I am trying to make a PID controlled head block, but have had two mosfets croak. Can somebody verify that my wiring and code are correct? I have pwm voltage coming in and out of the mosfet driver, but it if the same voltage, so now I am wondering if I damaged the driver and the mosfets or just the mosfets, and what the problem is.
...I have pwm voltage coming in and out of the mosfet driver, but it if the same voltage, so now I am wondering if I damaged the driver and the mosfets...
The TC4427 should bump the PWM voltage to 12V (in this case) so there's a problem there. What does the output look like when not connected to the MOSFET board?
If the MOSFET is not being driven hard enough it may be more resistive than it would otherwise be and will get hot for higher drain currents. If the heating is bad enough the FET may fail.
You may want to consider adding some capacitors between the VDD and GND pins of the 4427 per the datasheet, figure 4:
So I have been messing with it and my FET will not turn on without 12V (pwm=2000) into the driver as opposed to limiting the PWM range to 0-255. So I am guessing the driver is fried.
jscates00:
Do you have an oscilloscope? If so, can you capture the input and output waveforms?
So what if it is? Why can't using a forum be a legitimate use of all the resources available to us? As long as the asker cites the forum as a source, and doesn't fall foul of the "own unaided work except as cited" kind of rule, just like with any other source, what's wrong with it?
It's your prerogative, as always of course, to assist or not to assist.
