Modbus Register Map
Anyone have a Modbus register map?
Can't connect to input registers or holding registers with qmodmaster or modbus poll.
The register map is unique to each device. It is usually defined in the communication section of the user manual specific to the product you have.
Unless I'm missing something, I haven't it for the Opta yet.
Sorry, I think my previous response was a bit too brief.
If the registers you are trying to read are within the Arduino Opta (Opta acting as a modbus slave device), then your code will define the registers that are implemented for each function code.
I don't have specific experience of an Opta, only using an UNO as a modbus slave.
Are there any examples specific to Opta that Arduino provide that would give you a head start?
EDIT: I found this link that may help you:
I am using my Opta as a slave, and can write coils and read discrete inputs no problem using Modbus TCP - no code in sketch at all.
Same can't be said for the analog inputs (input registers I think?), and I don't think I would need lines of code just for analog values.
Thoughts?
