model tank
Tank has two Arduino mini's, one for main control; the other for generating sound. The tank is driven around by gamepad attached to a computer, communicating to the arduino controller onboard the tank via bluetooth. Being 1/35 in scale, it is small, roughly palm-sized. It has independent suspension, active inertial calculation and simulation, metal tracks, and ball-bearings for all running wheels and support rollers. Thanks for watching.
Hi, The tank looks great with the inertia, is it build from a motorized kit or did you motorize a scale model - either way it looks great
EDIT: I guess this is you - early peek of 1/35 scale IS-3 (sound, smoke, active inertial suspension) - RCU Forums
Are you using servos or something for the active suspension or just the weight of the tank ? It looks like there is a lot going on here how about some more on what you started out with so that we can appreciate what has gone into this - the modellers seem impressed.
Duane B
rcarduino.blogspot.com
Ditto Ditto I want two one for the Grandson and one for me ! Awesome fire mechanisms and suspension
