I have been banging my head for the last hours with this and I don’t understand what is wrong. I have two Arduinos connected to each other via I2C. I simply want the master to just request two bytes from the slave. I am basically using the sketches found on the Arduino website. Pasting them below:
Master Receive
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
Wire.requestFrom(8, 2); // request 2 byte from slave device #8
while (Wire.available()) { // slave may send less than requested
Serial.println(Wire.read()); //Write what you receive
delay(100);
Slave send
#include <Wire.h>
Wire.begin(8); // join i2c bus with address #8
Wire.onRequest(requestEvent); // register event
delay(100);
// function that executes whenever data is requested by master
// this function is registered as an event, see setup()
void requestEvent() {
Wire.write(66);
Wire.write(40);
As you can see, it is (or should be) very straight forward. In the master, I am expecting to receive the two values that I send in requestEvent. 66 and 40. However, I always receive 255 and 40 instead.
Am I missing something very obvious here?! Because this is really frustrating… >:(
