Hi everyone, I am using an Arduino R4 WIFI as Modbus Slave and S7-1200 PLC as Modbus Master.
So my problem is not to get the communication working. When starting up the PLC and the Arduino the Modbus communication works fine for some time however then it would just freeze up for some reason. Sometimes it would be good for up to 3 days and then just stop. The only way to restart it is to do a hard reset of the PLC.
Below is my code. Hopefully someone can see something in the code that would cause this as I am at my wits end with this.
Let me know if you need to see the TIA portal code.
#include <Modbus.h>
#include <ModbusIP.h>
#include <Ethernet.h>
#include "arduino_secrets.h"
#include "thingProperties.h"
#include "SPI.h"
int setpoint;
const int setPoint_IR = 100;
const int slider_mb = 101;
const int spare_001 = 102;
const int switch_001 = 103;
const int switch_002 = 104;
const int switch_003 = 105;
const int switch_004 = 106;
const int switch_005 = 107;
const int hold_001 = 108;
const int hold_002 = 109;
const int hold_003 = 110;
const int hold_004 = 111;
const int hold_005 = 112;
const int read_001 = 113;
const int read_002 = 114;
const int read_003 = 115;
const int read_004 = 116;
const int read_005 = 117;
ModbusIP mb;
const int analogInPin = A0;
const int flowSensorPin = 2;
const int flowSensorPin2 = 3;
const int analogOutPin = 9;
const int alarmTriggerPin = 4; // Digital pin for alarm trigger input
const int alarmSetPin = 5; //Digital pin for alarm se/unset input
int sensorValue = 0;
int outputValue = 0;
bool alertSent = false;
unsigned long lastReadTime = 0;
int alarmsetInt = alarmset ? 1:0;
int lightOnInt = lightOn ? 1:0;
volatile unsigned long pulseCount = 0;
volatile unsigned long pulseCount2 = 0;
unsigned long oldTime = 0;
float calibrationFactor = 5.5;
float flowRate = 0.0;
float flowRate2 = 0.0;
unsigned long lastModbusResetTime = 0;
const unsigned long modbusResetInterval = 3600000; // 60 mins in milliseconds
// Define MAC and IP globally for reuse in reset function
byte mac[] = {0xDE, 0xAD,0xBE,0xEF,0xFE,0xED};
byte ip[] {192,168,3,120};
const unsigned long readInterval = 500; // Read every 500ms
int lastAlarmSetState = HIGH;// Store the last alarm set input state (HIGH because of pull-up)
int lastAlarmState = HIGH; // Store the last alarm input state (HIGH because of pull-up)
// Variables for the burglar alarm delay
unsigned long alarmTriggerTime = 0;
const unsigned long alarmDelay = 5000; // 5 seconds in milliseconds
bool alarmTriggering = false;
unsigned long highFlowStartTime = 0;
bool highFlowActive = false;
const unsigned long highFlowThresholdTime = 1800000; // 30 minutes in milliseconds
const float highFlowThreshold = 5.0;
unsigned long burglarAlarmBlinkTimer = 0;
const unsigned long burglarAlarmBlinkInterval = 30000;
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Setup the alarm trigger pin as input with pullup
pinMode(alarmTriggerPin, INPUT_PULLUP);
pinMode(alarmSetPin, INPUT_PULLUP);
pinMode(flowSensorPin, INPUT);
pinMode(flowSensorPin2, INPUT);
attachInterrupt(digitalPinToInterrupt(flowSensorPin),pulseCounter, FALLING);
attachInterrupt(digitalPinToInterrupt(flowSensorPin2),pulseCounter2, FALLING);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
// Enter mac and ip data hier (moenie vergeet nie!)
// byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// byte ip[] = { 192, 168, 3, 120 };
mb.config(mac, ip);
mb.addHreg(setPoint_IR);
mb.addHreg(slider_mb);
mb.addHreg(spare_001);
mb.addHreg(switch_001);
mb.addHreg(switch_002);
mb.addHreg(switch_003);
mb.addHreg(switch_004);
mb.addHreg(switch_005);
mb.addHreg(hold_001);
mb.addHreg(hold_002);
mb.addHreg(hold_003);
mb.addHreg(hold_004);
mb.addHreg(hold_005);
mb.addHreg(read_001);
mb.addHreg(read_002);
mb.addHreg(read_003);
mb.addHreg(read_004);
mb.addHreg(read_005);
void pulseCounter() {pulseCount++; }
void pulseCounter2() {pulseCount2++;}
mb.task();
setpoint = analogRead(A0);
mb.Hreg(setPoint_IR, threshold_value);
mb.Hreg(slider_mb,test_value_001);
mb.Hreg(switch_001,alarmsetInt);
mb.Hreg(switch_002,lightOnInt);
mb.Hreg(hold_002, flowRate);
mb.Hreg(hold_003, flowRate2);
battery_voltage = mb.Hreg(read_001);
total_water_per_day = mb.Hreg(read_002);
total_water_per_week = mb.Hreg(read_003);
comms_count_01 = mb.Hreg(read_004);
if ((millis() - oldTime) > 1000) {
detachInterrupt(digitalPinToInterrupt(flowSensorPin));
detachInterrupt(digitalPinToInterrupt(flowSensorPin2));
flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
water_flow_rate = flowRate;
flowRate2 = ((1000.0/ (millis() - oldTime)) * pulseCount2) / calibrationFactor;
oldTime = millis();
water_flow_02 = flowRate2;
pulseCount = 0;
pulseCount2 = 0;
attachInterrupt(digitalPinToInterrupt(flowSensorPin), pulseCounter, FALLING) ;
attachInterrupt (digitalPinToInterrupt(flowSensorPin2), pulseCounter2, FALLING);
// Check for high water flow condition
if (flowRate > highFlowThreshold) {
if (!highFlowActive){
// First time flow exceeds threshold
highFlowActive = true;
highFlowStartTime = millis();
else if (millis() - highFlowStartTime > highFlowThresholdTime){
// Flow has been high for more than 30 minutes
water_use_high = true;
else {
// Reset when flow drops below threshold
water_use_high = false;
// Burglar alarm cycling logic
if (alarmactivated) {
if (currentMillis - burglarAlarmBlinkTimer >= burglarAlarmBlinkInterval){
burglarAlarmBlinkTimer = currentMillis;
burglaralarm = !burglaralarm; // Toggle the alarm state
// DisplaySetPointValues();
delay(200);
ArduinoCloud.update();
// Read digital alarm input (LOW when triggered because of pull-up)
int alarmState = digitalRead(alarmTriggerPin);
int alarmSetState = digitalRead(alarmSetPin);
// Burglar alarm logic - detect when pin is held LOW for more than 5 seconds
if (alarmState == LOW) { // Input is active (LOW with pull-up)
if (!alarmTriggering) {
// First time we detect the alarm is active
alarmTriggering = true;
alarmTriggerTime = currentMillis;
Serial.println("Alarm input activated, waiting for 5 seconds to confirm...");
} else if (currentMillis - alarmTriggerTime >= alarmDelay) {
// Input has been active for more than 5 seconds
if (!burglaralarm) {
burglaralarm = true;
alarmactivated = true;
Serial.println("BURGLAR ALARM ACTIVATED! Input held for 5+ seconds");
// Input is inactive (HIGH), reset the trigger state
if (alarmTriggering) {
burglaralarm = false;
alarmactivated = false;
Serial.println("Alarm input deactivated before timeout");
if (currentMillis - lastReadTime >= readInterval) {
lastReadTime = currentMillis;
// Read sensor value
sensorValue = analogRead(analogInPin);
variable_Input_001 = sensorValue;
Serial.print("Sensor = ");
Serial.println(sensorValue);
// Check if value exceeds threshold and email alert hasn't been sent yet
if (sensorValue >= threshold_value && !alertSent) {
alert_email = true; // This will trigger the email notification
alertSent = true; // Prevent multiple alerts
Serial.println("Alert triggered!");
// Reset the alert flag if value goes below threshold
if (sensorValue < threshold_value && alertSent) {
alert_email = false;
alertSent = false;
Serial.println("Alert reset");
// If alarm set state changed
if (alarmSetState != lastAlarmSetState){
lastAlarmSetState = alarmSetState;
if (alarmSetState== LOW) { // Input is LOW when button is pressed (with Pull-up)
