This is using the V2 ide on OSX.
If I load up the Arduino_RouterBridge/monitor.ino example and build then it complains about MsgPack being missing.
In file included from /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RPClite/src/client.h:14,
from /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RPClite/src/Arduino_RPClite.h:22,
from /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RouterBridge/src/bridge.h:27,
from /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RouterBridge/src/Arduino_RouterBridge.h:16,
from /Users/andrewcapon/Documents/Arduino/Blink_copy_20230430062317/Blink_copy_20230430062317.ino:25:
/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RPClite/src/error.h:17:10: fatal error: MsgPack.h: No such file or directory
17 | #include "MsgPack.h"
compilation terminated.
Alternatives for MsgPack.h: []
ResolveLibrary(MsgPack.h)
-> candidates: []
exit status 1
in Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries the Arduino_RouterBridge is there but MsgPackis missing.
So if I install MsgPack into my user libraries it builds.
But:
-0s, -01, -02 and -03 optimisations work fine.
With -og or -o0 though we get when linking:
Multiple Definitions:
std::__throw_bad_alloc()
std::__throw_length_error(char const*)'
Undefined:
_Unwind_GetTextRelBase
_Unwind_GetRegionStart
_Unwind_VRS_Get
__gnu_unwind_frame
_Unwind_RaiseException
_Unwind_Complete
Has anyone any idea why this lib is missing from the installation and why it doesn’t work with -og or -o0?Here are the versions:
Using library Arduino_RouterBridge at version 0.2.2 in folder: /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RouterBridge
Using library Arduino_RPClite at version 0.2.0 in folder: /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RPClite
Using library MsgPack at version 0.4.2 in folder: /Volumes/X82/Arduino/User/libraries/MsgPack
Using library DebugLog at version 0.8.4 in folder: /Volumes/X82/Arduino/User/libraries/DebugLog
Using library ArxTypeTraits at version 0.3.2 in folder: /Volumes/X82/Arduino/User/libraries/ArxTypeTraits
Using library ArxContainer at version 0.7.0 in folder: /Volumes/X82/Arduino/User/libraries/ArxContainer
We need to see your code, all of it in code tags. Then the verbose error log also in code tags.
Thanks for the reply: As I said it is the example supplied with the Uno Q: Arduino_RouterBridge/monitor.ino example
This file is part of the Arduino_RouterBridge library.
Copyright (c) 2025 Arduino SA
This Source Code Form is subject to the terms of the Mozilla Public
License, v. 2.0. If a copy of the MPL was not distributed with this
file, You can obtain one at http://mozilla.org/MPL/2.0/.
#include <Arduino_RouterBridge.h>
bool set_led(bool state) {
digitalWrite(LED_BUILTIN, state);
return state;
int add(int a, int b) {
This file has been truncated. show original
If someone else could possible try it with -og optimisation?
FQBN: arduino:zephyr:unoq
Using board 'unoq' from platform in folder: /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0
Using core 'arduino' from platform in folder: /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0
Detecting libraries used...
