I have a motor controller EM-282c-48 that I would like to interface using the Modbus protocol.
After playing with multiple libraries I am having no success in receiving information from the controller, I have plugged in the official interface unit which is based on 386p and works as expected verifying the controller is outputting data.
I have attached the PDF protocol sheet from the manufacture.
Here is the example from the library I'm trying to use, but I really am open to anything.
* Modbus master example 2:
* The purpose of this example is to query an array of data
* from an external Modbus slave device.
* This example is similar to "simple_master", but this example
* allows you to use software serial instead of hardware serial
* in case that you want to use D1 & D2 for other purposes.
* The link media can be USB or RS232.
The circuit:
* software serial rx(D3) connect to tx pin of another device
* software serial tx(D4) connect to rx pin of another device
* In this example, we will use two important methods so that we can use
* software serial.
* 1. Modbus::Modbus(uint8_t u8id)
* This is a constructor for a Master/Slave through USB/RS232C via software serial
* This constructor only specifies u8id (node address) and should be only
* used if you want to use software serial instead of hardware serial.
* This method is called if you create a ModBus object with only on parameter "u8id"
* u8id is the node address of the arduino that will be programmed on,
* 0 for master and 1..247 for slave
* for example: Modbus master(0);
* If you use this constructor you have to begin ModBus object by
* using "void Modbus::begin(SoftwareSerial *softPort, long u32speed)".
* 2. void Modbus::begin(SoftwareSerial *sPort, long u32speed)
* Initialize class object.
* This is the method you have to use if you construct the ModBus object by using
* Modbus::Modbus(uint8_t u8id) in order to use software serial and to avoid problems.
* You have to create a SoftwareSerial object on your own, as shown in the example.
* sPort is a pointer to your SoftwareSerial object, u32speed is the baud rate, in
* standard increments (300..115200)
created long time ago
by smarmengol
modified 29 July 2016
by Helium6072
This example code is in the public domain.
#include <ModbusRtu.h>
#include <SoftwareSerial.h>
// data array for modbus network sharing
uint16_t au16data[16];
uint8_t u8state;
SoftwareSerial mySerial(8, 9);//Create a SoftwareSerial object so that we can use software serial. Search "software serial" on Arduino.cc to find out more details.
* Modbus object declaration
* u8id : node id = 0 for master, = 1..247 for slave
* port : serial port
* u8txenpin : 0 for RS-232 and USB-FTDI
* or any pin number > 1 for RS-485
Modbus master(0, mySerial); // this is master and RS-232 or USB-FTDI via software serial
* This is an structe which contains a query to an slave device
modbus_t telegram;
unsigned long u32wait;
mySerial.begin(9600);//use the hardware serial if you want to connect to your computer via usb cable, etc.
master.start(); // start the ModBus object.
master.setTimeOut( 2000 ); // if there is no answer in 2000 ms, roll over
u32wait = millis() + 1000;
u8state = 0;
switch( u8state ) {
case 0:
if (millis() > u32wait) u8state++; // wait state
case 1:
Serial.println("QUERY");
telegram.u8id = 1; // slave address
telegram.u8fct = 4; // function code (this one is registers read)
telegram.u16RegAdd = 41201; // start address in slave
telegram.u16CoilsNo = 3; // number of elements (coils or registers) to read
telegram.au16reg = au16data; // pointer to a memory array in the Arduino
master.query( telegram ); // send query (only once)
u8state++;
case 2:
master.poll(); // check incoming messages
if (master.getState() == COM_IDLE) {
u8state = 0;
u32wait = millis() + 2000;
Serial.println(au16data[0]);//Or do something else!
Serial.println(au16data[1]);//Or do something else!
Serial.println(au16data[2]);//Or do something else!
Serial.println(au16data[3]);//Or do something else!
Serial.println(au16data[4]);//Or do something else!
Serial.println(au16data[5]);//Or do something else!
Modbus_common_part_12.8.2019.pdf (392 KB)