alarm_is_set = true;
Serial.println("Alarm system is now SET");
alarm_is_set = false;
Serial.println ("Alarm system is now UNSET");
// If alarm state changed
if (alarmState != lastAlarmState) {
lastAlarmState = alarmState;
if (alarmState == LOW) { // Input is LOW when button is pressed (with pull-up)
aLARM = true;
Serial.println("aLARM triggered by digital input!");
aLARM = false;
Serial.println("aLARM reset by digital input");
// Check if time to reset Modbus connection
if (currentMillis - lastModbusResetTime >= modbusResetInterval){
Serial.println("Resetting Modbusconnection...");
mb.config(mac, ip); // Reinitialize the connection
lastModbusResetTime = currentMillis;
Serial.println("Modbus connection reset complete");
// void DisplaySetPointValues() {
// String Printstr;
// Printstr = "SetPoint Value = " + String(setpoint);
// Serial.println(Printstr);
// Existing cloud callback functions
void onTemperature001Change() {
// Add your code here to act upon Temperature001 change
void onVariableInput001Change() {
// This function will be called when the input value changes
void onThresholdValueChange() {
// This function will be called when the threshold value is updated from the cloud
Serial.print("New threshold set: ");
Serial.println(threshold_value);
void onAlertEmailChange() {
// This will be automatically called when the email alert variable changes
// You don't need to add code here as the cloud handles the email sending
void onAlarmIsSetChange() {
// Reset burglar alarm when alarm is unset
if (!alarm_is_set){
void onALARMChange() {
// Add your code here to act upon ALARM change
void onAlarmsetChange() {
// Add your code here to act upon Alarmset change
Since Burglaralarm is READ_WRITE variable, onBurglaralarmChange() is
executed every time a new value is received from IoT Cloud.
void onBurglaralarmChange() {
// Add your code here to act upon Burglaralarm change
Serial.print("Burglar alarm state changed to: ");
Serial.println(burglaralarm);
Since ResetAll is READ_WRITE variable, onResetAllChange() is
void onResetAllChange() {
// Add your code here to act upon ResetAll change
if (reset_all) {
Serial.println("Alarm state reset by ResetAll command");
reset_all = false; // Auto-reset the ResetAll variable
Since Alarmactivated is READ_WRITE variable, onAlarmactivatedChange() is
void onAlarmactivatedChange() {
// Add your code here to act upon Alarmactivated change
Since TestValue001 is READ_WRITE variable, onTestValue001Change() is
void onTestValue001Change() {
// Add your code here to act upon TestValue001 change
Since BatteryVoltage is READ_WRITE variable, onBatteryVoltageChange() is
void onBatteryVoltageChange() {
// Add your code here to act upon BatteryVoltage change
Since LightOn is READ_WRITE variable, onLightOnChange() is
void onLightOnChange() {
// Add your code here to act upon LightOn change
Since WaterFlowRate is READ_WRITE variable, onWaterFlowRateChange() is
void onWaterFlowRateChange() {
// Add your code here to act upon WaterFlowRate change
Serial.println("Water flow rate updated:" + String(water_flow_rate) + "L/min");
Since WaterFlow02 is READ_WRITE variable, onWaterFlow02Change() is
void onWaterFlow02Change() {
// Add your code here to act upon WaterFlow02 change
Serial.println("Water flow rate 2 updated:" + String(water_flow_02) + "L/min");
Since TotalWaterPerDay is READ_WRITE variable, onTotalWaterPerDayChange() is
void onTotalWaterPerDayChange() {
// Add your code here to act upon TotalWaterPerDay change
Since TotalWaterPerWeek is READ_WRITE variable, onTotalWaterPerWeekChange() is
void onTotalWaterPerWeekChange() {
// Add your code here to act upon TotalWaterPerWeek change
Since CommsCount01 is READ_WRITE variable, onCommsCount01Change() is
void onCommsCount01Change() {
// Add your code here to act upon CommsCount01 change
Since WaterUseHigh is READ_WRITE variable, onWaterUseHighChange() is
void onWaterUseHighChange() {
// Add your code here to act upon WaterUseHigh change
