jurs:
Try this code, it can translate from ASCII text to MORSE code and the other way round:
/* Serial Morse Encoder and Decoder
* written by 'jurs' for Arduino forum
* Usage:
* Use the serial monitor to send ASCII text ==> will be encoded to morse code
* Use the serial monitor to send dots and dashes ==> will be decoded to ASCII
char morseCode[]={ // first bit set tells where morse encoding starts
B00000101, // A = .-
B00011000, // B = -...
B00011010, // C = -.-.
B00001100, // D = -..
B00000010, // E = .
B00010010, // F = ..-.
B00001110, // G = --.
B00010000, // H = ....
B00000100, // I = ..
B00010111, // J = .---
B00001101, // K = -.-
B00010100, // L = .-..
B00000111, // M = --
B00000110, // N = -.
B00001111, // O = ---
B00010110, // P = .--.
B00011101, // Q = --.-
B00001010, // R = .-.
B00001000, // S = ...
B00000011, // T = -
B00001001, // U = ..-
B00010001, // V = ...-
B00001011, // W = .--
B00011001, // X = -..-
B00011011, // Y = -.--
B00011100, // Z = --..
B00111111, // 0 = -----
B00101111, // 1 = .----
B00100111, // 2 = ..---
B00100011, // 3 = ...--
B00100001, // 4 = ....-
B00100000, // 5 = .....
B00110000, // 6 = -....
B00111000, // 7 = --...
B00111100, // 8 = ---..
B00111110, // 9 = ----.
#define NUMCHARS sizeof(morseCode)
char morseChars[]="ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789";
void sendMorseChar(char c)
// invalid ASCII chars will not be encoded into anything
// valid ASCII chars are encoded into morse dots/dashes
// then finish with sending a space character ' '
char* found= strchr(morseChars, c);
if (found==NULL) return;
byte morse= morseCode[found-morseChars];
boolean firstBitFound=false;
for (int i=7; i>= 0; i--)
byte thisBit= bitRead(morse,i);
if (firstBitFound)
if (thisBit) Serial.print('-');
else Serial.print('.');
else if (thisBit) firstBitFound=true;
Serial.print(" ");
char handleMorseInput(char c)
{ // char c==0 is for clearing internal receiveBuf
// char c==1 is for evaluating internal receiveBuf
static byte receiveBuf;
if (c==0)
receiveBuf=1; // set 0-bit
return 0;
else if (c==1)
for (int i=0;i<NUMCHARS;i++)
if (receiveBuf==morseCode[i])
return morseChars[i];
return('*');
else if (c=='.') receiveBuf= receiveBuf<<1;
else if (c=='-') receiveBuf= (receiveBuf<<1) | 1;
return 0;
void handleSerialInput()
static boolean isMorseInput=false;
if (!Serial.available()) return;
char c=Serial.read();
// automatic detection of morse or ASCII input
if (c=='.' || c=='-')
if (!isMorseInput)
{ // switch to morse input and clear input buffer
isMorseInput= true;
handleMorseInput(0);
handleMorseInput(c);
if (isMorseInput)
char dc= handleMorseInput(1); // retrieve decoded char from input buffer
if (dc>32) Serial.print(dc);
isMorseInput=false;
else if (c=='\n') Serial.println();
else if (c==' ') Serial.print(' ');
else if (c>32) // filter out control characters and international special characters
sendMorseChar(toupper(c));
handleSerialInput();
Input is taken from the serial monitor.
If you want to see additional blinking LED output instead of output on Serial only, and if you want to set a busy/timeout flag/LED while sending, I think this can be added easily.
Which pins are the speaker and LED's connected too?
