Modbus RTU data to web page gauges
Hi all!
Thanks for your time in advanced, any guidance and suggestions are appreciated.
I’m a self taught and thanks to many like you with their patience and guidance have learned to use Arduino IDE.
For this project I wanted to use canvas gauges to display data from an analog pot attached to the NodeMcu. After lots of reading from different post I was able to make it work!
Will post the sketch and picture of the gauge when I get home today.
So, since that’s done. Now I would like to get data from an RS485 Modbus RTU device and display it on the gauge. Humm but I have no clue on how to store that data on an array then send it to the server then display it on the gauge.
Yup, JavaScript and html will be used on the server side.
here is the link to the Video.
Analog read to gauge
the Ino file:
const char* htmlfile = "/index.html";
          //WiFi Connection configuration
const char *ssid = "My Wifi";
const char *password = "123456789";
  ESP8266WebServer server(80);
void handleADC(){
  int a = analogRead(A0);
  a = map(a,0,1023,0,100);
  String adc = String(a);
  Serial.println(adc);
  server.send(200, "text/plane",adc); //sends data to server
void handleRoot(){
  server.sendHeader("Location", "/index.html",true);   //Redirect to our html web page
  server.send(302, "text/plane","");
void handleWebRequests(){
  if(loadFromSpiffs(server.uri())) return;
  String message = "File Not Detected\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET)?"GET":"POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  for (uint8_t i=0; i<server.args(); i++){
    message += " NAME:"+server.argName(i) + "\n VALUE:" + server.arg(i) + "\n";
  server.send(404, "text/plain", message);
  Serial.println(message);
             //Initialize File System
  SPIFFS.begin();
  Serial.println("File System Initialized");
  Serial.print("Setting AP (Access Point)…");
             //Connect to wifi Network
  WiFi.mode(WIFI_AP);           //Only Access point
  WiFi.softAP(ssid, password);   //Start HOTspot
      //If connection successful show IP address in serial monitor
  Serial.print("Connected to: ");
  Serial.println(ssid);
  IPAddress IP = WiFi.softAPIP();
  Serial.print("Server IP address: ");
  Serial.println(IP);
              //Initialize Webserver
  server.on("/",handleRoot);
  server.on("/getADC",handleADC); //Reads ADC function is called from out index.html
  server.onNotFound(handleWebRequests); //Set setver all paths are not found so we can handle as per URI
  server.begin();
  Serial.println("HTTP server started");
 server.handleClient();
bool loadFromSpiffs(String path){
  String dataType = "text/plain";
  if(path.endsWith("/")) path += "index.htm";
  if(path.endsWith(".src")) path = path.substring(0, path.lastIndexOf("."));
  else if(path.endsWith(".html")) dataType = "text/html";
  else if(path.endsWith(".htm")) dataType = "text/html";
  else if(path.endsWith(".css")) dataType = "text/css";
  else if(path.endsWith(".js")) dataType = "application/javascript";
  else if(path.endsWith(".png")) dataType = "image/png";
  else if(path.endsWith(".gif")) dataType = "image/gif";
  else if(path.endsWith(".jpg")) dataType = "image/jpeg";
  else if(path.endsWith(".ico")) dataType = "image/x-icon";
  else if(path.endsWith(".xml")) dataType = "text/xml";
  else if(path.endsWith(".pdf")) dataType = "application/pdf";
  else if(path.endsWith(".zip")) dataType = "application/zip";
  File dataFile = SPIFFS.open(path.c_str(), "r");
  if (server.hasArg("download")) dataType = "application/octet-stream";
  if (server.streamFile(dataFile, dataType) != dataFile.size()) {
  dataFile.close();
  return true;
this is where the analog reading is received and sent to the server:
void handleADC(){
