Momentary button as latching button
I am looking for some help please, I need to make a momentary push button act like a latching button so that when it is pressed it does something until its pressed again to turn that function off.
My current code for the function is:
/* function to control maintain mode */
void maintainMode()
  byte maintainSwitch = 0;
  maintainSwitch = digitalRead(MAINTAIN_SWITCH_PIN);
  delay(50);
  if(maintainSwitch == LOW)
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("Maintenance Mode: ON");
    lcd.setCursor(0, 2);
    lcd.print("Disable mode when complete.");
    digitalWrite(HEATER_RELAY_PIN, HIGH);
    digitalWrite(FILTER_UV_RELAY_PIN, HIGH);
  }else{
    lcd.clear();
    lcd.print("Maintenance Mode: OFF");
The above code does not work and ive spend hours trying to find a solution, any ideas?
How do you call the function "maintainMode()"? Post ALL your code.
The state change detection example shows how to do what you want.
groundFungus:
Ive just looked at the code and tried it but it still acts as a momentary button! the cade just shows its current state
wreckitsteve:
Show us! All of it! Because we know one thing for sure, the bug is in the code you did not post...
When a push button is pressed, it is pressed at human speed. This means that it stays pressed for several cycles of your loop().
