I'm planning to create my own motor controller using mosfets in an H-Bridge configuration for forward and reverse, but also to use PWM to vary the DC motor speeds. (it will then eventually be put into the heng long tiger 1 tank I'm pulling apart!)
What mosfet characteristics make it compatible with PWM from the arduino when I look at datasheets?
Am I able to connect two mosfets in parallel to a single arduino PWM port without frying things so they can be PWM at the same time?
What additional components will I need for shortcomings of 2-wire 7.2v DC motors and mosfets to protect components and the battery they will run off?
I'm currently salvaging components from retired computer power supplies and motherboards, I have a wide selection of mosfets that hold far more current than needed but I do not understand which ones are better suited to my project.
Thank you.
