Weller
1
Hi, i'm trying to communicate with a MODBUS slave device. The data sheet shows the protocol to be:
Modbus ASCII
RS-485
9600 bps baud rate
1 start bit, 7 data bits, no parity, 2 stop bits
LRC (Longitudinal Redundancy Check)
Presumably I will need a RS485 breakout to convert the Arduino's UART serial to RS-485?
What about the frame format? I think the Arduino is set to 8N1, so I need to somehow change that to 1 start bit, 7N1.
How do I go about changing this? Can it even be done?
You can simulate 7N2 with 8N1 by always setting the most significant bit to 1 for each byte sent.
Weller
3
Thanks Louis, how do I set the MSB to 0? Is that really all I need to do?
system
4
For 25 LEDs you only need 4 shift registers.
Where did 25 LEDs get mentioned? Or shift registers?
That was another thread
He said "setting the most significant bit to 1" BTW.
For every byte you send OR it with 0x80. Eg
send_modbus_byte (my_byte | 0x80);
Should be.
Rob
system
7
Did you find a library you liked for modbus communication yet?