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/sketch/monitor.ino.cpp -o /dev/null
Alternatives for Arduino_RouterBridge.h: [Arduino_RouterBridge@0.2.2]
ResolveLibrary(Arduino_RouterBridge.h)
-> candidates: [Arduino_RouterBridge@0.2.2]
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RouterBridge/src -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/sketch/monitor.ino.cpp -o /dev/null
Alternatives for Arduino_RPClite.h: [Arduino_RPClite@0.2.0]
ResolveLibrary(Arduino_RPClite.h)
-> candidates: [Arduino_RPClite@0.2.0]
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RouterBridge/src -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RPClite/src -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/sketch/monitor.ino.cpp -o /dev/null
Alternatives for MsgPack.h: [MsgPack@0.4.2]
-> candidates: [MsgPack@0.4.2]
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RouterBridge/src -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RPClite/src -I/Volumes/X82/Arduino/User/libraries/MsgPack -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/sketch/monitor.ino.cpp -o /dev/null
Alternatives for DebugLog.h: [DebugLog@0.8.4]
ResolveLibrary(DebugLog.h)
-> candidates: [DebugLog@0.8.4]
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RouterBridge/src -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RPClite/src -I/Volumes/X82/Arduino/User/libraries/MsgPack -I/Volumes/X82/Arduino/User/libraries/DebugLog -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/sketch/monitor.ino.cpp -o /dev/null
Alternatives for ArxTypeTraits.h: [ArxTypeTraits@0.3.2]
ResolveLibrary(ArxTypeTraits.h)
-> candidates: [ArxTypeTraits@0.3.2]
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RouterBridge/src -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RPClite/src -I/Volumes/X82/Arduino/User/libraries/MsgPack -I/Volumes/X82/Arduino/User/libraries/DebugLog -I/Volumes/X82/Arduino/User/libraries/ArxTypeTraits -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/sketch/monitor.ino.cpp -o /dev/null
Alternatives for ArxContainer.h: [ArxContainer@0.7.0]
ResolveLibrary(ArxContainer.h)
-> candidates: [ArxContainer@0.7.0]
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RouterBridge/src -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RPClite/src -I/Volumes/X82/Arduino/User/libraries/MsgPack -I/Volumes/X82/Arduino/User/libraries/DebugLog -I/Volumes/X82/Arduino/User/libraries/ArxTypeTraits -I/Volumes/X82/Arduino/User/libraries/ArxContainer -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/sketch/monitor.ino.cpp -o /dev/null
Generating function prototypes...
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RouterBridge/src -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RPClite/src -I/Volumes/X82/Arduino/User/libraries/MsgPack -I/Volumes/X82/Arduino/User/libraries/DebugLog -I/Volumes/X82/Arduino/User/libraries/ArxTypeTraits -I/Volumes/X82/Arduino/User/libraries/ArxContainer -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/sketch/monitor.ino.cpp -o /private/var/folders/49/4t7f1jx17t540mn9j9zm63600000gp/T/4035755422/sketch_merged.cpp
/Volumes/X82/Arduino/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/49/4t7f1jx17t540mn9j9zm63600000gp/T/4035755422/sketch_merged.cpp
Compiling sketch...
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RouterBridge/src -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RPClite/src -I/Volumes/X82/Arduino/User/libraries/MsgPack -I/Volumes/X82/Arduino/User/libraries/DebugLog -I/Volumes/X82/Arduino/User/libraries/ArxTypeTraits -I/Volumes/X82/Arduino/User/libraries/ArxContainer -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/sketch/monitor.ino.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/sketch/monitor.ino.cpp.o
Compiling libraries...
Compiling library "Arduino_RouterBridge"
Compiling library "Arduino_RPClite"
Compiling library "MsgPack"
Compiling library "DebugLog"
Compiling library "ArxTypeTraits"
Compiling library "ArxContainer"
Compiling core...
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/analogReference.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/analogReference.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/zephyrCommon.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/zephyrCommon.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/abi.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/abi.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/USB.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/USB.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/Print.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/Print.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/Common.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/Common.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/PluggableUSB.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/PluggableUSB.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/main.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/main.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/threads.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/threads.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/new.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/new.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/String.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/String.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/IPAddress.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/IPAddress.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/Stream.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/Stream.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/CanMsg.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/CanMsg.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-gcc -g -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cflags.txt -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/usb_device_descriptor.c.o /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/usb_device_descriptor.c
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/itoa.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/itoa.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/CanMsgRingbuffer.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/CanMsgRingbuffer.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -g -Og -std=gnu++17 -c -w -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/generated/zephyr/autoconf.h -imacros/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/llext-edk/include/zephyr/include/zephyr/toolchain/zephyr_stdint.h @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/cxxflags.txt -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib -lstdc++ -lsupc++ -fdata-sections -ffunction-sections -fno-unwind-tables -MMD -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DARDUINO=10607 -DARDUINO_UNO_Q -DARDUINO_ARCH_ZEPHYR -DARDUINO_ARCH_ZEPHYR -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated -I/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/api/deprecated-avr-comp -iprefix/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx @/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/includes.txt /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/zephyrSerial.cpp -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/zephyrSerial.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/USB.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/abi.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/CanMsg.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/CanMsgRingbuffer.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/Common.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/IPAddress.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/PluggableUSB.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/Print.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/Stream.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/api/String.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/itoa.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/main.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/new.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/threads.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/usb_device_descriptor.c.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/zephyrCommon.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-ar rcs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/zephyrSerial.cpp.o
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(functexcept.o): in function `std::__throw_bad_alloc()':
functexcept.cc:(.text.unlikely._ZSt17__throw_bad_allocv+0x0): multiple definition of `std::__throw_bad_alloc()Archiving built core (caching) in: /Users/BobTheDog/Library/Caches/arduino/cores/ccbdb29ec222d9653a789e0412d427aa/core.a
Linking everything together...
