Hi everybody,
I want to make an Arduino MKRZero play an audio file (e.g. wav) from a SD Card and send the audio signal on a 6.35mm mono jack socket, so that I can play the file on a guitar speaker (with its own power supply). So no need to drive a speaker.
I thought of doing it this way:
My questions are:
- I am sending the audio signal from the Arduino using the function analogWrite() on the digital pin D0. However, I considered another option, which is sending data over SPI to a DAC, e.g. DAC7742. What would be the advantages of using a DAC over SPI rather than Analogwrite directly to the jack socket like here? Speed? Sound quality?
- Before I order the components, do you see any missing hardware/components or error between the Arduino and the audio signal in output (J3) so that I can connect to a guitar amplifier?
Thanks in advance for your help!
Stochelo
If you're not driving a speaker, why are you using an audio power amplifier IC?
The 10 bit DAC on the MKR Zero is on pin A0, why are you not using it? It's even labelled on the diagram you posted.
The built-in DAC is only 10-bits but that may be OK for "guitar quality". I would try that first, since it's easier.
I don't have any experience with 10-bit audio but with 8-bits you can hear quantization noise, which is a slight "fuzz" on top of the audio. Like regular noise it's most-noticeable with quiet sounds, but unlike regular analog noise it goes-away completely with silence.
As you may know, CDs are 16-bits.44.1kHz which is generally better than human hearing.
You shouldn't need any amplification. And, the LM386 is a (small) "power amplifier", designed to drive a speaker. It's not intended as a preamp.
You do need a "DC blocking capacitor" because the microcontroller can't put-out the negative half of the AC audio signal and it will have a DC bias.
And you probably don't need the volume control since your guitar amp probably already has one. But if you leave out the pot you should have a resistor to ground, which along with the capacitor makes a high pass filter. (DC is "zero Hz" and it's blocked by a high-pass filter).
@anon57585045 : Good question, that was one of the things I was not sure about. I'm not good at electronics, I'm more a SW guy, so I assumed that it could be necessary to have a "louder" audio signal (with a higher voltage), so that the signal reaching the amp is not too quiet. But I guess I was wrong! I will delete the AOP block then!
I will use the 10-bits DAC from pin A0!
@DVDdoug : I redid the diagram (much simpler now), hopefully I correctly placed the DC blocking capacitor. I looked up how to calculate its value, but I have no idea about the input impedance of the circuit to which this capacitor is connected or the frequency of the signal. Do you have any idea what would be the Capacitor value?
Also, I might have connect this "device" (my project is a pedal) to a mixing table which could be 10 meters from me, that's why I want the possibility of changing the volume from the pedal itself. But thank you for letting me know that I should have a high-pass filter if I decided to remove the volume control!
The input impedance of a guitar amp is usually 1M or more. Or with a 10K pot you can use that as your resistance calculation.
I just noticed that your volume pot is wired wrong. The center-tap is the output to the guitar amp. I found a schematic here.
Try to find an "audio taper" pot. A regular linear pot won't sound linear and it will be too loud at "low" settings.
Thanks @DVDdoug , you're right, my volume pot was wired wrong! I just ordered all the components for my project, including a 500kOhm audio taper potentiometer. For the capacitor blocking the DC, I will do some tests directly on the board, I'm afraid that any of my calculation would be off.
Thanks for your help!
It isn't uncommon to find an op amp circuit on an output though, it can make filters and line drivers.
