1 << 4)) ret=-2;  // signal to strong
    if ( rr & (1 << 5)) ret=-3;  // signal to weak
  if ((rr & 3) == 1) { // valid angle data ?
     rr = (rr >> 2);
     lo= rr ;
     lo=lo *  3600 / 16384;	// scale output to 360 deg, units in tens of deg.
    ret= lo;
  digitalWrite(_pinSS,1);
  return(ret);
// send and receive SPI byte  to/from MLX90316 Chip
uint8_t  MLX90316::_spiByte(uint8_t  tx) {
  byte rxb=0;
  for (int ix = 0; ix < 8; ix++){  // receive/transmit 8 SPI bits
    digitalWrite(_pinMOSI,0);   // turn port internal pullup resistor off
    pinMode(_pinMOSI,OUTPUT);   // switch MOSI pin to output
    // write SPI transmit bit to sensor
    if ((tx & 1) != 0) digitalWrite(_pinMOSI,1);
    else digitalWrite(_pinMOSI,0);
    tx= ( tx >> 1);
    pinMode(_pinMOSI,INPUT);    // switch MOSI pin to input
    digitalWrite(_pinMOSI,1);   // turn port internal pullup resistor on
    digitalWrite(_pinSCK,1);    // clocksignal positive slope
    digitalWrite(_pinSCK,0);   // clocksignal negative slope
    rxb = ( rxb << 1);           // shift received byte left
    if (digitalRead(_pinMOSI) ==1) rxb = rxb | 1; // read respose bit from sensor
  return(rxb);
I have the output of the rotary connected to pin 11, the /SS to pin 10, and SCLK to pin 13.
On the serial monitor, I am receiving straight '1's or if the rotary is turned to a certain position, I get all '0's. I thought the code was right...
That is not even close to what that code does.
Sorry that comment was for the full setup() function. But you are right, I forgot to put the digitalWrite() functions in the attach() to set the outputs of those settings. However after adding this, there is no difference.
Then it does NOT belong after a line of code. Comments CAN be on lines by themselves. All useful ones are.
The code is a very convoluted way of communicating with a standard SPI device.