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/arm-zephyr-eabi-g++ -L/Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671 -L/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx -Wl,--gc-sections -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -std=gnu++17 -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-unwind-tables -fno-use-cxa-atexit -lstdc++ -lsupc++ -lnosys -nostdlib --specs=picolibc.specs --specs=nosys.specs /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/sketch/monitor.ino.cpp.o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/analogReference.cpp.o -Wl,--start-group /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a -lstdc++ -lsupc++ -Wl,--end-group -e main -T/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/arduino_uno_q_stm32u585xx/syms-dynamic.ld -T/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/_ldscripts/memory-check.ld -T/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/variants/_ldscripts/build-static.ld -o /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/monitor.ino_check.tmp
'; /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a(abi.cpp.o):/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/abi.cpp:14: first defined here
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(functexcept.o): in function `std::__throw_length_error(char const*)':
functexcept.cc:(.text.unlikely._ZSt20__throw_length_errorPKc+0x0): multiple definition of `std::__throw_length_error(char const*)'; /Users/BobTheDog/Library/Caches/arduino/sketches/B5F7D606791C29827F6B414DD696F671/core/core.a(abi.cpp.o):/Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/cores/arduino/abi.cpp:11: first defined here
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(functexcept.o):(.ARM.exidx.text.unlikely._ZSt28__throw_bad_array_new_lengthv+0x0): undefined reference to `__aeabi_unwind_cpp_pr1'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_arm.o):(.ARM.exidx.text.__cxa_type_match+0x0): undefined reference to `__aeabi_unwind_cpp_pr0'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_personality.o):(.ARM.exidx.text._ZL28read_encoded_value_with_basehjPKhPj+0x0): undefined reference to `__aeabi_unwind_cpp_pr0'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_personality.o): in function `base_of_encoded_value(unsigned char, _Unwind_Context*)':
eh_personality.cc:(.text._ZL21base_of_encoded_valuehP15_Unwind_Context+0x2e): undefined reference to `_Unwind_GetTextRelBase'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: eh_personality.cc:(.text._ZL21base_of_encoded_valuehP15_Unwind_Context+0x36): undefined reference to `_Unwind_GetDataRelBase'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: eh_personality.cc:(.text._ZL21base_of_encoded_valuehP15_Unwind_Context+0x3e): undefined reference to `_Unwind_GetRegionStart'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_personality.o):(.ARM.exidx.text._ZL21base_of_encoded_valuehP15_Unwind_Context+0x0): undefined reference to `__aeabi_unwind_cpp_pr1'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_personality.o):(.ARM.exidx.text._ZL18read_encoded_valueP15_Unwind_ContexthPKhPj+0x0): undefined reference to `__aeabi_unwind_cpp_pr0'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_personality.o): in function `parse_lsda_header(_Unwind_Context*, unsigned char const*, lsda_header_info*)':
eh_personality.cc:(.text._ZL17parse_lsda_headerP15_Unwind_ContextPKhP16lsda_header_info+0xa): undefined reference to `_Unwind_GetRegionStart'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_personality.o):(.ARM.exidx.text._ZL17parse_lsda_headerP15_Unwind_ContextPKhP16lsda_header_info+0x0): undefined reference to `__aeabi_unwind_cpp_pr0'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_personality.o): in function `_Unwind_GetGR':
eh_personality.cc:(.text._Unwind_GetGR+0xc): undefined reference to `_Unwind_VRS_Get'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_personality.o):(.ARM.exidx.text._Unwind_GetGR+0x0): undefined reference to `__aeabi_unwind_cpp_pr0'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_personality.o): in function `__gxx_personality_v0':
