Mobatools stepper print current position?
How can I serial print the current position of my stepper after I jog it from the home zero position? It doesn't have to count/show every single step but just show where it ended after I release the jog button. This way I can use this position data in future programing. Here's my code showing my attempt to do this on my CW button at line 173. I added line 39 also. This doesn't work as it only prints one step every time I hit the button.
#define MAX8BUTTONS // saves RAM because only 4 switches are used
#define MAX_STEPPER 6
#include <MobaTools.h>
const int STEPS_PER_REV = 800;
const int POS_MAX = 20000;
const int FORTY_METER_POSITION = 5000;
const int EIGHTY_METER_POSITION = 10000;
const int ONESIXTY_METER_POSITION = 16000;
//create stepper object ( 800 steps / rev - 1/4 microstep )
// Stepper 1 buffer tank
const byte stepper1_pul = 2;
const byte stepper1_dir = 3;
MoToStepper stepper_1( STEPS_PER_REV, STEPDIR );
// Stepper 2 IPA tank
const byte stepper2_pul = 4;
const byte stepper2_dir = 5;
MoToStepper stepper_2( STEPS_PER_REV, STEPDIR );
const byte enaPin = 7;
// buttons must switch to Gnd
enum { buttonZero, buttonCW, buttonCCW, forty_meter_button, eighty_meter_button, onesixty_meter_button } ; // create names for the buttons
const byte buttonPins[] = {22, 23, 24, 26, 27, 28 }; // assign pins to the buttons
const byte buttonCnt = sizeof(buttonPins);
MoToButtons myButton( buttonPins, buttonCnt, 20, 500 );
// limit switch at refpoint
const byte refPin1 = 25;         // limit pin stepper 1 homing
const byte refPin2 = 29;         // limit pin stepper 2 homing
const byte atRefpoint = LOW;   // dependig wether it is a NO or NC switch
int stepCount = 0;
  Serial.begin(115200); while (!Serial);
// Stepper 1
  stepper_1.attach( stepper1_pul, stepper1_dir );
  stepper_1.attachEnable( enaPin, 10, LOW );        // Enable active
// Stepper 2
  stepper_2.attach( stepper2_pul, stepper2_dir );
  stepper_2.attachEnable( enaPin, 10, LOW );        // Enable active
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(refPin1, INPUT_PULLUP );
  pinMode(refPin2, INPUT_PULLUP );
  Serial.println("Starting loop");
  myButton.processButtons();          // reading and processing the buttons ( e.g. debouncing and state change detection)
  digitalWrite( LED_BUILTIN, digitalRead( refPin1 ) );
    // check buttons and react accordingly
  if ( myButton.pressed(buttonZero) ) {                                   // home all steppers to zero position
    Serial.println(" Find ref point");
    toRefPoint();
  if ( myButton.pressed(buttonCW) ) {                                     // jog slow clockwise direction
    Serial.println("Jog CW towards end");
    toCWdirection();
  if ( myButton.pressed(buttonCCW) ) {                                    // jog slow counter clockwise direction
    Serial.println("Jog CCW back to 0 ");
    toCCWdirection();
  if ( myButton.pressed(forty_meter_button) ) {                           // move to 40m position
    Serial.println("Move towards the 40M position");
    toFortyPoint();
   if ( myButton.pressed(eighty_meter_button) ) {                         // move to 80m position
    Serial.println("Move towards the 80M position");
    toEightyPoint();
    if ( myButton.pressed(onesixty_meter_button) ) {                       // move to 160m position
    Serial.println("Move towards the 160M position");
    toOnesixtyPoint();
  if ( myButton.released(buttonCW) || myButton.released(buttonCCW) ) {
    Serial.println("Stop the stepper");
    stepper_1.rotate(0);
void toRefPoint() {                                   // Homing: move all steppers to ref point and set zeropoint
  Serial.println("homing buffer tank...");               // buffer tank start homing...
  if ( digitalRead( refPin1 ) != atRefpoint ) {       // quick move to ref point it it's not already there
    Serial.println("Quick move to limit switch");
    stepper_1.setSpeedSteps( 10000, 200 );
    stepper_1.rotate(-1);
    while ( digitalRead( refPin1 ) != atRefpoint );
  Serial.println("ref point reached, stop the stepper");
  while ( stepper_1.moving() );                      // wait till stop
  Serial.println("move slowly back to the switching point of the limit switch");
  stepper_1.setSpeedSteps( 500 );
  stepper_1.setRampLen(0);
  stepper_1.rotate( 1 );
  while ( digitalRead( refPin1 ) == atRefpoint );
  Serial.println("Switch point reached - set zero");
  stepper_1.setZero();
  stepper_1.moveTo(0);
  Serial.println("homing buffer tank finished!");
Serial.println("homing IPA tank...");                    // IPA tank start homing...
  if ( digitalRead( refPin2 ) != atRefpoint ) {       // quick move to ref point it it's not already there
    stepper_2.setSpeedSteps( 10000, 200 );
    stepper_2.rotate(-1);
    while ( digitalRead( refPin2 ) != atRefpoint );
  digitalWrite( LED_BUILTIN, digitalRead( refPin2 ) );
  stepper_2.rotate(0);
  while ( stepper_2.moving() );                      // wait till stop
  stepper_2.setSpeedSteps( 500 );
  stepper_2.setRampLen(0);
  stepper_2.rotate( 1 );
  while ( digitalRead( refPin2 ) == atRefpoint );
  stepper_2.setZero();
  stepper_2.moveTo(0);
  Serial.println("IPA tank homing finished!");
void toFortyPoint() {                                  // buffer tank 40 meter position
    stepper_1.setSpeedSteps( 40000, 500 );
    stepper_1.moveTo( FORTY_METER_POSITION );
void toEightyPoint() {                                 // buffer tank 80 meter position
    stepper_1.moveTo( EIGHTY_METER_POSITION );
void toOnesixtyPoint() {                               // buffer tank 160 meter position
    stepper_1.moveTo( ONESIXTY_METER_POSITION );
void toCWdirection() {                                 // buffer tank jog CW
    stepper_1.setSpeedSteps( 5000, 0 );
    stepper_1.moveTo(20000);
    Serial.print("steps:");
  Serial.println(stepCount);
  stepCount++;
void toCCWdirection() {                                // buffer tank jog CCW
@MicroBahner Another one for you ?
You can read the actual position at any time with the stepper_1.readSteps() function.
@UKHeliBob Thanks :wink:
Hi @electrotech173 ,
and here an example:
  Forum: https://forum.arduino.cc/t/mobatools-stepper-print-current-position/1213698/3
  Wokwi: https://wokwi.com/projects/387465608087734273
  Serial.println("Start");
// Stepper 1
  stepper_1.moveTo(1000);
  while (stepper_1.moving()){
    Serial.println(stepper_1.readSteps());
see GetStepperPos - Wokwi ESP32, STM32, Arduino Simulator
Thank you!
Thank you for your help! I will try this out.
