More than one error please help
ok I am putting this together and I have to make it work if I can!
Please look over and compile code if you can!
I am using an Arduino mega 2560, dht22, rtc ds3231, I have LCD on order Geekcreit® IIC / I2C 1602 Blue Backlight LCD Display Module For Arduino, Relay shield v3.0.
Please look over error list and please get back at me please!
tester1.ino (5.89 KB)
No
You show us the errors.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
PS Sorry your code may be too big to use code tags.
Quite a lot of your code is not in a function. For instance this block, but there are others
Wire.begin();
RTC.begin();
lcd.begin(16, 2); // Configura lcd numero columnas y filas
lcd.setCursor(0, 0); //Show "TIME" on the LCD
lcd.print("TIME");
lcd.setCursor(0, 1);
lcd.print("ON");    //Show "ON" on the lcd
lcd.setCursor(6, 1);
lcd.print("OFF");  //Show "OFF" on the lcd
To clarify you can only declare at top level, not execute code (other than as a side effect of
expressions in the declarations).