eh_personality.cc:(.text.__gxx_personality_v0+0x28): undefined reference to `__gnu_unwind_frame'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: eh_personality.cc:(.text.__gxx_personality_v0+0x54): undefined reference to `_Unwind_VRS_Set'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: eh_personality.cc:(.text.__gxx_personality_v0+0x88): undefined reference to `_Unwind_VRS_Set'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: eh_personality.cc:(.text.__gxx_personality_v0+0x9a): undefined reference to `_Unwind_VRS_Set'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: eh_personality.cc:(.text.__gxx_personality_v0+0xbc): undefined reference to `_Unwind_VRS_Set'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: eh_personality.cc:(.text.__gxx_personality_v0+0xe6): undefined reference to `_Unwind_GetLanguageSpecificData'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_terminate.o):(.ARM.exidx.text._ZN10__cxxabiv112__unexpectedEPFvvE+0x0): undefined reference to `__aeabi_unwind_cpp_pr1'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_terminate.o):(.ARM.exidx.text._ZSt10unexpectedv+0x0): undefined reference to `__aeabi_unwind_cpp_pr1'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_throw.o):(.ARM.exidx.text._ZL23__gxx_exception_cleanup19_Unwind_Reason_CodeP21_Unwind_Control_Block+0x0): undefined reference to `__aeabi_unwind_cpp_pr0'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_throw.o): in function `__cxa_throw':
eh_throw.cc:(.text.__cxa_throw+0x26): undefined reference to `_Unwind_RaiseException'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_throw.o):(.ARM.exidx.text.__cxa_throw+0x0): undefined reference to `__aeabi_unwind_cpp_pr0'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(si_class_type_info.o):(.ARM.exidx.text._ZNK10__cxxabiv120__si_class_type_info11__do_upcastEPKNS_17__class_type_infoEPKvRNS1_15__upcast_resultE+0x0): undefined reference to `__aeabi_unwind_cpp_pr0'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(class_type_info.o):(.ARM.exidx.text._ZNK10__cxxabiv117__class_type_info11__do_upcastEPKS0_PPv+0x0): undefined reference to `__aeabi_unwind_cpp_pr0'
/Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: /Volumes/X82/Arduino/Arduino15/packages/zephyr/tools/arm-zephyr-eabi/0.16.8/bin/../lib/gcc/../../picolibc/arm-zephyr-eabi/lib/thumb/v8-m.main+fp/hard/libstdc++.a(eh_catch.o): in function `__cxa_begin_catch':
eh_catch.cc:(.text.__cxa_begin_catch+0x4c): undefined reference to `_Unwind_Complete'
collect2: error: ld returned 1 exit status
Using library Arduino_RouterBridge at version 0.2.2 in folder: /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RouterBridge
Using library Arduino_RPClite at version 0.2.0 in folder: /Volumes/X82/Arduino/Arduino15/packages/arduino/hardware/zephyr/0.52.0/libraries/Arduino_RPClite
Using library MsgPack at version 0.4.2 in folder: /Volumes/X82/Arduino/User/libraries/MsgPack
Using library DebugLog at version 0.8.4 in folder: /Volumes/X82/Arduino/User/libraries/DebugLog
Using library ArxTypeTraits at version 0.3.2 in folder: /Volumes/X82/Arduino/User/libraries/ArxTypeTraits
Using library ArxContainer at version 0.7.0 in folder: /Volumes/X82/Arduino/User/libraries/ArxContainer
exit status 1
Compilation error: exit status 1
Hm, quite a few errors(6+?). Have you recorded an issue with the developers via github?
Just in case, if you are using a Silicon Mac, have you installed Rosetta2? Often the tool chain is not universal or Silicon.
Thanks, not yet reported an error, I will try tomorrow on linux to see if the problem is also there, maybe with windows if I can face that as well.
I have been seeing some weird OSX issues, maybe no one else is using this board with osx or I am doing strange things. Not using a silicon Mac, good old fashioned intel
I didn't mention it because I assumed it was obvious, but do the compile normally without any switches.
BobTheDog:
-0s, -01, -02 and -03 optimisations work fine.
With -og or -o0 though we get when linking:
It is the optimisation level that causes the problem.
