Model Rocket Tracker!
I'd like to have a location tracking device for model rocket launches. I am an experienced Arduino user but not a professional programmer. I am launching medium sized rockets about 2" in diameter and 3-4ft tall. I searched for a GPS tracker and found several projects. Are there any model rocket enthusiasts out there that have used an Arduino GPS rocket tracker successfully? I am looking into this one:
But it hasn't been updated in 6 years. Has anyone used it or know of a reliable system?
Thanks!
In general, GPS is not very good at altitude measuring, only horizontal positioning. Use barioemetric sensors for altitude.
OP wants to know where the rocket came down, or what tree it's in?
Whatever it is, it has to be carried up including batteries.
Thanks, but as I said I am mostly interested in using it to facilitate finding the rocket after it returns to ground.
Yes I am using a medium sized rocket that from what I've seen so far can carry such a payload.
How far away will it land and what is the terrain like, trees, hills etc ?
I took a quick flight over the repository. It is dated, but should still work.
I still use "naked" 433 FSK/ASK modules and software. These days better radio sets can be had that do more of the heavy lifting. It would be easy enough to use the rest of the project (the web stuff) by starting with the two Arduino sketches and substituting a modern pair of devices.
Which might give you better reange and reliability.
If I were you, I would fearlessy build the 6 year old project from one end to the other - 433 radio sets (TX and RX pair) are cheap enough and you could get a sense of how well it meets your expectations.
Then, if necessary, start looking into newer radios. This library wuold be my first big change
because it can be written once and then would allow trying many different radio sets w/ minimal changes to the firmware.
a7
What is the maximum distance at which you still need to receive the rocket’s position, and what kind of terrain is involved?
Open fields are very different from woods, hills, or a rocket lying behind an obstacle. That range requirement should probably be defined before choosing the radio system.
I'm going to launch in a flat field-like area with few obstructions. Possibly a standard model rocket club launch range. I am guessing that it might go 500-1000 ft horizontally from where it was launched and also 500-1000 ft in altitude.
For only about 500–1000 ft (150–300 m) over open ground, LoRa should have plenty of range. I'd probably choose a LoRa link over simple 433 MHz ASK/FSK modules for a new design because it generally offers much better sensitivity and robustness.
Does your rocket already have an audible beeper? GPS can get you close, but a beeper can make the last few meters of the search much easier, especially in tall grass.
I would agree with the comments about LoRa, it should be possible to receive transmissions with the GPS co-ordinates at those sort of distances.
One benefit of LoRa modules is that you can also make them send out RF audio 'beeps' that can be heard with one of the low cost Baofeng UHF handheld tranceivers. These beeps can also be picked up at fair distance and a directional yagi antenna, easy to find for the 433Mhz range, can be then be used to locate the direction of the downed rocket.
Just a thought: Would a smoke generator be possible? Of course, one that would not create a fire hazard.
Could put leds and a light detector on the outside then if you can't find it before it gets dark, you might find it quickly then.
By the 70's, my rockets came down in tiny smoking pieces.
Well, a rocket must have the best line of sight prospects for a radio signal to reach over a fair distance?
If you use a GPS module with a 10 per second update and log the data, you will be tracking where its going to land before it gets there. Since GPS also gives altitude, its final location should be pretty easy to identify.
Using something like the nRF24L01 module gives a good range and high data rate.
Even if the rocket landed in a deep hole, it shouldn't matter that you no longer recieve a signal? You'll already know, where that hole is located, even if it's on the other side of a mountain.....
You could send a signal to turn a beeper on, when you get close, if it's in deep brush.
Maybe a bit of math's involved, but I'm sure there's more than 'a bit of math's' involved in launching rockets anyway?
+1.
It's amazing how many things look like what you are searching for, I've spent too much time wandering around within 15 feet of something I know is right here..
For me it's quadcopters, and everything I fly is with a beeper. My spendier models have a beeper with a lipo built in: loud, small and immune to crash faults in the main electronics.
a7
Maybe an AirTag for accurate tracking for the last 30 feet.
I am trying to get this RocketTracker library to work. The author is not specific when he speaks of the radio modules. He used the RadioHead library with RH_ASK.h header file. I can't get the radios to communicate, I have struggled with it all day. This is exactly what I didn't want to get into. This is a link to the modules I purchased:
Does anyone know if these modules should be compatible with the RH_ASK library?
Thanks,
Stephen
They should.
Getting a radio set to work in the context of s sketch which may be sketchy is a waste of time.
Comfort first.
Look for the simplest example of a pair of sketches, one to transmit the other to receive.
The RadioHead library should have one.
Yeth. Here
Use ask_transmitter and ask_receiver.
HTH
a7
Thanks. I got the RH examples working with the 2 AVR nanos using the default initializer "RH_ASK driver" which uses pin 12 on the receiver and pin 11 on the transmitter. I believe it was written originally for the nano but the author now uses the ESP8266/32 platform. There is some conflict with the workings of the sketch that I had to mitigate. The issue that I observe is that it doesn't transmit if there is not a ~100ms delay after the GPS commands. There is further work to do to find the root cause but I just needed something working quickly for now. I will prb try to add a beeper and possibly flare or smoke if this doesn't work good enough. I'll let you know how it goes. I think I may try to upgrade to a LORA system.
Good plan.
The LoRa modules also have an FSK capability so they can simulate FM tones that you can hear on a cheap UHF handheld radio.
FSK capable modules can also put out a signal that makes it easy to get a very long range direction fix with a yagi antenna.
I was able to get an accurate fix on a satellite I built putting out a 436Mhz 100mW FSK signal with a yagi when it was at circa 1,500km distance . I got the fix accurate to 2 seconds of the orbit position, so for a speed of 28,000kmph the fix was accurate to about 15km.
